Using the code you had provided above, it is providing parameters, but for whatever reason, it's not updating temps anymore. Did the hot water thing, wakeup/config etc.
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:12.610 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:12.569 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:12.567 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:12.068 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:12.067 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:11.566 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:11.565 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:11.064 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:11.063 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:10.581 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:10.580 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:10.113 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:10.113 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:09.645 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:09.644 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:09.058 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:09.057 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:08.567 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:08.566 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '3' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:08.059 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:08.057 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:07.556 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 01 02 00 00 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:07.555 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '1' with a byte size of '2' is set to '[0, 0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:07.512 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:07.504 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:07.503 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:07.301 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:07.194 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:06.661 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:06.626 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:06:04.259 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@1d122ed]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:05:02.474 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@11bb00a]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:04:00.707 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@c919d2]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:02:59.093 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@15af9f0]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:01:57.396 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@6ff36f]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 03:00:57.178 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@13d4f83]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:59:53.070 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: FF , isMulticast: false' to [['name':'contact', 'value':'open', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:59:53.057 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: FF , isMulticast: false' to [['value':'open', 'name':'contact', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:59:51.293 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: 00 , isMulticast: false' to [['name':'contact', 'value':'closed', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:59:51.278 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: 00 , isMulticast: false' to [['value':'closed', 'name':'contact', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:59:16.620 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@3604a7]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:22.378 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:22.337 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:22.336 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:21.835 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:21.834 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:21.334 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:21.333 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:20.834 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:20.833 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:20.333 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:20.332 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:19.830 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:19.829 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:19.330 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:19.329 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:18.828 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:18.827 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:18.327 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:18.326 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '3' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.826 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.825 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.719 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.688 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 01 02 00 00 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.687 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '1' with a byte size of '2' is set to '[0, 0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.660 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.658 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.629 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.628 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.600 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.599 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.571 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.570 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.541 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.540 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.512 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.511 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.482 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.480 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.467 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.450 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.421 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.420 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.391 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.390 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.362 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.361 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.333 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.332 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '3' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.302 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.301 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.281 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.272 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.271 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.271 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.270 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.242 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.241 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.212 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 01 02 00 00 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.211 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '1' with a byte size of '2' is set to '[0, 0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.181 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:17.180 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:16.844 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:16.843 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:15.855 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:15.854 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:15.186 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:15.153 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:15.151 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:15.093 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:11.804 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:11.795 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:11.794 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:08.818 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:08.800 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:58:08.799 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:57:40.681 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@1068805]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:56:39.033 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@5dff03]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:37.467 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: FF , isMulticast: false' to [['name':'contact', 'value':'open', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:37.453 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: FF , isMulticast: false' to [['value':'open', 'name':'contact', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:37.378 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: 00 , isMulticast: false' to [['name':'contact', 'value':'closed', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:37.364 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: 00 , isMulticast: false' to [['value':'closed', 'name':'contact', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:36.995 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: FF , isMulticast: false' to [['name':'contact', 'value':'open', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:36.892 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: FF , isMulticast: false' to [['value':'open', 'name':'contact', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:34.250 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: 00 , isMulticast: false' to [['name':'contact', 'value':'closed', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:34.235 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: 00 , isMulticast: false' to [['value':'closed', 'name':'contact', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:33.628 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: FF , isMulticast: false' to [['name':'contact', 'value':'open', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:33.614 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: FF , isMulticast: false' to [['value':'open', 'name':'contact', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:30.998 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: 00 , isMulticast: false' to [['name':'contact', 'value':'closed', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:30.984 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: 00 , isMulticast: false' to [['value':'closed', 'name':'contact', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:30.883 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: FF , isMulticast: false' to [['name':'contact', 'value':'open', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:30.868 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: FF , isMulticast: false' to [['value':'open', 'name':'contact', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:30.184 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: 00 , isMulticast: false' to [['name':'contact', 'value':'closed', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:30.169 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: 00 , isMulticast: false' to [['value':'closed', 'name':'contact', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:16.382 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:16.336 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:16.333 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:15.878 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:15.877 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:15.327 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:15.326 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.827 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.826 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.326 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.325 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.080 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.050 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.049 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.020 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:14.019 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.991 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.990 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.962 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.961 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '3' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.931 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.930 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.902 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 01 02 00 00 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.901 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '1' with a byte size of '2' is set to '[0, 0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.873 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.871 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.844 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.843 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.814 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.813 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.786 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:13.785 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:11.275 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:11.265 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:11.265 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:11.020 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:55:10.914 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.986 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.985 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.800 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.612 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.611 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '3' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.426 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.425 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.245 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:57.241 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:56.831 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 01 02 00 00 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:56.830 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '1' with a byte size of '2' is set to '[0, 0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:56.443 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:56.442 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:56.234 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:56.225 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:56.224 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:55.752 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:55.599 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:55.492 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:55.446 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:55.445 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:55.269 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:55.182 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:54.944 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:54.943 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:54.492 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:54.492 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:53.942 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:53.941 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:53.440 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:53.439 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:52.939 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:52.938 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:52.453 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:52.452 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '3' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.937 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.936 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.440 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 01 02 00 00 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.438 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '1' with a byte size of '2' is set to '[0, 0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.392 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.382 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.381 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:51.106 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:50.962 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:54:34.364 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@77b30f]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:32.674 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: FF , isMulticast: false' to [['name':'contact', 'value':'open', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:32.660 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: FF , isMulticast: false' to [['value':'open', 'name':'contact', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:32.030 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: 00 , isMulticast: false' to [['name':'contact', 'value':'closed', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:32.015 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: 00 , isMulticast: false' to [['value':'closed', 'name':'contact', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:29.445 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: FF , isMulticast: false' to [['name':'contact', 'value':'open', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:29.431 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: FF , isMulticast: false' to [['value':'open', 'name':'contact', 'descriptionText':fgk-01x is open]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:29.023 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 2001, payload: 00 , isMulticast: false' to [['name':'contact', 'value':'closed', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:53:28.879 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 3003, payload: 00 , isMulticast: false' to [['value':'closed', 'name':'contact', 'descriptionText':fgk-01x is closed]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:52:40.889 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8407, payload: , isMulticast: false' to [['descriptionText':fgk-01x woke up, 'isStateChange':false], hubitat.device.HubMultiAction@8a7b8c]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:45.270 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:45.219 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:45.217 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:44.716 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:44.715 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:44.216 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:44.215 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:43.713 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:43.712 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:43.212 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:43.211 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:42.710 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:42.709 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:42.211 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:42.210 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:41.717 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:41.716 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:41.206 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:41.205 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '3' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:40.708 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 02 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:40.707 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '2' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:40.349 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 01 02 00 00 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:40.348 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '1' with a byte size of '2' is set to '[0, 0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:40.153 pm [debug](http://192.168.0.50/device/edit/229)Listing of current parameter settings of fgk-01x
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:40.131 pm [debug](http://192.168.0.50/device/edit/229)Resetting fgk-01x parameters to SmartThings compatible defaults
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:40.130 pm [debug](http://192.168.0.50/device/edit/229)Configuring Device...
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:39.581 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 FF 00 00 , isMulticast: false' to [['value':'tampered', 'name':'tamper', 'descriptionText':fgk-01x has been tampered with]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:39.409 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 9C02, payload: 14 00 00 00 00 , isMulticast: false' to [['value':'secure', 'name':'tamper', 'descriptionText':fgk-01x is secure]]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:34.265 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 8003, payload: FF , isMulticast: false' to [['name':'battery', 'unit':'%', 'value':1, 'descriptionText':fgk-01x has a low battery, 'isStateChange':true], 8408]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:34.219 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0F 01 00 , isMulticast: false' to [8002]
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:34.213 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '15' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:33.712 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0E 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:33.712 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '14' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:33.212 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0D 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:33.211 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '13' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:32.714 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0C 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:32.713 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '12' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:32.209 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 0A 01 01 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:32.207 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '10' with a byte size of '1' is set to '[1]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:31.705 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 09 01 00 , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:31.705 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '9' with a byte size of '1' is set to '[0]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:31.205 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 07 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:31.204 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '7' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:30.840 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 05 01 FF , isMulticast: false' to []
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:30.839 pm [debug](http://192.168.0.50/device/edit/229)fgk-01x parameter '5' with a byte size of '1' is set to '[255]'
[dev:229](http://192.168.0.50/logs?device=229#pastdev229)2022-09-20 02:51:30.810 pm [debug](http://192.168.0.50/device/edit/229)parsed 'zw device: 14, command: 7006, payload: 03 01 00 , isMulticast: false' to []
