Used the Alexa Virtual Button code by @mikee385 to get a signal from my door to Alexa to HE.
Made the rule as seen above. The notification (red pulsing LED) comes on appropriately when the virtual button is pressed. But I am unable to get the notification to stop.
Separately - instead of the Virtual thing being a button, is there a way to make it a switch? I find "on/off" easier to wrap my head around than button presses.
Yea, i saw LEDEFFECTALL as the option to select in the instructions, but that doesn’t seem to be an option for me, not sure if I selected something wrong. I can’t get any notification if I select a child device, but on the parent, I can get the notification going despite no “LEDEffectAll” option.
I realize that's a fan switch (and I only have Blue 2-1s), but are those screenshots from the switch driver, or some other Inovelli tool? I don't see a way to recreate your screenshots from the Blue 2-1 driver, but I could be missing something obvious (wouldn't be first time!)
Since Jonathan's no longer active, I'm going to move away from his app so I'm exploring options... Thank you!
I use the notifications in several rules on my hubs, I have several RED Switches with the full Bar LED, and a few Fan/Switch combos with the two LEDs -- and I use them for notifications all the time -- I'm at work right now, but when I get home tonight, I'll see if I can post some screenshots of my rules. However my memory says I'm using the Red Fan/Light Inovelli driver as @SmartHomePrimer suggests, and I'm simply using start and stop notification commands.
Those are screenshots (just a fraction of what's there becuase you scroll, and scroll... ) from the Inovelli driver for the LZW36 (which is the Red series Z-Wave Fan/Light controller the OP has).
Interesting that the 2-1s don't have similar options like that... Or if they do, I haven't figured out how to surface them. But I'll keep playing around -- I'm still just in the very early stages of this exploration. Thanks again!
I was able to configure the notifications for my garage door contact sensor - however, the start notification is easy, but to get it to stop I used the "wait" until closed, and when closed "start notification" with the code for no LED - but now the light LED is always off instead of the usual faint blue level indicator.
ALSO - when I tried to set the indicator to the child switch it didn't work, so I did the LED indicator to the parent switch and it worked... BUT now the light no longer responds to voice commands (via Alexa)
As an example, here are a few of my notification rules that are working well.
I just converted all 13 of my LED Mini-Dashboard notifications to RM this evening, and although it's pretty tedious at first, it went quickly once I got into a groove. Clipboard is your friend! I'm enjoying some of the additional flexibility that RM offers above the Mini Dashboard app, so this move has been a win for me.
To reset/clear a notification, "ledEffectAll/One(# if One, 255,0,100,255)" works great.
This one uses all 7 leds, solid (no animation), green (~85), 5% level
Wish I could help. I checked all my rules, and I only use setIndicator.
I'll try to play around with a Blue 2in1 this weekend, i have a couple stashed away for a rainy day, and see if I can figure the notifications out. I vaguely recall struggling with it before.
Can anyone confirm if this is correct? - I tried changing the device type to the "Inovelli Fan/Light LZW36" device, which gave me more options in the "select custom command" area, but I think this is what broke my Alexa connection, when I turned it back to this (the default setting), now my Alexa can control the light again. Also I have the LZW36 driver installed, do I need a different one? It seems these Red Series Fan/Light Switches are no longer being made by Inovelli
So I think this part of my problem - I think the notification needs to be on the parent device, but when I have it set up this way... the default, the parent device doesn't show up in my list of "switches" to select from.
When I changed the device to the LZW36 Fan+Switch, it showed up with some options (although not "set indicator" nor "AllLED.."), but then it broke the connection to Alexa - We say "good night Alexa" to turn off the lights while in bed which is critical if it doesn't work.
