Heiman Zigbee Gas Detector Help
Since these were listed as supported, I bought two. This may be some new rev, but it's the ones selling right now. Every time I've tried to add them the driver comes up as "device,"
Not the built-in driver.
When I load the version in the package manager, Homi/Heiman Gas Detector lgkahn Configuration, SmokeDetector, Refresh, GasDetector, Sensor Storage Gas Leak Detector
Same when I load the built in driver.
It seems to work.
Current States
  • enrollment : Enrolled
  • lastUpdate : 12/11/2024 10:14 AM
  • manufacture : HEIMAN
  • model : GASSensor-EF-3.0
  • naturalGas : clear
  • smoke : clear
  • zoneType : Gas Sensor
Data
  • endpointId: 01
  • application: 10
  • firmwareMT: 120B-0086-00000010
  • inClusters: 0000,0003,0500,0502,0B05
  • manufacturer: HEIMAN
  • model: GASSensor-EF-3.0
  • outClusters: 0019
  • softwareBuild: 00000010
However at some point while working on these ONE time, ONE of them showed entries under State Variables. I've yet to test them since it's a bit of a pain to do so, but just curious about...
1) Why the default driver doesn't work
2) If they are connected correctly should I have entries under "State Variables."
Thanks!
Quick Update:
I just tested this with a gas stove. While it alarms, the only log message I get is the following through the whole process.
dev:6422024-12-11 10:57:31.459 AMinfoKitchen Gas Leak Detector gas is clear
dev:6422024-12-11 10:56:13.958 AMinfoKitchen Gas Leak Detector gas is clear
dev:6422024-12-11 10:55:56.128 AMinfoKitchen Gas Leak Detector gas is clear
It NEVER actually shows anything but "clear"...but it does trigger that message.
After assigning and saving a driver, have you tried clicking the “configure” button on the device page?
Yes. Several times.
Should I see State Variables?
Side comment...
I'm also not sure about this long term. Testing them for leak response over a gas burner it's takes quite a bit to trigger and seems like the gas needs to be extremely concentrated. I mean to the level the house would probably blow with an arc from a light switch turning on.
Much less you'd be unconscious anyway.
That said, this is hard to test. I had to hold it right over the "off" burner to get any results. In the real world...lower levels over time "might" trigger too.
I'm not a big fan of "might" when it comes to safety.
I use the built in heiman driver. That said, post the fingerprint and tag @mike.maxwell and he can add it to the hub.
I'm not sure if it's proper to post here...or to him directly...but thanks. Will start here.
I've never done this and sort of expected more info.
dev:6432024-12-12 11:26:06.926 AMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0500,0502,0B05", outClusters:"0019", model:"GASSensor-EF-3.0", manufacturer:"HEIMAN", controllerType: "ZGB"
dev:6432024-12-12 11:26:06.839 AMtraceZCL version:03
dev:6432024-12-12 11:26:06.837 AMtraceSoftware Build Id:unknown
dev:6432024-12-12 11:26:06.836 AMtraceModel:GASSensor-EF-3.0
dev:6432024-12-12 11:26:06.834 AMtraceManufacturer:HEIMAN
dev:6432024-12-12 11:26:06.739 AMdebuggetting info for unknown Zigbee device...
Not sure if it will help but post the info from the device page again too.
Current States
  • lastUpdate : 12/12/2024 11:09 AM
  • smoke : clear
  • endpointId: 01
  • application: 10
  • outClusters: 0019
  • softwareBuild:
@mike.maxwell can you add the above fingerprint?
the new fingerprint has been added to the existing Heiman Zigbee Gas Detector driver, it will be in the next 2.4.0 beta release
That's truly awesome THANKS Mike!
Hello
I have an old Heiman Natural Gas detector that is connected and set up correctly, however a new one I just received is showing up as "device" after being discovered during Zigbee paring even though I manually selected the type as Heiman Zigbee Gas Detector.
Here is the info I think @mike.maxwell may need to add it in the next update.
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0500,0B05", outClusters:"0019", model:"TS0204", manufacturer:"_TYZB01_0w3d5uw3", controllerType: "ZGB"
ZCL version:03
Model:TS0204
Manufacturer:_TYZB01_0w3d5uw3
Let me know if you need something else or if perhaps I may have done something wrong.
I've also just bought some Heiman Natural Gas detectors with the above fingerprint details. Please add support for this device.
The device is supported, in the sense that it should work with the hub when the right driver is assigned, although the pairing fingerprint info does need to be added to the driver code to make things as seamless as possible for the user.
Are you able to use the device as expected after reassigning the driver manually?
To add to what @marktheknife said, after changing the driver and clicking save, please click configure.
I got it working but it took some guesswork. But just like @marktheknife and @rlithgow1 said, the correct steps after joining is:
  1. Manually select correct driver
  2. Click Configure
I guess I want the driver updated because then maybe we won't need post-join manual steps. Now to figure out how to use HSM.
Just remember HSM is nothing special, it's simply a subset of rule machine. So if you don't feel like using it that's fine. Also if it helps, I have an auto shut off on my main gas line that trips if the gas sensor goes off.
I have some of the Heiman sensors...one is about 6 ft above my gas range. I have opened the valve with no flame a few times...the sensor has never tripped.
Has anybody here done any functionality testing with these?
Is it natural gas or lp. One rises , one sinks.
as kahn-hubitat stated, natural gas will rise so sensors need to be high to be detected, propane gas falls and sensors must be low to be detected.
So not sure what gas this detector can detect, but if it's for both, you will need 2 of them to make sure it detects both gases (if you have both gases in your home of course).
I believe it does both as i know it does nat. Gas and i tested with a bic lighter which is propane.
Natural
So maybe the concentration was just not high enough to trigger the sensor, even if the smell is strong, does not mean the concentration is high.
