I see this in the logs after pressing "Configure" button in the driver...it looks like it's running the default value reset as well?
dev:2292022-09-19 09:49:15.280 pm debugResetting fgk-01x parameters to SmartThings compatible defaults
dev:2292022-09-19 09:49:15.278 pm debugConfiguring Device...
Below is the untouched ST code. This was the driver the sensors were using on ST for the last 3-4 years with no issues right up to exclusion a few days ago. There is code in there which I mod'd to calibrate my sensors. Maybe there are some clues there on the nature of these sensors?
* Copyright 2014 Jean-Jacques GUILLEMAUD
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Fibaro Z-Wave FGK-101 Marketing Description is at :
* http://www.fibaro.com/en/the-fibaro-system/door-window-sensor
* Fibaro FGK-10x Operating Manual can be downloaded at :
* http://www.fibaro.com/files/instrukcje/eng/DoorWindowSensor%20FGK-101-107%20ENG_v21-v23.pdf
* The current version of this Handler is parameterized to force Device's wakeup :
* - on any open<->closed state change
* - in case of Tampering Alarm triggering
* - every 60mn (wakeUpIntervalSet(seconds:60*60), hard coded)
* - whenever Temperature delta change since last report is greater than 0.31°C (Parameter#12, hard coded)
* also :
* - Temperature is natively reported by sensor in Celsius (SensorMultilevelReport[scale:0]);
* convertion is needed for Fahrenheit display
* A few specificities of this device that are relevant to better understand some parts of this Handler :
* - it is a battery operated device, so Commands can only be sent to it whenever it wakes up
* - it is a multi-channel Device, and the multi-level temperature sensor reports only from EndPoint#2
* - specific configurable parameters are documented in the above Operating Manual
* - some of those parameters must be modified to activate the anti-Tampering Alarm
* - some of the "scaffolding" has been left in place as comments, since it may help other people to understand/modify this Handler
* - BEWARE : the optional DS18B20 sensor must be connected BEFORE the Device is activated (otherwise, reset the Device)
* - IMPORTANT : for debugging purpose, it is much better to change the wake-up period from the default 60mn to 1mn or so;
* but unless you force the early wake up of the sensor (forcing open/closed for instance), you will have to
* wait up to 60mn for the new value to become effective.
* Z-Wave Device Class: GENERIC_TYPE_SENSOR_BINARY / SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
* FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
* Command Classes supported according to Z-Wave Certificate ZC08-14070004 for FGK-101\US :
* Used in Handler :
* - 0x20 - 32 : BASIC V1
* 0x30 - 48 : SENSOR_BINARY !V1! V2
* - 0x31 - 49 : SENSOR_MULTILEVEL V1 !V2! V3 V4 V5
* - 0x56 - 86 : CRC_16_ENCAP V1
* 0x60 - 96 : MULTI_CHANNEL V3
* 0x70 - 112 : CONFIGURATION V1 !V2!
* 0x72 - 114 : MANUFACTURER_SPECIFIC V1 !V2!
* 0x80 - 128 : BATTERY V1
* 0x84 - 132 : WAKE_UP V1 !V2!
* 0x85 - 133 : ASSOCIATION V1 !V2!
* 0x86 - 134 : VERSION V1
* 0x98 - 152 : SECURITY V1 [only latest versions of FGK-101]
* 0x9C - 156 : SENSOR_ALARM V1
* NOT used in Handler :
* 0x2B - 43 : SCENE_ACTIVATION V1
* also found in FGK-101 Raw Description, in addition to Z-Wave Certificate for FGK-101\US [?!!] :
* + 0x7A - 122 : FIRMWARE_UPDATE_MD V1 V2
* + 0xEF - 239 : MARK V1
* List of Known Bugs / Oddities / Missing Features :
* - valueTitle does not show displayNames on mobile Dashboard/Things page;
* attempted workaround using : valueTile(){unit:'${displayName}') failed
* - valueTile behaves differently on mobile Dashboard (interpolated colors) from Simulator (step-wise colors)
* - using Preferences values instead of hard-coded values for some parameters would be nicer
metadata {
definition (name: "JJ's Fibaro FGK-101 Handler", namespace: "JJG2014", author: "Jean-Jacques GUILLEMAUD") {
capability "Contact Sensor"
capability "Battery"
capability "Configuration"
capability "Temperature Measurement"
capability "Sensor"
capability "Alarm"
command "reportNext", ["string"]
attribute "reportASAP", "number"
attribute "deviceTime", "number"
// FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
fingerprint deviceId: "0x2001", inClusters: "0x30, 0x60, 0x70, 0x72, 0x80, 0x84, 0x85, 0x9C" // should include "0x20, 0x31" too ?!!
simulator {
status "open": "command: 2001, payload: FF"
status "closed": "command: 2001, payload: 00"
def T_values=[10,14,14.9,15,17,17.9,18,19,19.9,20,22,22.9,23,24,44,44.9,45,46,100]
def float Ti
for (int i = 0; i <= T_values.size()-1; i += 1) {
Ti=T_values.get(i)
def theSensorValue = [(short)0, (short)0, (short)(Ti*100)/256, (short)(Ti*100)%256]
// status "temperature ${Ti}°C": zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2).encapsulate(zwave.sensorMultilevelV2.sensorMultilevelReport(scaledSensorValue: i, precision: 2, scale: 0, sensorType: 1, sensorValue: theSensorValue, size:4)).incomingMessage()
tiles {
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
// label:'${name}', label:'${currentValue}', unit:"XXX" work, but NOT label:'${device.name}', label:'${displayName}', unit:'${unit}', ...
state "temperature", label:'${currentValue}°\n', unit:"C", icon: "st.alarm.temperature.normal",
// redondant lines added to avoid color interpolation on Dashboard (a feature or a bug ?!)
backgroundColors:[ // ***on IDE Simulator*** // ***on iPad App***
[value: 14, color: "#0033ff"], // °C <=14 : dark blue // °C <=14 : dark blue
//[value: 14.1, color: "#00ccff"], <- decimal value IGNORED by the Tile !!!
//[value: 14.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated dark blue<-> light blue
[value: 15, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 17, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
//[value: 17.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated light blue<->blue-green
[value: 18, color: "#ccffcc"], // 15< °C <=19 : light blue // 18<=°C <=19 : blue-green
[value: 19, color: "#ccffcc"], // 15< °C <=19 : light blue // 19°C : blue-green
//[value: 19.5], // 19< °C <=21 : blue-green // 19< °C <20 : interpolated blue-green<->green
[value: 20, color: "#ccff00"], // 19< °C <=21 : blue-green // 20<=°C <=21 : green
[value: 22, color: "#ccff00"], // 21< °C <=23 : green // 22°C : green
//[value: 22.5], // 23< °C <=45 : orange // 22< °C <23 : interpolated green<-> orange
[value: 23, color: "#ffcc33"], // 23< °C <=45 : orange // 23<=°C <=44 : orange
[value: 43, color: "#ffcc33"], // 23< °C <=45 : orange // 44°C : orange
//[value: 43.5], // 45< °C : red // 44< °C <45 : interpolated orange <-> red
[value: 44, color: "#ff3300"] // 45< °C : red // 45<=°C : red
valueTile("temperatureF", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
state "temperature", label:'${currentValue}°\n', unit:"F", icon: "st.alarm.temperature.normal",
[value: 57, color: "#0033ff"], // °C <=14 : dark blue // °C <=14 : dark blue
[value: 59, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 63, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 64, color: "#ccffcc"], // 15< °C <=19 : light blue // 18<=°C <=19 : blue-green
[value: 66, color: "#ccffcc"], // 15< °C <=19 : light blue // 19°C : blue-green
[value: 68, color: "#ccff00"], // 19< °C <=21 : blue-green // 20<=°C <=21 : green
[value: 72, color: "#ccff00"], // 21< °C <=23 : green // 22°C : green
[value: 73, color: "#ffcc33"], // 23< °C <=45 : orange // 23<=°C <=44 : orange
[value: 109, color: "#ffcc33"], // 23< °C <=45 : orange // 44°C : orange
[value: 111, color: "#ff3300"] // 45< °C : red // 45<=°C : red
standardTile("contact", "device.contact") {
state "open", label: 'open'/* in English :'${name}' */, icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: 'closed'/* in English :'${linkText}' */, icon: "st.contact.contact.closed", backgroundColor: "#79b821"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'batt. @ ${currentValue}%' /*battery*/, unit:""
//Select temperatureF if Location temperature Scale is °F
main(["temperature"])
details(["temperature", "contact", "battery"])
//main(["temperatureF"])
//details(["temperatureF", "contact", "battery"])
// parse events into attributes
state.parseCount=state.parseCount+1
settings.debugLevel = 2 // set to 1 or 2 when experimenting
if (debugLevel>=1) {log.debug "--------------------------Parsing... ; state.parseCount: ${state.parseCount}--------------------------"}
if (debugLevel>=2) {log.debug "Parsing... '${description}'"}
def result = null
def cmd = zwave.parse(description, [0x20:1, 0x30:1, 0x31:2, 0x56:1, 0x60:3, 0x70:2, 0x72:2, 0x80:1, 0x84:2, 0x85:2, 0x9C:1])
if (cmd) {
result = zwaveEvent(cmd)
if (debugLevel>=1) {log.debug "Parsed ${cmd} to ${result.inspect()}"}
} else {
log.debug "Non-parsed event: ${description}"
return result
/* Duncan's original fix
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = [0x20:1, 0x30: 2, 0x31: 2, 0x60: 3, 0x70: 2, 0x72: 2, 0x84: 1, 0x9C: 1][cmd.commandClass as Integer] ?: 1
zwaveEvent(zwave.commandClass(cmd.commandClass, version)?.command(cmd.command)?.parse(cmd.data))
//SmartThings v2 Hub forces CRC16-encoded replies from FGK-101 Device (v1 Hub did not)
log.debug "CRC16.......... cmd : ${cmd}"
def versions = [0x20:1, 0x30: 1, 0x31: 2, 0x60: 3, 0x70: 2, 0x72: 2, 0x84: 2, 0x9C: 1]
// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
def version = versions[cmd.commandClass as Integer]
log.debug "commandClass : ${cmd.commandClass}"
log.debug "version : ${version}"
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
log.debug "ccObj : ${ccObj}"
log.debug "cmd.command : ${cmd.command}"
log.debug "cmd.data : ${cmd.data}"
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
if (!encapsulatedCommand) {
log.debug "Could not extract command from ${cmd}"
} else {
zwaveEvent(encapsulatedCommand)
// Devices that support the Security command class can send messages in an
// encrypted form; they arrive wrapped in a SecurityMessageEncapsulation
// command and must be unencapsulated
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x98: 1, 0x20: 1])
// can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
log.debug "encapsulatedCommand : ${encapsulatedCommand}"
return zwaveEvent(encapsulatedCommand)
def temperatureScaleFC(tempvalue) {
//FGK-101 is natively °C; convert to °F if selected in settings
def float tempFC = tempvalue
if (location.temperatureScale == "F") {
tempFC = tempvalue * 1.8 + 32
return tempFC
def wakeUpResponse(cmdBlock) {
//Initialization... (executed only once, when the Handler has been updated)
//All untouched parameters are supposed to be DEFAULT (as factory-set)
if (state.isInitialized == false) {
if (debugLevel>=2) {log.debug "state.isInitialized : ${state.isInitialized}"}
cmdBlock << zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId).format() // NB : may have to wait 60mn for that value to be refreshed !
cmdBlock << "delay 1200"
// NOTE : any asynchronous temperature query thru SensorMultilevelGet() does NOT reset the delta-Temp base value (managed by DS18B20 hardware)
// Adjust temperature report sensitivity for outside thermometers whose displayName starts with "*"
def byte tempQuantumSixteenth
if (device.displayName.substring(0,1).equals("*")) {
tempQuantumSixteenth = 16 /* 16/16=1°C = 1.8°F */
} else {
tempQuantumSixteenth = 5 /* 5/16=0.31°C = 0.56°F */
cmdBlock << zwave.configurationV2.configurationSet(parameterNumber: 12/*for FGK101*/, size: 1, configurationValue: [tempQuantumSixteenth]).format()
// inclusion of Device in Association#3 is needed to get delta-Temperature notification messages [cf Parameter#12 above]
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
// inclusion of Device in Association#2 is needed to enable SensorAlarmReport() Command [anti-Tampering protection]
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
// inclusion of Device in Association#4 is needed for backward compatibility with non Z-Wave+ controlers
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:4, nodeId:[zwaveHubNodeId]).format()
// inclusion of Device in Association#5 is needed for backward compatibility with non Z-Wave+ controlers
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:5, nodeId:[zwaveHubNodeId]).format()
state.isInitialized = true
//Regular Commands...
def long nowTime = new Date().getTime()
// Next line needed because "update()" does not seem to work anymore
state.batteryInterval = (long) (24*60-45)*60*1000 // 1 day
if (nowTime-state.lastReportBattery > state.batteryInterval) {
cmdBlock << zwave.batteryV1.batteryGet().format()
//next 2 lines redondant since any open/closed status change is asynchronously notified
//cmdBlock << zwave.basicV1.basicGet().format()
//cmdBlock << "delay 1200"
//next 2 lines redondant too : SensorBinaryReport(EndPoint: 1) == BasicReport
//cmdBlock << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 1, destinationEndPoint: 1, commandClass:0x30 /*Sensor Binary*/, command:2).format()
//cmdBlock << zwave.sensorAlarmV1.sensorAlarmGet().format()
//cmdBlock << zwave.multiChannelV3.multiChannelEndPointGet().format() // MultiChannelEndPointReport -> dynamic: false, endPoints: 2
//cmdBlock << zwave.multiChannelV3.multiChannelCapabilityGet(endPoint:1).format() // MultiChannelCapabilityReport -> commandClass: [48], dynamic: false, endPoint: 1, genericDeviceClass: 32, specificDeviceClass: 1
//cmdBlock << zwave.multiChannelV3.multiChannelCapabilityGet(endPoint:2).format() // MultiChannelCapabilityReport -> commandClass: [49], dynamic: false, endPoint: 2, genericDeviceClass: 33, specificDeviceClass: 1
//next Command should normally be needed only once, at configuration time, but because of a random SmartThings platform bug, the wakeUp period may be reset to 1mn !
//cmdBlock << zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId).format() // NB : may have to wait 30mn for that value to be refreshed !
cmdBlock << zwave.wakeUpV2.wakeUpIntervalGet().format() // NB : may have to wait 60mn for that value to be refreshed !
cmdBlock << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 2, destinationEndPoint: 2, commandClass:0x31/*Sensor Multilevel*/, command:4/*Get*/).format()
cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
cmdBlock << "delay 2000"
log.debug "wakeUpNoMoreInformation()"
log.debug "cmdBlock : ${cmdBlock}"
return cmdBlock
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd) {
// IMPORTANT NOTE : when the batteryLevel becomes too low, Device reports become erratic, all periodic wakeUpNotifications stop
// and consequently BATTERYLEVEL IS NOT UPDATED ANYMORE every 24 hours, continuing to display the last (and obsolete) reported value.
// Curiously, asynchronous sensorMultilevelReports continue to arrive, for some time, making the Device look (partially) "alive"
if (debugLevel>=2) {log.debug "wakeupv2.WakeUpNotification $cmd"}
def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: true, displayed: false)
def cmdBlock = []
cmdBlock=wakeUpResponse(cmdBlock)
return [event, response(cmdBlock)]
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd) {
// This section resets the displayed battery level to 1% when the battery level is obsolete by more than 48h.
if (nowTime-state.lastReportBattery > 3*state.batteryInterval) { // reset batteryLevel to 1% if no update for 48-72 hours
log.debug "obsolete (likely low) battery value : ${((nowTime-state.lastReportBattery)/3600000)} hours old"
sendEvent(name: "battery", displayed: true, isStateChange:true, unit: "%", value: 1, descriptionText: "${device.displayName} has a low battery")
state.lastReportBattery = nowTime
// Dirty temporary recovery fix for remote Devices which lost wakeUp capability but still get asynchromous SensorMultilevelReports
// Forcing with the magnet a close/open transition after replacing the battery should (in most cases...) restore wakeUps
//def cmdBlock = []
//cmdBlock=wakeUpResponse(cmdBlock)
//return [response(cmdBlock)]
//configure()
def float scaledSensorValue = cmd.scaledSensorValue
// Adjust measured temperature based on previous manual calibration; FGK-101 is natively °C
switch (device.name) {
case 'Z-Wave Door/Window Sensor' : //JJG
scaledSensorValue = scaledSensorValue + 0.7999
log.debug "Temp Adjust for : ${device.name}"
break;
case 'Z-Wave Door/Window Sensor 2' : //MLE
scaledSensorValue = scaledSensorValue + 0.6800
break;
case 'Z-Wave Door/Window Sensor 3' : //MPT
scaledSensorValue = scaledSensorValue + 0.4055
break;
case 'T002' : //NBN
scaledSensorValue = scaledSensorValue - 0.0758
break;
case 'T004' : //SCU
scaledSensorValue = scaledSensorValue + 0.0011
break;
case 'T007' : //FSU
scaledSensorValue = scaledSensorValue + 0.0025
break;
case 'T008' :
scaledSensorValue = scaledSensorValue - 0.0146
break;
case 'T009' :
scaledSensorValue = scaledSensorValue + 0.0383
break;
case 'T010' :
break;
case 'T011' :
scaledSensorValue = scaledSensorValue - 0.0889
break;
case 'T012' :
scaledSensorValue = scaledSensorValue - 0.0532
break;
case 'T013' :
break;
case 'T014' : //*ext*//
scaledSensorValue = scaledSensorValue - 0.0160
break;
//Round to nearest 1 decimal temperature value; convert to °F if needed
def float ftempSign = temperatureScaleFC(scaledSensorValue) < 0 ? -1 : +1
def float ftemp = ftempSign * ((((temperatureScaleFC(scaledSensorValue).abs()*100+5)/10).intValue()*1.0)/10)
log.debug "ftempSign : ${ftempSign}"
log.debug "ftemp : ${ftemp}"
state.maxEventInterval = (long) (4*60-10)*60*1000 // at least 1 Temperature Report event every 4 hours
log.debug "cmd.scaledSensorValue : ${cmd.scaledSensorValue}"
log.debug "correction : ${scaledSensorValue-cmd.scaledSensorValue}"
log.debug "device.displayName : ${device.displayName}"
log.debug "'Date().getTime()' : ${new Date().getTime()}"
log.debug "state.forcedWakeUp : ${state.forcedWakeUp}"
log.debug "state.maxEventInterval : ${state.maxEventInterval}"
log.debug "state.lastReportTime : ${state.lastReportTime}"
log.debug "nowTime : ${nowTime}"
log.debug "(nowTime-state.lastReportTime > state.maxEventInterval) : ${(nowTime-state.lastReportTime > state.maxEventInterval)}"
log.debug "state.lastReportedTemp: ${state.lastReportedTemp}"
def float tempQuantum
tempQuantum = temperatureScaleFC(0.9999)-temperatureScaleFC(0)
} else {
tempQuantum = temperatureScaleFC(0.2999)-temperatureScaleFC(0)
log.debug "((ftemp-state.lastReportedTemp).abs()>${tempQuantum}): ${(ftemp-state.lastReportedTemp).abs()>tempQuantum}"
if (((ftemp-state.lastReportedTemp).abs()>tempQuantum) || ((nowTime-state.lastReportTime) > state.maxEventInterval) || state.forcedWakeUp) {
def map = [ displayed: true, value: ftemp.toString(), isStateChange:true, linkText:"${device.displayName}" ]
switch (cmd.sensorType) {
case 1:
map.name = "temperature"
map.unit = cmd.scale == 1 ? "F" : "C"
//ignores Device's native temperature scale, ftemp already converted to °F if settings as such
map.unit = location.temperatureScale
log.debug "map.value : ${map.value}"
log.debug "map.unit : ${map.unit}"
break;
log.debug "temperature Command : ${map.inspect()}"
state.lastReportedTemp = ftemp
state.lastReportTime = nowTime
state.forcedWakeUp = false
// For Test purpose; redondant with reportNext() => state.forcedWakeUp=1
if (device.currentValue('reportASAP')==1) {sendEvent(name: "reportASAP", value: 0, isStateChange: true)}
return createEvent(map)
def sensorValueEvent(value) {
if (value) {
createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open")
} else {
createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed")
// BasicReport should never occur since all status change notifications are asynchronous via BasicSet
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
sensorValueEvent(cmd.value)
if (debugLevel>=2) {log.debug "basicv1.BasicReport $cmd.value"}
// To check that WakeUpInterval does not revert to 1mn instead of 1h
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalReport cmd) {
if (debugLevel>=2) {log.debug "WakeUpIntervalReport $cmd"}
if (cmd.seconds!=60*60) {
def result = createEvent(name:"WakeUpIntervalReport", descriptionText:"${device.displayName} had ${cmd.seconds} seconds wakeUp period", isStateChange:true, displayed:true, linkText:"${device.displayName}")
configure()
return result
def openClosed(cmd, cmdValue) {
def theState = cmdValue == 0 ? "closed" : "open"
if (debugLevel>=2) {log.debug "openClosed $cmd"}
// Use closed/open sensor notification to trigger push of updated Temperature value and immediate setting of updated device parameters
// Sometimes, Temperature forced refresh stops working : SensorMultilevelGet() Commands are stacked but not executed immediately;
// will restart after some time, and stacked Commands will be executed !
def event = createEvent(name:"contact", value:"${theState}", descriptionText:"${device.displayName} is ${theState}", isStateChange:true, displayed:true, linkText:"${device.displayName}")
state.forcedWakeUp = true
def cmdBlock = []
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
if (debugLevel>=2) {log.debug "basicv1.BasicSet $cmd"}
def cmdValue = cmd.value
return openClosed(cmd, cmdValue)
// SensorBinaryReport should never occur since all status change notifications are asynchronous via BasicSet
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
if (debugLevel>=2) {log.debug "sensorbinaryv1.SensorBinaryReport $cmd"}
def cmdValue = cmd.sensorValue
def zwaveEvent(physicalgraph.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
//def event = sensorValueEvent(cmd.sensorState)
if (debugLevel>=2) {log.debug "sensoralarmv1.SensorAlarmReport $cmd.sensorState"}
def event = createEvent(name:"alarm", descriptionText:"${device.displayName} is tampered with !", isStateChange:true, displayed:true, linkText:"${device.displayName}")
def cmdBlock = []
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
log.debug "batteryv1.BatteryReport ${cmd.batteryLevel}"
log.debug "state.lastReportBattery : ${state.lastReportBattery}"
log.debug "state.batteryInterval : ${state.batteryInterval}"
if ((nowTime-state.lastReportBattery > state.batteryInterval) || state.forcedWakeUp) {
def map = [ name: "battery", displayed: true, isStateChange:true, unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
log.debug "battery map : ${map}"
return [createEvent(map)]
def zwaveEvent(physicalgraph.zwave.commands.configurationv2.ConfigurationReport cmd) {
if (debugLevel>=2) {log.debug "ConfigurationReport - Parameter#${cmd.parameterNumber}: ${cmd.configurationValue}"}
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelEndPointReport cmd) {
if (debugLevel>=2) {log.debug "multichannelv3.MultiChannelCapabilityReport: ${cmd}"}
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
def zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd) {
if (debugLevel>=2) {log.debug "versionv1.VersionReport: ${cmd}"}
// MultiChannelCmdEncap and MultiInstanceCmdEncap are ways that devices can indicate that a message
// is coming from one of multiple subdevices or "endpoints" that would otherwise be indistinguishable
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 1, 0x31: 2]) // can specify command class versions here like in zwave.parse
if (debugLevel>=2) {log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")}
// Catch All command Handler in case of unexpected message
def zwaveEvent(physicalgraph.zwave.Command cmd) {
createEvent(descriptionText: "!!! $device.displayName: ${cmd}", displayed: false)
// When a Temperature Event got lost in transit, the Watchdog requests a forced report at next wake up
// The "reportNext()" alarm command is used to signal back from the Watchdog SmartApp to the sleepy Device Handler
def reportNext(commandMsg) {
log.debug "reportNext !"
log.debug "commandMsg : ${commandMsg}"
// Next line may be needed because "update()" does not seem to work reliably anymore
return []
// For Tests Purpose
// Executed each time the Handler is updated
def updated() {
log.debug "Updated !"
// All state.xxx attributes are Device-local, NOT Location-wide
state.isInitialized = false
state.lastReportedTemp = (float) -1000
state.lastReportTime = (long) 0
state.lastReportBattery = (long) 0
// Real-time clock of sensors (ceramic resonator) is up to 3% inaccurate
state.batteryInterval = (long) (24*60-45)*60*1000 // 1 Battery Report event every 24 hours, rounded up to the nearest hourly wakeup
state.maxEventInterval = (long) (4*60-10)*60*1000 // at least 1 Temperature Report event every 3:50 hours
state.parseCount=(int) 0
if (!(state.deviceID)) {state.deviceID = device.name}
log.debug "state.deviceID: ${state.deviceID}"
sendEvent(name: "reportASAP", value: 1, isStateChange: true)
log.debug "device.currentValue('reportASAP') : ${device.currentValue('reportASAP')}"
infos()
// If you add the Configuration capability to your device type, this command will be called right
// after the device joins to set device-specific configuration commands.
def configure() {
log.debug "Configuring..."
log.debug "device.displayName.substring(0,1) : ${device.displayName.substring(0,1)}"
} else {
log.debug "tempQuantumSixteenth : ${tempQuantumSixteenth}"
delayBetween([
// Make sure sleepy battery-powered sensors send their WakeUpNotifications to the hub
zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId).format(),
zwave.configurationV2.configurationSet(parameterNumber: 12/*for FGK101*/, size: 1, configurationValue: [tempQuantumSixteenth]).format(),
zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format(),
// get zwave version information
zwave.versionV1.versionGet().format()
],1200)
def infos() {
if (!state.devices) { state.devices = [:] }
log.debug "zwaveHubNodeId: ${zwaveHubNodeId}" // -> "1"
log.debug "device.displayName: ${device.displayName}" // -> "JJG"
log.debug "device.id: ${device.id}" // -> "75841488-ae76-4cac-b523-a2694e72c25a"
log.debug "device.name: ${device.name}" // -> "T001"
log.debug "device.label: ${device.label}" // -> "JJG"
log.debug "device.data: ${device.data}" // -> "[endpointId:0, version: 2.1, MSR:010F-0700-2000]"
//log.debug "'device.rawDescription': ${device.rawDescription}" // -> "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
