@aryvin
Here is my smart App for Icomfort
* Lennox iComfort (Connect)
* Copyright 2015 Jason Mok
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Last Updated : 7/15/2015
definition(
name: "Lennox iComfort (Connect)",
namespace: "copy-ninja",
author: "Jason Mok",
description: "Connect Lennox iComfort to control your thermostats",
category: "SmartThings Labs",
iconUrl: "http://smartthings.copyninja.net/icons/iComfort@1x.png",
iconX2Url: "http://smartthings.copyninja.net/icons/iComfort@2x.png",
iconX3Url: "http://smartthings.copyninja.net/icons/iComfort@3x.png"
preferences {
page(name: "prefLogIn", title: "Lennox iComfort")
page(name: "prefListDevice", title: "Lennox iComfort")
/* Preferences */
def prefLogIn() {
def showUninstall = username != null && password != null
return dynamicPage(name: "prefLogIn", title: "Connect to Lennox iComfort", nextPage:"prefListDevice", uninstall:showUninstall, install: false) {
section("Login Credentials"){
input("username", "text", title: "Username", description: "iComfort Username (case sensitive)")
input("password", "password", title: "Password", description: "iComfort password (case sensitive)")
section("Advanced Options"){
input(name: "polling", title: "Server Polling (in Minutes)", type: "int", description: "in minutes", defaultValue: "5" )
//paragraph "This option enables author to troubleshoot if you have problem adding devices. It allows the app to send information exchanged with iComfort server to the author. DO NOT ENABLE unless you have contacted author at jason@copyninja.net"
//input(name:"troubleshoot", title: "Troubleshoot", type: "boolean")
def prefListDevice() {
LoginResult = loginCheck()
if (LoginResult)
def thermostatList = getThermostatList()
if (thermostatList) {
return dynamicPage(name: "prefListDevice", title: "Thermostats", install:true, uninstall:true) {
section("Select which thermostat/zones to use"){
input(name: "thermostat", type: "enum", required:false, multiple:true, options:[thermostatList])
} else {
return dynamicPage(name: "prefListDevice", title: "Error!", install:false, uninstall:true) {
section(""){ paragraph "Could not find any devices " }
} else {
section(""){ paragraph "The username or password you entered is incorrect. Try again. " }
/* Initialization */
def installed() { initialize() }
def updated() {
unsubscribe()
initialize()
def uninstalled() {
unschedule()
getAllChildDevices().each { deleteChildDevice(it.deviceNetworkId) }
def initialize() {
// Get initial polling state
state.polling = [ last: 0, rescheduler: now() ]
state.troubleshoot = null
// Create selected devices
def selectedDevices = [] + getSelectedDevices("thermostat")
selectedDevices.each { (getChildDevice(it))?:addChildDevice("copy-ninja", "Lennox iComfort Thermostat", it, null, ["name": "Lennox iComfort: " + thermostatList[it]]) }
// Remove unselected devices
def deleteDevices = (selectedDevices) ? (getChildDevices().findAll { !selectedDevices.contains(it.deviceNetworkId) }) : getAllChildDevices()
deleteDevices.each { deleteChildDevice(it.deviceNetworkId) }
//Subscribes to sunrise and sunset event to trigger refreshes
subscribe(location, "sunrise", runRefresh)
subscribe(location, "sunset", runRefresh)
subscribe(location, "mode", runRefresh)
subscribe(location, "sunriseTime", runRefresh)
subscribe(location, "sunsetTime", runRefresh)
//Refresh device
runRefresh()
def getSelectedDevices( settingsName ) {
(!settings.get(settingsName))?:((settings.get(settingsName)?.getAt(0)?.size() > 1) ? settings.get(settingsName)?.each { selectedDevices.add(it) } : selectedDevices.add(settings.get(settingsName)))
return selectedDevices
/* Access Management */
private loginCheck() {
def returnval = 0
apiPut("/DBAcessService.svc/ValidateUser", [query: [UserName: settings.username, lang_nbr: "1"]] ) { response ->
if (response.status == 200) {
if (response.data.msg_code == "SUCCESS")
returnval = 1
else
returnval = 0
} else {
returnval = 0
return returnval
// Listing all the thermostats you have in iComfort
private getThermostatList() {
def thermostatList = [:]
def gatewayList = [:]
state.data = [:]
state.lookup = [
thermostatOperatingState: [:],
thermostatFanMode: [:],
thermostatMode: [:],
program: [:],
coolingSetPointHigh: [:],
coolingSetPointLow: [:],
heatingSetPointHigh: [:],
heatingSetPointLow: [:],
differenceSetPoint: [:],
temperatureRangeF: [:]
state.list = [
temperatureRangeC: [],
program: [:]
//Get Thermostat Mode lookups
apiGet("/DBAcessService.svc/GetTstatLookupInfo", [query: [name: "Operation_Mode", langnumber: 0]]) { response ->
response.data.tStatlookupInfo.each {
state.lookup.thermostatMode.putAt(it.value.toString(), translateDesc(it.description))
//Get Fan Modes lookups
apiGet("/DBAcessService.svc/GetTstatLookupInfo", [query: [name: "Fan_Mode", langnumber: 0]]) { response ->
state.lookup.thermostatFanMode.putAt(it.value.toString(), translateDesc(it.description))
//Get System Status lookups
apiGet("/DBAcessService.svc/GetTstatLookupInfo", [query: [name: "System_Status", langnumber: 0]]) { response ->
state.lookup.thermostatOperatingState.putAt(it.value.toString(), translateDesc(it.description))
//Get Temperature lookups
apiGet("/DBAcessService.svc/GetTemperatureRange", [query: [highpoint: 40, lowpoint: 0]]) { response ->
response.data.each {
def temperatureLookup = it.Value.split("\\|")
state.lookup.temperatureRangeF.putAt(temperatureLookup[1].toString(), temperatureLookup[0].toString())
state.list.temperatureRangeC.add(temperatureLookup[0].toString())
//Retrieve all the gateways
apiGet("/DBAcessService.svc/GetSystemsInfo", [query: [userID: settings.username]]) { response ->
response.data.Systems.each { device ->
gatewayList.putAt(device.Gateway_SN,device.System_Name)
//Retrieve all the Zones
gatewayList.each { gatewaySN, gatewayName ->
apiGet("/DBAcessService.svc/GetTStatInfoList", [query: [GatewaySN: gatewaySN, TempUnit: (getTemperatureScale()=="F")?0:1, Cancel_Away: "-1"]]) { response ->
response.data.tStatInfo.each {
def dni = [ app.id, gatewaySN, it.Zone_Number ].join('|')
thermostatList[dni] = ( it.Zones_Installed > 1 )? gatewayName + ": " + it.Zone_Name : gatewayName
//Get the state of each device
state.data[dni] = [
temperature: it.Indoor_Temp,
humidity: it.Indoor_Humidity,
coolingSetpoint: it.Cool_Set_Point,
heatingSetpoint: it.Heat_Set_Point,
thermostatMode: lookupInfo( "thermostatMode", it.Operation_Mode.toString(), true ),
thermostatFanMode: lookupInfo( "thermostatFanMode", it.Fan_Mode.toString(), true ),
thermostatOperatingState: lookupInfo( "thermostatOperatingState", it.System_Status.toString(), true ),
thermostatProgramMode: it.Program_Schedule_Mode,
thermostatProgramSelection: it.Program_Schedule_Selection,
awayMode: it.Away_Mode.toString()
//Get Devices Program lookups
state.lookup.program.putAt(dni, [:])
state.list.program.putAt(dni, [])
apiGet("/DBAcessService.svc/GetTStatScheduleInfo", [query: [GatewaySN: gatewaySN]]) { response2 ->
if (response2.status == 200) {
response2.data.tStatScheduleInfo.each {
state.lookup.program[dni].putAt(it.Schedule_Number.toString(), "Program " + (it.Schedule_Number + 1) + ":\n" + it.Schedule_Name)
state.list.program[dni].add("Program " + (it.Schedule_Number + 1) + ":\n" + it.Schedule_Name)
//Get Devices Limit Lookups
apiGet("/DBAcessService.svc/GetGatewayInfo", [query: [GatewaySN: gatewaySN, TempUnit: "0"]]) { response2 ->
state.lookup.coolingSetPointHigh.putAt(dni, response2.data.Cool_Set_Point_High_Limit)
state.lookup.coolingSetPointLow.putAt(dni, response2.data.Cool_Set_Point_Low_Limit)
state.lookup.heatingSetPointHigh.putAt(dni, response2.data.Heat_Set_Point_High_Limit)
state.lookup.heatingSetPointLow.putAt(dni, response2.data.Heat_Set_Point_Low_Limit)
state.lookup.differenceSetPoint.putAt(dni, response2.data.Heat_Cool_Dead_Band)
return thermostatList
/* api connection */
// HTTP GET call
private apiGet(apiPath, apiParams = [], callback = {}) {
// set up parameters
apiParams = [ uri: getApiURL(), path: apiPath, headers: [Authorization : getApiAuth()] ] + apiParams
try {
httpGet(apiParams) { response -> callback(response) }
} catch (Error e) {
log.debug "API Error: $e"
// HTTP PUT call
private apiPut(apiPath, apiParams = [], callback = {}) {
// set up final parameters
apiParams = [ uri: getApiURL(), path: apiPath, headers: [Authorization: getApiAuth()] ] + apiParams
log.debug "apiParams: $apiParams"
try {
httpPut(apiParams) { response -> callback(response) }
} catch (Error e) {
// update child device data
private updateDeviceChildData(device) {
apiGet("/DBAcessService.svc/GetTStatInfoList", [query: [GatewaySN: getDeviceGatewaySN(device), TempUnit: (getTemperatureScale()=="F")?0:1, Cancel_Away: "-1"]]) { response ->
def dni = [ app.id, it.GatewaySN, it.Zone_Number ].join('|')
state.data[dni] = [
return true
// lookup value translation
def lookupInfo( lookupName, lookupValue, lookupMode ) {
if (lookupName == "thermostatFanMode") {
if (lookupMode) {
return state.lookup.thermostatFanMode.getAt(lookupValue.toString())
} else {
return state.lookup.thermostatFanMode.find{it.value==lookupValue.toString()}?.key
if (lookupName == "thermostatMode") {
if (lookupMode) {
return state.lookup.thermostatMode.getAt(lookupValue.toString())
} else {
return state.lookup.thermostatMode.find{it.value==lookupValue.toString()}?.key
if (lookupName == "thermostatOperatingState") {
if (lookupMode) {
return state.lookup.thermostatOperatingState.getAt(lookupValue.toString())
} else {
return state.lookup.thermostatOperatingState.find{it.value==lookupValue.toString()}?.key
/* for SmartDevice to call */
// Refresh data
def refresh() {
log.info "Refreshing data..."
// set polling states
state.polling?.last = now()
// update data for child devices
getAllChildDevices().each { (!updateDeviceChildData(it))?:it.updateThermostatData(state.data[it.deviceNetworkId.toString()]) }
//schedule the rescheduler to schedule refresh ;)
if ((state.polling?.rescheduler?:0) + 300000 < now()) { //BES - Changed to every 5 minutes.
log.info "Scheduling Auto Rescheduler.."
runEvery30Minutes(runRefresh)
state.polling?.rescheduler = now()
// Get Device Gateway SN
def getDeviceGatewaySN(childDevice) { return childDevice.deviceNetworkId.toString().split("\\|")[1] }
// Get Device Zone
def getDeviceZone(childDevice) { return childDevice.deviceNetworkId.toString().split("\\|")[2] }
// Get single device status
def getDeviceStatus(childDevice) { return state.data[childDevice.deviceNetworkId.toString()] }
// Send thermostat
def setThermostat(childDevice, thermostatData = []) {
thermostatData.each { key, value ->
if (key=="coolingSetpoint") { state.data[childDevice.deviceNetworkId].coolingSetpoint = value }
if (key=="heatingSetpoint") { state.data[childDevice.deviceNetworkId].heatingSetpoint = value }
if (key=="thermostatFanMode") { state.data[childDevice.deviceNetworkId].thermostatFanMode = value }
if (key=="thermostatMode") { state.data[childDevice.deviceNetworkId].thermostatMode = value }
def apiBody = [
Cool_Set_Point: state.data[childDevice.deviceNetworkId].coolingSetpoint,
Heat_Set_Point: state.data[childDevice.deviceNetworkId].heatingSetpoint,
Fan_Mode: lookupInfo("thermostatFanMode",state.data[childDevice.deviceNetworkId].thermostatFanMode.toString(),false),
Operation_Mode: lookupInfo("thermostatMode",state.data[childDevice.deviceNetworkId].thermostatMode.toString(),false),
Pref_Temp_Units: (getTemperatureScale()=="F")?0:1,
Zone_Number: getDeviceZone(childDevice),
GatewaySN: getDeviceGatewaySN(childDevice)
apiPut("/DBAcessService.svc/SetTStatInfo", [contentType: "application/x-www-form-urlencoded", requestContentType: "application/json; charset=utf-8", body: apiBody])
return state.data[childDevice.deviceNetworkId]
// Set program
def setProgram(childDevice, scheduleMode, scheduleSelection) {
def apiBody = []
def thermostatData = []
//Retrieve program info
state.data[childDevice.deviceNetworkId].thermostatProgramMode = scheduleMode
if (scheduleMode == "1") {
state.data[childDevice.deviceNetworkId].thermostatProgramSelection = scheduleSelection
apiGet("/DBAcessService.svc/GetProgramInfo", [query: [GatewaySN: getDeviceGatewaySN(childDevice), ScheduleNum: scheduleSelection, TempUnit: (getTemperatureScale()=="F")?0:1]]) { response ->
state.data[childDevice.deviceNetworkId].coolingSetpoint = response.data.Cool_Set_Point
state.data[childDevice.deviceNetworkId].heatingSetpoint = response.data.Heat_Set_Point
state.data[childDevice.deviceNetworkId].thermostatFanMode = lookupInfo("thermostatFanMode",response.data.Fan_Mode.toString(),true)
// set up final parameters for program
apiBody = [
Program_Schedule_Mode: scheduleMode,
Program_Schedule_Selection: scheduleSelection,
//Set Thermostat Program
apiPut("/DBAcessService.svc/SetProgramInfoNew", [contentType: "application/x-www-form-urlencoded", requestContentType: "application/json; charset=utf-8", body: apiBody]) { response ->
state.data[device.deviceNetworkId] = [
thermostatData = [
//Set Thermostat Values
return setThermostat(childDevice, thermostatData)
def translateDesc(value) {
switch (value) {
case "cool only" : return "cool"
case "heat only" : return "heat"
case "heat or cool" : return "auto"
default: return value
def getThermostatProgramName(childDevice, thermostatProgramSelection) {
def thermostatProgramSelectionName = state?.lookup?.program[childDevice.deviceNetworkId]?.getAt(thermostatProgramSelection.toString())
return thermostatProgramSelectionName?thermostatProgramSelectionName:"Unknown"
def getThermostatProgramNext(childDevice, value) {
def sizeProgramIndex = state.list.program[childDevice.deviceNetworkId].size() - 1
def currentProgramIndex = (state?.list?.program[childDevice.deviceNetworkId]?.findIndexOf { it == value })?state?.list?.program[childDevice.deviceNetworkId]?.findIndexOf { it == value } : 0
def nextProgramIndex = ((currentProgramIndex + 1) <= sizeProgramIndex)? (currentProgramIndex + 1) : 0
def nextProgramName = state?.list?.program[childDevice.deviceNetworkId]?.getAt(nextProgramIndex)
return state?.lookup?.program[childDevice.deviceNetworkId]?.find{it.value==nextProgramName}?.key
def getTemperatureNext(value, diffIndex) {
if (getTemperatureScale()=="F") {
return (value + diffIndex)
} else {
def currentTemperatureIndex = state?.list?.temperatureRangeC?.findIndexOf { it == value.toString() }.toInteger()
def nextTemperature = new BigDecimal(state?.list?.temperatureRangeC[currentTemperatureIndex + diffIndex])
return nextTemperature
def getSetPointLimit( childDevice, limitType ) {
if (getTemperatureScale() == "F") {
return state?.lookup?.getAt(limitType)?.getAt(childDevice.deviceNetworkId)
} else {
if (limitType == "differenceSetPoint") {
} else {
def limitTemperatureF = state?.lookup?.getAt(limitType)?.getAt(childDevice.deviceNetworkId)
def limitTemperatureC = new BigDecimal(state?.lookup?.temperatureRangeF?.getAt(limitTemperatureF.toInteger().toString()))
return limitTemperatureC
// Set Away Mode
def setAway(childDevice, awayStatus) {
def awayMode = ((awayStatus.toString().equals("away"))?"1":"0")
state.data[childDevice.deviceNetworkId].awayMode = awayMode.toString()
def apiQuery = [
awayMode: awayMode.toString(),
ZoneNumber: getDeviceZone(childDevice),
TempScale: (getTemperatureScale()=="F")?0:1,
apiPut("/DBAcessService.svc/SetAwayModeNew", [contentType: "application/json; charset=utf-8", requestContentType: "application/json; charset=utf-8", query: apiQuery]) { response ->
state.data[childDevice.deviceNetworkId] = [
//API URL
def getApiURL() {
def troubleshoot = "false"
if (settings.troubleshoot == "true") {
if (!(state.troubleshoot)) state.troubleshoot = now() + 3600000
troubleshoot = (state.troubleshoot > now()) ? "true" : "false"
if (troubleshoot == "true") {
return "https://services-myicomfort-com-xjor6gavxo3b.runscope.net"
} else {
return "https://services.myicomfort.com"
//API Authorization header
def getApiAuth() {
return "Basic " + (settings.username + ":" + settings.password).bytes.encodeBase64()
def runRefresh(evt) {
log.info "Last refresh was " + ((now() - (state.polling?.last?:0))/60000) + " minutes ago"
// Reschedule if didn't update for more than 5 minutes plus specified polling
if ((((state.polling?.last?:0) + (((settings.polling.toInteger() > 0 )? settings.polling.toInteger() : 1) * 60000) + 300000) < now()) && canSchedule()) {
log.info "Scheduling Auto Refresh.."
schedule("* */" + ((settings.polling.toInteger() > 0 )? settings.polling.toInteger() : 1) + " * * * ?", refresh)
// Force Refresh NOWWW!!!!
refresh()
//Update rescheduler's last run
if (!evt) state.polling?.rescheduler = now()
Here is my Device Driver:
* Lennox iComfort Thermostat
* Last updated : 7/15/2015
metadata {
definition (name: "Lennox iComfort Thermostat", namespace: "copy-ninja", author: "Jason Mok") {
capability "Thermostat"
capability "Relative Humidity Measurement"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Temperature Measurement"
capability "Actuator"
attribute "thermostatProgram", "string"
command "heatLevelUp"
command "heatLevelDown"
command "coolLevelUp"
command "coolLevelDown"
command "switchMode"
command "switchFanMode"
command "switchProgram"
command "setThermostatProgram"
command "away"
command "present"
command "setPresence"
command "updateThermostatData", ["string"]
simulator { }
tiles {
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("humidity", "device.humidity", inactiveLabel: false) {
state("humidity", label:'${currentValue}% \nHumidity' , unit: "Humidity",
backgroundColors:[
[value: 20, color: "#b2d3f9"],
[value: 30, color: "#99c5f8"],
[value: 35, color: "#7fb6f6"],
[value: 40, color: "#66a8f4"],
[value: 45, color: "#4c99f3"],
[value: 50, color: "#328bf1"],
[value: 55, color: "#197cef"],
[value: 60, color: "#006eee"],
[value: 70, color: "#0063d6"],
standardTile("thermostatOperatingState", "device.thermostatOperatingState", canChangeIcon: false, decoration: "flat") {
state("idle", icon: "st.thermostat.ac.air-conditioning", label: "Idle")
state("waiting", icon: "st.thermostat.ac.air-conditioning", label: "Waiting")
state("heating", icon: "st.thermostat.heating")
state("cooling", icon: "st.thermostat.cooling")
state("emergency heat", icon: "st.thermostat.emergency-heat")
standardTile("thermostatMode", "device.thermostatMode", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state("auto", action:"switchMode", nextState: "auto", icon: "st.thermostat.auto")
state("heat", action:"switchMode", nextState: "heat", icon: "st.thermostat.heat")
state("cool", action:"switchMode", nextState: "cool", icon: "st.thermostat.cool")
state("off", action:"switchMode", nextState: "off", icon: "st.thermostat.heating-cooling-off")
state("emergency heat", action:"switchMode", nextState: "emergency heat", icon: "st.thermostat.emergency-heat")
state("program", action:"switchMode", nextState: "program", icon: "st.thermostat.ac.air-conditioning", label: "Program")
standardTile("thermostatFanMode", "device.thermostatFanMode", canChangeIcon: false, inactiveLabel: false, decoration: "flat") {
state("auto", action:"switchFanMode", nextState: "auto", icon: "st.thermostat.fan-auto")
state("on", action:"switchFanMode", nextState: "on", icon: "st.thermostat.fan-on")
state("circulate", action:"switchFanMode", nextState: "circulate", icon: "st.thermostat.fan-circulate")
state("off", action:"switchFanMode", nextState: "off", icon: "st.thermostat.fan-off")
standardTile("heatLevelUp", "device.switch", canChangeIcon: false, inactiveLabel: true, decoration: "flat" ) {
state("heatLevelUp", action:"heatLevelUp", icon:"st.thermostat.thermostat-up", backgroundColor:"#F7C4BA")
valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false) {
state("heat", label:'${currentValue}°',
backgroundColors:[
[value: 40, color: "#f49b88"],
[value: 50, color: "#f28770"],
[value: 60, color: "#f07358"],
[value: 70, color: "#ee5f40"],
[value: 80, color: "#ec4b28"],
[value: 90, color: "#ea3811"]
standardTile("heatLevelDown", "device.switch", canChangeIcon: false, inactiveLabel: true, decoration: "flat") {
state("heatLevelDown", action:"heatLevelDown", icon:"st.thermostat.thermostat-down", backgroundColor:"#F7C4BA")
standardTile("coolLevelUp", "device.switch", canChangeIcon: false, inactiveLabel: true, decoration: "flat" ) {
state("coolLevelUp", action:"coolLevelUp", icon:"st.thermostat.thermostat-up" , backgroundColor:"#BAEDF7")
valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false) {
state("cool", label:'${currentValue}°',
backgroundColors:[
[value: 40, color: "#88e1f4"],
[value: 50, color: "#70dbf2"],
[value: 60, color: "#58d5f0"],
[value: 70, color: "#40cfee"],
[value: 80, color: "#28c9ec"],
[value: 90, color: "#11c3ea"]
standardTile("coolLevelDown", "device.switch", canChangeIcon: false, inactiveLabel: true, decoration: "flat") {
state("coolLevelDown", action:"coolLevelDown", icon:"st.thermostat.thermostat-down", backgroundColor:"#BAEDF7")
valueTile("thermostatProgram", "device.thermostatProgram", inactiveLabel: false, decoration: "flat") {
state("program", action:"switchProgram", label: '${currentValue}')
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state("default", action:"refresh.refresh", icon:"st.secondary.refresh")
standardTile("presence", "device.presence", inactiveLabel: false, decoration: "flat") {
state("present", label:"present", action:"switchPresenceMode", nextState: "present", icon: "st.Home.home2")
state("away", label:"away", action:"switchPresenceMode", nextState: "away", icon: "st.Transportation.transportation5")
main "temperature"
details(["temperature", "humidity", "thermostatOperatingState", "heatLevelUp", "coolLevelUp", "thermostatFanMode", "heatingSetpoint", "coolingSetpoint", "thermostatMode", "heatLevelDown", "coolLevelDown", "thermostatProgram", "presence", "refresh" ])
def parse(String description) { }
def refresh() { parent.refresh() }
def poll() { updateThermostatData(parent.getDeviceStatus(this.device)) }
def updateThermostatData(thermostatData) {
def ValChanged = false
def thermostatProgramMode = (device.currentValue("thermostatProgram") == "Manual")?"0":"1"
def thermostatMode = (device.currentState("thermostatMode")?.value)?device.currentState("thermostatMode")?.value:"auto"
log.debug "UpdateThermostatData: " + thermostatData
thermostatData.each { name, value ->
if (name == "temperature" || name == "coolingSetpoint" || name == "heatingSetpoint") {
sendEvent(name: name, value: value , unit: getTemperatureScale())
log.debug "Sending Event: " + [name, value, getTemperatureScale()]
} else if (name == "thermostatProgramMode") {
thermostatProgramMode = value
ValChanged = true
} else if (name == "thermostatProgramSelection") {
thermostatProgramSelection = value
ValChanged = true
} else if (name == "thermostatMode") {
ValChanged = true
} else if (name == "awayMode") {
if (value == "1") {
sendEvent(name: "presence", value: "away")
log.debug "Sending Event: " + ["presence", "away"]
} else {
sendEvent(name: "presence", value: "present")
log.debug "Sending Event: " + ["presence", "present"]
} else {
sendEvent(name: name, value: value, displayed: false)
log.debug "Sending Misc Event: " + [name, value]
if (true == ValChanged){
if (thermostatProgramMode == "0") {
sendEvent(name: "thermostatMode", value: thermostatMode)
sendEvent(name: "thermostatProgram", value: "Manual")
log.debug "Sending Event: " + ["thermostatMode", thermostatMode]
log.debug "Sending Event: " + ["thermostatProgram", "Manual"]
} else {
sendEvent(name: "thermostatMode", value: "program")
log.debug "Sending Event: " + ["thermostatMode", "program"]
if (thermostatProgramSelection) {
sendEvent(name: "thermostatProgram", value: parent.getThermostatProgramName(this.device, thermostatProgramSelection).toString().replaceAll("\r","").replaceAll("\n",""))
log.debug "Sending Event: " + ["thermostatProgram", parent.getThermostatProgramName(this.device, thermostatProgramSelection).replaceAll("\r","").replaceAll("\n","")]
def setHeatingSetpoint(Number heatingSetpoint) {
// define maximum & minimum for heating setpoint
def minHeat = parent.getSetPointLimit(this.device, "heatingSetPointLow")
def maxHeat = parent.getSetPointLimit(this.device, "heatingSetPointHigh")
def diffHeat = parent.getSetPointLimit(this.device, "differenceSetPoint").toInteger()
heatingSetpoint = (heatingSetpoint < minHeat)? minHeat : heatingSetpoint
heatingSetpoint = (heatingSetpoint > maxHeat)? maxHeat : heatingSetpoint
// check cooling setpoint
def heatSetpointDiff = parent.getTemperatureNext(heatingSetpoint, diffHeat)
def coolingSetpoint = device.currentValue("coolingSetpoint")
coolingSetpoint = (heatSetpointDiff > coolingSetpoint)? heatSetpointDiff : coolingSetpoint
setThermostatData([coolingSetpoint: coolingSetpoint, heatingSetpoint: heatingSetpoint])
def setCoolingSetpoint(Number coolingSetpoint) {
// define maximum & minimum for cooling setpoint
def minCool = parent.getSetPointLimit(this.device, "coolingSetPointLow")
def maxCool = parent.getSetPointLimit(this.device, "coolingSetPointHigh")
coolingSetpoint = (coolingSetpoint < minCool)? minCool : coolingSetpoint
coolingSetpoint = (coolingSetpoint > maxCool)? maxCool : coolingSetpoint
// check heating setpoint
def coolSetpointDiff = parent.getTemperatureNext(coolingSetpoint, (diffHeat * -1))
def heatingSetpoint = device.currentValue("heatingSetpoint")
heatingSetpoint = (coolSetpointDiff < heatingSetpoint)? coolSetpointDiff : heatingSetpoint
def switchMode() {
def currentMode = device.currentState("thermostatMode")?.value
switch (currentMode) {
case "off":
setThermostatMode("heat")
break
case "heat":
setThermostatMode("cool")
break
case "cool":
setThermostatMode("auto")
break
case "auto":
setThermostatMode("program")
break
case "program":
setThermostatMode("off")
break
default:
if(!currentMode) { setThermostatMode("auto") }
def off() { setThermostatMode("off") }
def heat() { setThermostatMode("heat") }
def emergencyHeat() { setThermostatMode("emergency heat") }
def cool() { setThermostatMode("cool") }
def auto() { setThermostatMode("auto") }
def switchFanMode() {
def currentFanMode = device.currentState("thermostatFanMode")?.value
switch (currentFanMode) {
case "auto":
setThermostatFanMode("on")
break
case "on":
setThermostatFanMode("off")
break
case "off":
setThermostatFanMode("circulate")
break
case "circulate":
setThermostatFanMode("auto")
break
default:
if(!currentFanMode) { setThermostatFanMode("auto") }
def setThermostatMode(mode) {
if (thermostatProgramMode != "0") {
parent.setProgram(this.device, "0", state.thermostatProgramSelection)
setThermostatData([ thermostatProgramMode: "0", thermostatMode: mode ])
} else {
setThermostatData([ thermostatMode: mode ])
def fanOff() { setThermostatFanMode("off")}
def fanOn() { setThermostatFanMode("on") }
def fanAuto() { setThermostatFanMode("auto") }
def fanCirculate() { setThermostatFanMode("circulate") }
def setThermostatFanMode(fanMode) { setThermostatData([ thermostatFanMode: fanMode ]) }
def heatLevelUp() {
setHeatingSetpoint(parent.getTemperatureNext(heatingSetpoint, 1))
def heatLevelDown() {
setHeatingSetpoint(parent.getTemperatureNext(heatingSetpoint, -1))
def coolLevelUp() {
setCoolingSetpoint(parent.getTemperatureNext(coolingSetpoint, 1))
def coolLevelDown() {
setCoolingSetpoint(parent.getTemperatureNext(coolingSetpoint, -1))
def switchProgram() {
def currentProgram = device.currentValue("thermostatProgram")
def nextProgramID = parent.getThermostatProgramNext(this.device, currentProgram)
setThermostatProgram(nextProgramID)
def setThermostatProgram(programID) {
updateThermostatData([thermostatProgramMode: "1", thermostatProgramSelection: programID])
def thermostatResult = parent.setProgram(this.device, "1", programID)
updateThermostatData(thermostatResult)
def setThermostatData(thermostatData) {
def thermostatResult = parent.setThermostat(this.device, thermostatData)
def away() { setPresence("away") }
def present() { setPresence("present") }
def switchPresenceMode() {
def currentPresenceMode = device.currentState("awayMode")?.value
switch (currentPresenceMode) {
case "present":
setPresence("away")
break
case "away":
break
default:
def setPresence(awayStatus) {
def awayMode = (awayStatus.toString().equals("away"))?1:0
updateThermostatData([awayMode: awayMode.toString()])
log.debug "Calling setAway:" + this.device + " " + awayStatus + " " + awayMode.toString()
def thermostatResult = parent.setAway(this.device, awayStatus)
