Hey there, i have a Iris V3 Keypad setup as of yesterday. I have 3 codes setup in it. And was able to use it 1 time to open my garage door.
the problem though is that when you put in the code XXXX and then press off the garage opens. and from then on the "alarm" isn't armed again, so pressing XXXX off doesn't open the door.
is it possible to make this keypad work as a garage opener? if not do you have another keypad you recomend?
I suspect you could write a rule that would be triggered when it became disarmed and then issue the arm command a short time later. That way, any time you disarm it at the keypad it would be a change.
I played around with this idea for a bit using the Centralite driver on an Iris v2, and using [Release] Nyckelharpa, an HSM Extension. I have a relay to control my garage, so I just need to trigger it to open/close it depending on it's current state.
Using the combination of everything above, I had a rule to set the keypad to armed, and to trigger my relay when disarmed. It would then arm itself from the rule again.
I ultimately wound up abandoning the project though as there wasn't any way I saw to lock the keypad after X failed attempts. This means someone could come by, try out 20 codes, and repeat this until they eventually figured out a working code.
I don't know that I did. It was just a side affect of something I was working on and ran across that issue. I didn't really need it so probably didn't pursue it any further. I will look and see if I have anything.
You can issue a command keypad.armAway, or keypad.armNight, or keypad.disarm. I do this from my own app, but I'm pretty sure you can do this in RM also.
If so, you can run them in RM like this (note that having to choose a capability like Motion instead of Keypad confused me when I did this on my system):
i had it turn on a virtual switch, then arm itself 10 seconds later. then in a separate rule i was controlling what happened based on the virtual switch turning on.
definitely look into the extension though. i don't think by itself i was able to control the state, but when i added the extension [Release] Nyckelharpa, an HSM Extension i was able to control it and the codes worked as well. when i wasn't using it, the keypad would only return 0000
