(@codahq) How different is the v1 from the v2? I have an unpublished v2 driver (read: not Gen5 but actually v2) and if they are close or the same I can publish it.
I presume quite different; I have a HEM v1 (oldest style, ZW095-A), and there is a HEM v5 which looks like mine, but is probably internally different. You have a HEM v2, which I don't believe would work with my v1.
(@SmartHomePrimer) I use this one with one of my v1 HEMs. I like it because I get separate clamp readings.
I have not had any problems with the driver, but I have moved one of my HEMs to a separate hub. I suspect they are related to the eventual slowdown issue. I’m planning to move both off my main hub at some point. Those are old Z-Wave 300 series, so they shouldn’t be expected not to cause any issues with newer Z-Wave Plus devices. At least, I’m not surprised by it.
So, you're saying the driver linked in that article is the one you use, and it works? I get errors clicking add children, delete children, and configure. Generally, it just doesn't do anything predictable until I install the broken jsconstantelos driver, and I get an error every 5-ish seconds (which is how often the device used to report to my ST).
Edit: Holy smokes, it works with SmartHomePrimer's recommended driver (slight modifications). I changed some settings, and pressed "Save Preferences", then "Configure".
The "Create Children" and "Delete Children" don't work, so I commented out lines 48 and 49. I was getting another error, so I also commented out lines 150-160. I now have individual clamp readings, and it reports every 30 seconds as configured; amazing! Thank you so much!
