This provides detailed information on interacting with Hubitat (i.e., the actual API for the Hubitat box). Hubitat uses groovy for general purpose processing (logic) and the API to interact with the environment).
There are a few examples at:
Throughout the forums, there are numerous chances to view other persons code. Before using someone elses code, it is strongly recommended you contact the author for permission.
I am getting error message while trying to execute below code inside Hubitat->Apps Code->New Code section.
class Example {
static void main(String[] args) {
// Using a simple println statement to print output to the console
println('Hello World');
Error-> Cannot cast object 'org.codehaus.groovy.runtime.InvokerHelper$1@1463534' with class 'org.codehaus.groovy.runtime.InvokerHelper$1' to class 'com.hubitat.hub.executor.AppDelegatingScript' on line null
Sounds more like a Driver. Drivers 'abstract' the physical device into a series of 'capabilities' that are common among similar devices. Thus a ZWave Switch and a Zigbee Switch, are able to be controlled by... yep.. by Apps.
An App tells devices to turn on/off, for example, and that causes the Driver to send the correct Zwave or Zigbee commands to make it so.
Here's a prototype/template that I use when creating a new Driver from scratch. It can be pasted into Driver Code: New Driver and attached to a virtual device. It doesn't actually do anything, but it's got all the minimum code to compile and run.
Because it's a template/proto, it's got code in it you may end up discarding. You can find an App template, as well as this Driver code at:
* Import URL: https://raw.githubusercontent.com/HubitatCommunity/??/master/??-Driver.groovy"
* Copyright 2019 C Steele
* Licensed under the Apache License, Version 2.0 (the "License"); you may not
* use this file except in compliance with the License. You may obtain a copy
* of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
* License for the specific language governing permissions and limitations
* under the License.
public static String version() { return "v???" }
import groovy.transform.Field
metadata
definition(name: "JustA Driver", namespace: "yourname", author: "your Name", importUrl: "https://raw.githubusercontent.com/HubitatCommunity/??/master/??.groovy")
capability "Switch"
preferences
//standard logging options
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
updated
Doesn't do much other than call initialize().
def updated()
initialize()
unschedule()
if (debugOutput) runIn(1800,logsOff) //disable debug logs after 30 min
log.trace "Msg: updated ran"
generic driver stuff
installed
def installed()
initialize()
log.trace "Msg: installed ran"
initialize
Doesn't do anything.
def initialize()
log.trace "Msg: initialize ran"
parse
In a virtual world this should never be called.
def parse(String description)
log.trace "Msg: Description is $description"
on
Turns the device on.
def on()
// The server will update on/off status
log.trace "Msg: $device ON"
off
Turns the device off.
def off()
log.trace "Msg: $device OFF"
First: As csteele mentioned, there is a specific structure to an app and a driver... You can not run arbitrary code on the HE.
Second:
You are trying to define a class. Classes are not supported within user code on the HE.
If you are looking to pull data into HE, I would suggest looking at an existing app that does something similar... like maybe the Netatmo app... for ideas and inspiration...
But, as previously mentioned, get permission from the original author if you are going to copy...
I too am struggling with my first Hubitat app. I'm trying to create an app that will run every X minute (or hours) and check to see if it can reach a web site. If it fails some number of times, it will power cycle my cable modem. I'd like to define a static integer variable that I can use as a counter for the number of failures, so that, after, say, three failures it will power cycle the modem. But I seem to be getting an exception when the relevant method runs, specifically when it increments the counter.
This is a snippet of code (just for testing purposes, obviously not what the ultimate code will look like):
When you are writing code to run on the platform you are not writing a full class, you are writing a groovy script. As such you cannot have variables outside of methods and access them unless you tell the groovy compiler that they are there. You need to use the @Field annotation in that case.
So at the top of your App you would want this:
@Field int counter = 0
Granted, that will get rid of the errors, but not really do what you want it to do since it won't be saved between runs. In that case you should be using state.
I am planning to write my first Hubitat app , Can we write an app on Hubitat to send motion sensors data/logs/events on cloud?
Currently I have added Marker API app on Hubitat which gives me URL's to get device info.
At another end I have created one .net application which hits URL's(given by Marker API) on every 3 seconds to read current status/attribute of my sensors.
Basically I am expecting that, there could be an app on habitat side which will directly send data to cloud whenever sensors status/motion will get changed or triggered.
