If Onebox is not working as expected, please check the following:
Test your site by pasting the link into iFramely ; check that the target is using correct OpenGraph or oEmbed meta tags for content. And remember the description text is required in Discourse!
Verify that the onebox request to the target website has not been blocked by user-agent . Some WordPress hosts frequently block “unknown” user agents.
The iFramely link above will make a HTML iframe if things are not working
I think I have it now -
That is much easier, but just for reference, you can also do strike through like this...
<s>Text you want strike through
It won't show here because I marked it as preformatted text so you could see what I've done.
This will strike all texts from <s> forward. To set an end point you use </s>
So to strike just a section, you can use <s>Section of text you want strike through</s> to limit it.
There has got to be something that I am missing.
Is there anything that I have to sign-up for or download???
Is there something built into community.hubitat.com that does the transformation?
This is a test - Dimmer - Copied from the you sent - and displayed - Cashed? https://www.amazon.com/dp/B081FF9G2K
