OK! I am clueless & not sure what is causing this & I give up, thought I'd ask the community if anyone has had this issue. Everything was working absolutely fine. One fine morning all my devices stopped working with the HUB. They all started showing OFFLINE on My Home app on my Android phone.
I tried rebooting the Hub which I thought will fix it but it did not. So I downloaded 'a known good working' backup copy. Then I did a soft reset on the hub & restored it from the back & still nothing seems to be working.
I removed everything & did a soft reset & started fresh by factory resetting my zigbee switches & add them back to the hub. I can successfully discover them & add them & they work momentarily. After a few minutes, they stop working.
This switch is close to the HUB in the Study.
I tried this on several other devices & same result it drops off after few minutes. I tried it with one of the Motion sensor as well & same result.
I do have 3 Wi-Fi Access points, I have used WI-FI Analyser & it shows these 3 are running on Channel 1-6-11, I have changed channel on the hub from 14 till 25 & I still have the same issue. I have even reset the radio for Zigbee. Nothing seems to be helping. My neighbour's wifi and all other discoverable SSIDs are on between 1-13 channels.
My house is a 2 Storey house with 4 bedrooms to cater with a single Hub. approx. 300sq mts.
I have all Zigbee devices
- Hubitat Rev C-5 with Platform version hub-2.3.2.134
- Roughly 5-7 Nue smart switches (mix of 1 2 & 4 gang)
- Couple of Ikea Tradfri globes
- Couple of Nue Contact sensor
- Couple of Motion Sensors
Other than the above Zigbee devices, i have Eufy doorebell , Couple of Google home mini/screen devices. All connected to Wi-fi Access points.
Am I missing something?
Is there someone who had this issue?
Is there something I can look further that can help me fix this issue?
Is it time to get rid of Hubitat?
Any Help is highly appreciated
