Got my new Smart Bridge Pro today, hooked it up, connected Lutron app and added a Pico. Now trying to add to Hubitat.
So in the Lutron Integrator app I select Create New Caseta/RA2 Integration. Then enter name and IP address (192.168.0.128 entered as DHCP reservation in my router). Add device, set up as follows. This is the only device I have added to the Smart Bridge, so should be #2 right?
Did you hit Done in the Lutron Integration app? If so, look at your Devices, and see if the Chris Pico is there. Also, that Lutron Telnet device exists.
Also, better to give your SmartBridge a static IP.
Yes I hit done, and yes I have both Chris Pico and Lutron Telnet devices. Should events be showing under either device, or live logs when I push buttons? I'm seeing nothing in Events or logs currently.
Watch the Lutron Telnet device for traffic, everything flows threw that. If you don't see any, then it isn't setup correctly. Open App and hit Done again.
Also, you can open a Telnet session to the SmartBridge pro separately from the hub. Credentials are username: luton, password: integration. That way you can see if the SmartBridge is working via telnet.
