I also went through the new household key settings and still have cloud asking for a key. I did this a few times.
Hi, that blank page is on me. hestia-token.json has two sets of credentials in it and I only said "appId and token", so it is easy to grab the wrong pair. The Maker API ones, makerApiAppId and makerApiToken, give you exactly that blank page. You want the plain appId and token.
Rather than have you build that URL by hand, I have made the recovery screen do it for you. Reload hestari.com first, and check the footer reads v2.1.3 so you know you have the new build. On the screen asking for your household key there is now a box at the top to paste the whole of hestia-token.json into, and a Build my link button. Open the link it gives you, then paste whatever that page shows into the second box. It will pull the key out, so you do not have to find it yourself.
If that link comes up blank or just says null, stop there and tell me. That means your hub has no saved settings, which is a different problem, and starting fresh is the right move rather than hunting for a key that is not there.
One thing that may explain the "did this a few times" part. If you have been going through "Set up as a new household", that write has to prove it holds your Maker API token, and it checks against the one already stored in your record. If you generated a new Maker API token at any point, the setup finishes on that device and never reaches the others, so you land right back where you started. Use the token you already had.
And if it still asks for a key after all that: Settings, Diagnostics, Run all checks, and send me the Cloud Sync line. It now tells the difference between "this device cannot read your settings" and "your saves are being rejected", which are different problems with different fixes. It was not saying that until today.
Hi ok i followed the steps got the secret key cleared the cached got the new home screen entered the secret key finished setup and still have it asking for household key and now have to re enter my devices again. the blank screen was my mistake on the entering the correct info but figured it out at the end.
That one is on me again, and it is the same bug I thought I had already fixed.
Entering your key worked. What went wrong is what happened next. Hestia read your settings, decrypted them correctly with your key, and then a separate check threw them away, because that check only recognised two things: "the hub this device already uses" and "a household you accepted on this device before". You had just cleared the cache, so both were gone. It decided your own settings were untrusted and offered you setup instead. Finishing that created a new household key, which is why your other devices still ask for one.
That check was written before household keys existed and was never taught about them, which is the actual defect. It is fixed in v2.1.4: if your settings open with your key, that is proof they are yours and they are applied. No wizard, nothing to confirm.
To get your other devices back without re-entering anything again, and you do not need the update for this part: open Hestia on the device where you finished setup, because that one holds the current key. Go to Settings → Wall Panel and copy the link, then open that link on each of the other devices. If that screen warns you the link carries no household key, stop there and tell me rather than going through setup again.
Reload hestari.com and the footer should read v2.1.4.
I am sorry you have had to rebuild this twice. You found two real bugs doing it, and both are fixed because you kept reporting them.
So I checked all my devices and they are all asking for the household keys not letting me use cloud all seem to work fine everything else in diagnostic is green and working just not cloud in all my devices. Should I start over? I'm on 2.1.4. All good with me helping to sort things out it will be worth it once the bugs are out.
So what you're saying is that your dashboards are all working appropriately and the diagnostics is flagging everything as green, except the cloud sync? Can you send me the diagnostics but make sure you don't include any of your IP or personal info please?
Thank you.
Hold off on starting over, and don't re-enter anything.
Your dashboards are fine and your settings are fine. What's wrong is one thing: the shared copy in the cloud is locked under a key none of your devices has anymore, which is why it's red on all of them at once rather than some working and some not.
Before I send you steps I want to see one line, because there are two different causes here and they need opposite fixes. On any device: Settings → Diagnostics → Run all checks, then send me the Cloud Sync line in full. The part I'm looking for is whether it ends with "The last save was also rejected".
If it does, this is about your Maker API token rather than the household key, and no amount of pasting keys will move it. I'd rather ask you for one line than send you through another rebuild on a guess.
This is what i get after a re check in diagnostic
Cloud Sync
Reachability of the hestari.com backend
Your settings are encrypted and this device does not have the key, so it cannot read them. Your hub has the key: open https://192.168.x.xx:8443/local/hestia-token.json on your network, take "appId" and "token" from it (NOT makerApiAppId or makerApiToken), and open /apps/api//config?access_token= — the 64-character value after "cloudSecret" is your key. Paste it into the recovery screen, or use Settings → Wall Panel on a device that still works. (If this address is shared with other homes, as on some ISPs, the record may genuinely belong to someone else.) The last save was also rejected: cloud rejected the write as unauthorized — the saved record for this connection was created with a different Maker API token. Use the token this household already had, in Settings → Hub & API.
This device needs your household key
I only get that when I use http://192.168.x.xx/local/index.html if I use https://hestari.com I get the household key error in orange.
Thinking on it a while back I might have re set the maker api access token when trying to resolve some of the connection issues not realizing how it affects the dashboard.
Same.
I see you added an area to paste the household key, I followed the procedure you asked to perform I did get my secret key then pasted it in the area in diagnostic and the results are This device already holds that key. Something not right. Hope this helps.
So now I'm getting the below message. If it has the old maker api token/key how do I get it to recognize the update maker api new token and key?
Use this key
This device already holds that key, and it does NOT open this network's saved settings. So the key is not the problem — the saved copy was written by something else, or it belongs to another home sharing your address. Run the checks above: Cloud Sync now says which.
Okay, please hold while I look into this.
The saved copy in the cloud is still matched to your previous Maker API token, and there's no way to re-point it at the new one from the dashboard side. Here's the quickest way around it, and it takes about two minutes.
That copy is filed under your home's public IP address. Reboot your router or modem so your ISP hands you a new one, then open Hestia. It'll find a clean slate, save your settings fresh, and every device in the house will land in the same place because they all share that address. Push re-registers itself the next time each device loads.
Nothing to re-enter, and don't start over in the meantime.
For what it's worth, this is a transition problem rather than something that's going to keep happening. 2.0.0 moved everyone onto encrypted settings with proper write authorisation, and you got caught in the window before the recovery routes for it were finished. From 2.2.0 onward a regenerated Maker API token is recoverable on its own, so new installs won't hit this, and neither will anyone who updates before it happens to them.
If your IP comes back the same after the reboot, let me know and I'll get you another route.
v2.2.0 is out, and it is a security release
Chasing the cloud sync problems two of you reported this week turned up something worse than the problem itself. So this release is mostly security, plus the fixes for what you actually hit.
Update both halves: re-paste HestiaDashboard.groovy, then open the app and click
Update Dashboard File. You do not need to click Done this time.
The one that matters
Hestia stores your settings in the cloud keyed by your public IP address. If your ISP puts you behind shared addressing, and many do, other households share that key with you.
Two endpoints had no authentication. One listed your sensors, including your smoke detectors. The other accepted events for them without checking who was sending. Smoke alerts deliberately skip the armed check, because a fire matters whether or not you armed the house.
Chained together, somebody sharing your address could make every phone in your house say "Smoke / CO Alert" at three in the morning, as often as they liked. They could also read when your doors opened, add their phone to your notifications, or delete your devices so your alarms stopped arriving.
All closed. No sign any of it was ever used, but it was possible.
What you reported
- Your household could re-key itself and lock you out. A device that could not reach the companion app invented its own household key, which happens routinely on hestari.com. Three guards now stop it, including one in the hub app that catches it even from older dashboards.
- You can enter a household key on a device that still works, in Settings → Diagnostics. It checks the key against your real record before saving it.
- Regenerating your Maker API token no longer locks you out forever.
- Diagnostics names the real cause now. Opening the dashboard from your hub's own address cannot reach the cloud, which used to show up as "hestari.com unreachable". It now tells you what is actually unavailable from that address, and what is unaffected: your hub keeps firing reminders, and push still reaches devices already registered.
One to watch for: if a write is rejected as unauthorised, alarm and arm/disarm notifications stop while door and window ones keep arriving. That looks like a working system and is not. Diagnostics now says so.
Changeover
Only a browser can register the new webhook, so the old form is still accepted until 2026-11-30 rather than cutting off households that rarely open the dashboard. Yours switches over by itself the first time you open it after updating. If you have updated and not opened it, open it once.
If you have had cloud sync trouble this past week
A few of you did, and it is worth saying plainly what it was.
v2.0.0 moved everyone onto encrypted settings with real write authorisation, which is what stops a neighbour reading your tokens and PINs. The cost of authorising writes is that it becomes possible to lose the thing that authorises you, and the routes back in were not all finished when that shipped. Two households got caught in that window.
This is a transition problem, not an ongoing one. From 2.2.0, a regenerated Maker API token recovers on its own, a device that cannot reach your hub no longer invents its own household key, and the hub itself refuses to let one device re-key the rest of the house. New installs will not hit any of it, and neither will anyone who updates before it happens to them.
The one case 2.2.0 cannot undo is a household already locked out before updating, because the new recovery route did not exist when that record was written. If that is you, say so in the thread and I will sort it out individually. Do not start over, and do not re-enter your devices.
Thanks to jbwrd3 and jkudave. Neither of you reported the smoke alarm issue, and neither of you would have found it either, but it only surfaced because you kept pushing on the thing that was actually bothering you.
Hi so you're saying I have to change my hubitat ip address? I have it set to static
@Haven All working beautifully now. Many thanks!!
A couple of quick tips for those using Hestia with camera streams on a Fire Tablet with Fully Kiosk Browser:
- In Fully Kiosk - Settings > Advanced Web Settings.
- Tap Mixed Content Mode and ensure it is strictly set to Always Allow Mixed Content.
- Trick the Android WebView into thinking the camera stream is coming from a registered web domain rather than a raw, local IP. Here is exactly how your camera stream URL/s should look in Hestia camera Settings:
- Your original URL:
http://192.168.x.x/snap.jpeg - Your new URL:
http://192.168.x.x.nip.io/snap.jpeg
Did you have to change your public ip?
