Haiku Fan (Big Ass Fans) support
@freedom there's a bounty out there for you if you put the driver on the Hubitat Package manager:
I'm having issues with the driver discovering my 4 Haiku fans. I got the driver code installed, created a virtual device with the Haiku driver, put in the proper IPs (from my Eero app), and device name. I saved the preferences, but I don't see any activity from the driver and 'current states' is blank. Am I missing a step?
Not sure if this will help. I had to use the fan's mac address in place of the IP address for this to work.
@zackrbrown may be a dumb question, but is there a way to get commands sent through the Haiku app or remote to be recognized by HE? For example, if I want to use Node Red to make something happen when my Haiku light turns on from the remote or app.
You could use a rule to periodically refresh the device, which would update the fan speed. I just checked and the status doesn't seem to update without a refresh.
It's definitely something I want it it do, but as far as I can tell HE really doesn't like TCP/UDP listen servers. If I could figure that out, I know that it would be possible to respond to commands from the phone app, but I'm not sure how the wall switch or remote send commands.
Take a look at the Samsung tv integration I think it's doing something like that.
Thanks for releasing this Zack. I've been using it with my Haiku fan with light and it works great through Hubitat.
I've been having some trouble integrating it with Homebridge using "Homebridge v2" from homebridge-hubitat-tonesto7. At first I added one driver to Hubitat and assigned it to Homebridge as a light. That works. Then I tried to assign the same driver to Homebridge as a fan. This doesn't work, as Homebridge doesn't allow duplicate drivers for different tasks. No worries, I added a second Haiku driver connecting to the same fan and added that to Homebridge as a fan. This is assigned to Homebridge successfully, and turns up in the Apple Home app as a fan, however it still only turns the light.
Does anyone have any thoughts on what to try next? My feeling is that the Haiku driver may need to be split up into a parent driver with 2 child drivers for fan and light. This should allow Homebridge to work correctly. I may have a go at doing that if there's no better suggestions.
The issues I was having was largely a Homebridge-Hubitat issue which I've resolved. I did need to make some changes to this Haiku driver however. Light capability has been added, and level control is now a percentage rather than 0-16.
Pull request has been sent. Changes are here: GitHub - dineshpannu/hubitat-haiku-driver: A Hubitat Elevate driver for Haiku fans
Thanks to Gradenko for the contribution!
NOTE: The current version of the driver on Github now sets the light level according to percentage (0-100) rather than 0-16. You may need update your routines when grabbing this new version.
Glad to help!
Would it be possible to add the importUrl: parameter to the driver to make it easier to update? Maybe add some version info too? Thanks!
A few years ago, I performed packet capture to get the following commands so I could add them to the SmartThings Device Handler.
I'm brand new to Hubitat and haven't figured out how to add this to a Hubitat Driver Code - can anyone make sense of how to import the following into this Hubitat Driver?
I would love to make Sleep: ON as part of my night routine.
def sleepon() {
sendEvent(name: "sleep", value: 'sleepon')
request("<" + devname + ";SLEEP;STATE;ON>")
def sleepoff() {
sendEvent(name: "sleepoff", value: 'sleepoff')
request("<" + devname + ";SLEEP;STATE;OFF>")
def whooshon() {
sendEvent(name: "whoosh", value: 'whooshon')
request("<" + devname + ";FAN;WHOOSH;ON>")
def whooshoff() {
sendEvent(name: "whoosh", value: 'whooshoff')
request("<" + devname + ";FAN;WHOOSH;OFF>")
@zackrbrown Been using the the Haiku Fan driver for months and just love it! One small enhancement would be to change the 'Set Speed' from preset to either percentage or level 1,2,3,4... The reason is that for my Haiku Fan Low=1 , Medium-Low=2 and Medium=4. I can't get to level 3. Just a thought! Thanks...
My latest update enables percentage control of the fan. I'm waiting for Zack to accept the pull request, but you can check out my fork here: GitHub - dineshpannu/hubitat-haiku-driver: A Hubitat Elevate driver for Haiku fans
@grandenko Which driver should I install? I see you have 2 drivers.
Add the code for both. Assign "Haiku Fan" (haiku-driver.groovy) to the fan. That driver will allow you to enable components for individual light and fan control. The other driver (haiku-fan-driver.groovy) is for the fan component used by the main driver.
@Gradenko Thanks for your help! This is a great addition to the Haiku driver,
@jwprovencher No problems, glad to help.
@andrew.conforti Under the pump at the moment but I can look at adding sleep() and whoosh() in the near future.
I am new to Hubitat and the community, and smart homes actually. But having fun with this all. Have a lot of GE Smart Dimmers and Switches installed and working great. Some learning but fun. Next is getting my BAF's connected. I was able to download and add the Driver to HE, but now what. I have searched for the instructions but unfortunately I am not having any luck. Anyone have some time to help a newbie....
Thank you all!
