I started it but got as far as I knew how. I have a fix that works for what I'M doing by using the WATO app here (at least check that out) as you can do things with the individual attributes from the main DH. I still think the best answer for this solution is two child devices that report like energy meters for each clamp. I think you should be able to do your reset using a custom command in RM. Haven't tried it,but that should work. Pretty sure between WATO and pushover you can do your reporting also.
the child one does NOT work...but I got the shell of creating the children. The other DH should work for what I said above. It does for me. Also, do read down below in the DH. At one point on ST I heavily documente what I could find about all the settings in the HEM1
