How can I kick off a "Stop Actions: Rule I want"
It is now called "Cancel Rule Timers" and is found under "Set Private Boolean/Run, Cancel, Pause Rules"
I believe so.
Release 2.1.3.125 Available
The same way you would trigger any other rule...through defining the trigger events and any conditions you want to check. it is the same as any other action.
