Hi thanks for the update I have still been having issue with my garage door opener it was still showing as a switch in lights but now it says it cant reach the door opener red error comes up above the app. I know the door is working I tried it in another dashboard and no issues. it works off a zooz relay switch.
Hestia v1.6.8 and v1.6.9 — Garage doors, and a keyboard/screen-reader pass
Two releases landed close together, so here they are in one go.
Garage doors (v1.6.9)
Hestia now treats a garage door as a garage door. Before this it had no concept of one, so if you added an opener it was stored as a light switch.
That had a real consequence worth knowing about: it counted as a light, which meant "all lights on" or "all lights off" sent it an on/off command. On a relay-style opener, which is most Hubitat garage setups, on is the command that moves the door. If you have a garage door in Hestia, this release is the one to take.
What you get now:
- A control in Security, under your locks, and in its room if you've assigned one. Both stay in sync.
- Real states: Closed, Open, Opening, Closing, or Unknown, with the panel in the icon travelling up or down while the door is actually moving.
- Closing is one tap. Opening asks first, with a confirm button that expires after five seconds. By voice, closing is immediate and opening waits for a spoken "yes", because a wake word can be set off by a TV or someone outside a window. Routines can close a garage but never open one, since a routine can run with nobody home.
- It drives your hardware the way it expects: proper garage devices get open/close, relays get a pulse, momentary openers get push. Openers that use a single pulse for both directions confirm in both directions and show one honest "Move door" button.
- It won't claim a door is shut when it isn't. If your hub reports an unknown state, or a driver gets stuck reporting "opening" (a known Hubitat quirk), you get Unknown rather than a comfortable lie.
Detection works by capability for any brand. Relay openers don't advertise a garage capability at all, so those are matched on a name containing "garage" plus door/opener, and anything missed can be set by hand in Settings, which now lists Garage Door as a device type. If you already had one saved as a switch, it moves out of your lights automatically, but only when the device's own capabilities prove it is a door. A switch named "garage light" stays exactly where it is.
myQ owners: Chamberlain closed their API to third parties back in 2023, which is why the Hubitat integrations stopped working. There's no safe way around it from Hestia's side, and I'm not going to ask anyone to store their Chamberlain password to try. Local hardware like ratgdo or the Konnected GDO blaQ replaces the cloud path and shows up as an ordinary Hubitat device, which Hestia then picks up on its own. Check your opener's learn button first: white means Security+ 3.0, which ratgdo doesn't support.
Keyboard and screen reader support (v1.6.8)
If you navigate by keyboard or use a screen reader, most of Settings was unreachable. Every clickable element can now be reached with Tab and activated with Enter or Space, Settings behaves as a proper dialog (focus moves in and back out, Escape closes it), fields are tied to their labels, and the toggles announce themselves. A visible focus outline appears for keyboard users only, so nothing changes if you use a mouse or touch.
Exit delay, and a clearer "Hub unreachable" (v1.6.8)
The arming countdown now agrees with itself everywhere. The mode row highlights the mode you're arming into instead of leaving Disarm lit, and the card, sidebar, topbar and Home screen all show the same ticking countdown, so leaving the Security screen no longer loses it.
The "Hub unreachable" banner also names the likely cause instead of one generic line. On an HTTPS hub address it points out that this device may not have accepted the hub's certificate yet, with a link to go do it. Each phone, tablet and computer needs that once.
As always, update through HPM, or just reload if you use hestari.com.
Hey there,
I just published two new releases one of which was aimed to resolve this. You should be able to either auto-identify or manually classify your device as a door opener. Can you check now please?
Thank you!
Yep that did it nice. Thank you just noticed it continues showing closing for a while mabey 5 min or so then goes to unknown after it's closed not a big deal but wanted to let you know. (A little update after playing around with things I tied the relay in with the door sensor using the zooz garage door app. This fix the issue shows and works as it should that one was me. Thank you)
Hey there, glad you liked the fix. If you can take a look at your logs after you close, and paste the state of them so that I can diagnose what's causing the lag that'd be swell. You can go to hubitat logs to see how the device is reporting the statuses.
Hestia v2.0.0: Cloud sync gets a real trust model
Major version because the way your synced settings are stored changed at the foundation. Using Hestia doesn't change at all, and your settings, devices, rooms, PINs and notifications all carry over untouched.
What you need to do
Update the companion app. Either HPM (Update, tick Hestia Dashboard), or paste HestiaDashboard.groovy over Apps Code → Hestia Dashboard and Save.
Then open the Hestia app and click Done. Easy to miss and it matters: saving the code doesn't apply it to the running app, and clicking Done is also what pulls the new dashboard down to your hub.
The dashboard itself needs nothing. On hestari.com just reload. Served from your hub, it arrives when you click Done above, or within three hours on its own.
Check it: Settings → Diagnostics → Run all checks. Companion App green "v2.0.0 (up to date)" means both halves agree. If Cloud Sync says "Not migrated yet", that's expected right after updating, not a fault. Reload once and it goes green.
Worth doing promptly if you run a wall panel. Your devices won't update together, and a device left on the old dashboard can wipe the household secret for the others. The new app prevents that.
What was wrong
If you use Cloud Sync, your settings were encrypted with a key derived from your home's public IP plus a fixed string sitting in this project's own source code, which anyone can read.
So anyone leaving the internet from the same public IP as you could work out your key and read your record: Maker API token, both PIN hashes, camera URLs, Anthropic and Google keys.
If your house has its own public IP, that means someone inside your house, and the real risk was low. If your ISP has you behind CGNAT, you share that IP with a lot of unrelated homes. I have no reason to think anyone did this. It was still true and it shouldn't have been.
What it is now
Your household gets its own 256-bit secret, generated on your device and never sent to hestari.com. The record is split: the sensitive half is encrypted and the servers hold no decryption code at all, because a backend that could still read it would make the split decorative. The readable half holds only what's needed to answer "a door opened, should anyone be notified?" — no tokens, no keys, no PINs, no camera URLs.
Writes now have to prove they hold your Maker API token, so a neighbour on your IP can't overwrite your record.
Stating this plainly: your raw Maker token is now sent to hestari.com on every settings save. Over HTTPS, hashed, compared, discarded, never stored. If you'd rather not, turn Cloud Sync off and Hestia runs entirely against your hub. Rotating your token won't lock you out.
Nothing to pair. Your hub hands the secret to your devices alongside the config they already pull from it, and existing households migrate themselves with no gap in notifications.
Also
Losing the hub now gives you an actual screen after twenty seconds, naming the likely cause, instead of a red bar that's easy to miss on a tablet across the room. It stays out of the way during an alarm or entry countdown. Diagnostics' Cloud Sync and Push checks now do a real round trip instead of trusting local state, so a device that's quietly stopped being registered shows up as failing.
Full technical detail is in the release notes.
Hi again thanks for the garage door fix, since I installed and set up the (zooz garage door app) after your update there is no issues or lag Hestia app is showing the correct door position ( open or closed ) and functions perfect to open and close the overhead door.
Amazing. Thanks for confirming and I'm glad it worked out for you. If there's anything else you find, please feel free to let me know.
v2.0.1 forum note (follow-up post in the existing thread)
v2.0.1 is up, right on the heels of 2.0.0. Apologies for the back to back release, but this one matters if you already updated.
2.0.0's encryption only actually kicked in when you saved a setting. On startup the dashboard would try, find no household key yet, and quietly give up, because the key was only ever created during a settings save. So if you updated and never opened Settings, you are still on the old key, with nothing on screen telling you so.
I caught it by checking my own household's stored record after release and finding it still in the old format. Clicking Save & Apply migrated it instantly, which is what confirmed the cause.
2.0.1 creates the key on startup instead. Nothing for you to do differently.
If you are already on 2.0.0: either take this update, or just open Settings and hit Save & Apply. Either one fixes it. Settings, Diagnostics, Run all checks will show Cloud Sync green "Synced" once you are across.
The companion app code did not change in this release. Only its version number moved so it stays in step with the dashboard. Worth re-pasting anyway, otherwise Diagnostics shows amber for a version mismatch when nothing is actually wrong.
Hi i just lost connection to all my devices after the latest v2 update.
Try updating to v2.0.1, make sure your groovy and app are both up to date as well.
Yes i did I had to reinstall my device and it synchronize withe the other devices I could never get my two fire 10 tablets to connect to the cloud I active log server errorHTTP 404 try refreshing in a moment and when I paste the url from Hestia wall panel into fully it comes up with a (ssl error when loading https://my ip address /apps ect.) All my device are on the same network my samsung tablet and cell including my pc are all fine just the 2 tablets
Good to hear the sync sorted itself out.
The tablets are a different problem and I think I know it. That HTTP 404 on the Activity Log can't come from my server, it only ever answers 200 or 500. A 404 means the request never left your network, which tells me those two tablets are loading Hestia from your hub's own address rather than from hestari.com. Everything cloud-related is relative, so on a hub-served page it all gets pointed at the hub, which has no idea what to do with it.
The SSL error is separate and it's a Fire tablet thing, not a Hestia one. Android's WebView won't accept your hub's self-signed certificate. Fully Kiosk has a setting for exactly this: Settings → Advanced Web Settings → Ignore SSL Errors. Turn that on and the wall panel URL should load.
If you want those tablets on cloud sync too, point them at hestari.com instead of the hub address. I'm looking at making the hub-served copy talk to the cloud properly, it just wasn't safe to do before the v2 encryption work landed.
Just to reassure you on the tablets, that one isn't from the v2 update. The cloud calls have gone to whichever address the page was loaded from since long before it, so a hub-loaded dashboard has always had that problem. It's just more visible now you're looking at it.
Ok thanks let me do some checking on my end I'll update you on my findings. Update: Perfect the setting Ignore SSL Errors in fully fixed the connection issues.
Fantastic. Thanks for letting me know and glad it was resolved.
Hi so I ran into issues again not sure what happened i had all the dashboards working fine but the one fire tablet went to set it up today and turn off the ssl in fully but would not let me connect, then I went to Hestia.com and this gave me the start page and afterwards I lost everything again and had to reinstall all my devices on my pc but still and the disabled ssl is not helping I cant connect on any of my devices also on the pc I'm getting
not sure what the fix is do I delete all of it and start fresh? It seems when i try to alter one dashboard I run into trouble with all of them on my other devices and cant connect. I dont understand why it will connect one time then not the other. Im now also getting this new (This device needs your household key) in diagnostic have no idea how to solve it.
v2.0.2 forum post
v2.0.2 is up. Take this one if you use cloud sync.
I introduced a bug in v2.0.0 that could wipe your settings across every device in your home. @jbwrd3 hit it over the past few days. Nothing he did caused it.
What went wrong. v2.0.0 started encrypting your settings with a key belonging to your household. What I missed is that the old weak key was also how a device bootstrapped itself. So a device that could not reach your hub had no way in, Hestia assumed it was a brand new household, and showed the setup wizard. Finishing that wizard rebuilt rooms from scratch and created a new household key, which locked out every other device. They would then get the wizard too. One device starting fresh took the whole household with it.
The tell was Diagnostics showing "Record present but unreadable".
What it does now. Hestia tells the difference between a new household and an existing one it cannot read. When it finds settings it cannot decrypt it no longer offers the wizard, it explains and points at the fix.
Already stuck? You do not need the update to recover. Open Hestia on a device that still works → Settings → Wall Panel → open that link on the stuck device. It carries your household key across.
One correction to my earlier instructions. Use the
Update Dashboard File button, not Done. Done runs a conditional download that can silently skip and leave your hub on the old dashboard.
Longer write-up, including the technical detail, is in the v2.0.2 release notes.
Hi So I've done the 2.0.2 update with same results none of my devices are working proper even when i paste the url from wall panel, when i use http://Hub IP/local/index.html it cant reach the cloud and when I use https://hestari.com i get (This device needs your household key) this is on all my dashboard devices. Is there a way to start from scratch ?
Nothing you did wrong here, and you do not need to start from scratch. The Wall Panel link only carries your household key if the device you copy it from has the key, and right now none of yours do, so you were pasting a link with nothing in it. That is on me and I am fixing it.
Your key is on your hub. Two steps:
- On your network, open
http://<your-hub-ip>/local/hestia-token.json. NoteappIdandtoken. - Open
http://<your-hub-ip>/apps/api/<appId>/config?access_token=<token>. Find"cloudSecret"and copy the 64 characters after it.
Then on each device that is stuck, open Hestia <those 64 characters>. That hands the device the key directly and pulls your settings back. Hestia strips it out of the address bar straight away.
If there is no cloudSecret in that output, tell me and we will do it the other way. If you go through "Set up as a new household" instead, use the same Maker API token you already have, not a new one, or the write gets rejected.
Hi i did get the appid and the token but when i enter the info and entered it was a blank screen.
