Are you using the Nortek stick or something else? What firmware did you flash on it? Typically no firmware updates are required for use as a secondary controller as far as I know - it should just work.
Also from the screencap you have not included it with HE as a secondary controller so would not be able to pair any devices to HE that way anyway.
edit: I did try and use my old Nortek stick but that did not work with the PC Controller sw - maybe a usb driver issue or something dunno. I typically use either the UZB-7 or the Z-Stick+. The above screencap is a Z-Ztick+ paired as "device" on the HE with no security.
Yes, it is a HUSBZB-1 Nortek Secure & Control stick and I installed the firmware mentioned in the OP of this thread SDK_v6_82_01\SD3503\ProductPlus\Bin\SerialAPI_Controller_Static\serialapi_controller_static_OTW_SD3503_US_WITH_BOOTLOADER.hex
I'm sorry if I don't follow, this is my first Z-wave device and my introduction to Z-wave networking in general. I'm not sure if I follow when it comes to the term "secondary controller".
I'll try to read through more of the Silicon Labs documentation, but I'm still a little lost;
Either way I see you have Network Role: inclusion in your screenshot whereas mine only says Network Role: RealPrimary so I can tell something isn't correct with my setup.
It's good to know that you can't get the Nortek stick to pair using the PC controller either, but what other tool should I use to try and get it connected if it isn't working in Hubitat or Z-waveJS?
Sorry I missed your earlier post about the firmware update. So maybe others can chime in as to whether that is the appropriate firmware or not..
In order for a stick to become a secondary controller to HE you need to pair it with the HE as normal... first go into HE and discover Z-Wave devices, start the inclusion process. Then on the PC Controller sofware running press "classic learn mode". Hopefully the device will appear in HE as a generic "Device".. that is all you need in HE. In your PC Controller sw a list of devices from HE should appear.
When this is done you should be able to use the NWI button at the top of the PC Controller SW interface and put your Z-Wave device in inclusion mode.
Note: S2 devices will NOT pair with S2 security. Better to pair them directly using the HE itself.
This is the only Z-wave device I have so I can't use another stick to troubleshoot it, pouring through the logs recently and it looks like I have somehow removed my stick's ability to have SUC which might prevent it from adding / removing nodes or actually working as a controller.
Next weekend when I have some free time I'd like to retry flashing the hardware, it would be great if @jp0550 has any advice about what I should do in the meantime. I did take backups of the main firmware, SRAM and NVR and maybe I can use those to restore function, but for the time being I'm just not sure what I should try next to get this thing in a state where it's capable of inclusion again.
Guess this should serve as a warning for anyone attempting this.
I might have misunderstood what your goals are - I was assuming you wanted to use your Nortek stick as a secondary controller to remove ghosts/add devices with no security etc. If that is not the case then I apologize for the confusion.
It's alright, no worries. My goal was just to upgrade the Z-wave firmware on the Nortek stick included with the HE C-4 hub so I could experiment with some of the new features (which seemed to be what this thread was about). I had recently updated the Zigbee firmware on that stick and that was a wonderful process which greatly enhanced it's functionality.
The same can't be said for this process, and as the only Z-wave device on that hub, without it working as a SUC controller node or whatever to do inclusion, I can't rebuild my network and all my Z-wave devices have in fact been rendered useless. I will reattempt the process next weekend to see if I get better results, but I think for now anyone reading this needs to know:
This does not signify that the device will continue working. It will respond to traffic from other Z-wave devices nearby and log smartStart packets but it cannot include or work as a hub in any capacity.
Have you tried with older tools like zensys? I've been running the newer firmware since around August (on a primary controller) and haven't had any issues with inclusions. I don't have any smart start devices, though which is why I left the smart start section in the guide as untested. I needed the upgrade for the rssi and latency info in a custom application I am using. I don't believe the suc message indicates that it wouldn't be capable of including devices, though, in general, but I need to brush up on the functions.
There are other prebuilt firmware versions in the sdk that might have it enabled. Which hex file did you flash?
The older zensys tools shouldn't have any notion of smart start so it should hopefully tell you if it's capable of inclusions using the older api methods.
@jp0550 Thank you for your reply, I tried again this weekend; all I did was uncheck the S2 keypair options and click 'Calibrate, Program and Verify', following the flashing procedure.
I am pleased to announce this fixed all my issues, the controller is now capable of adding devices in PC controller 5 and elsewhere. If anyone else repeats this tutorial and they do not see 'Inclusion Controller' when looking in the PC Controller 5 software, just try flashing it one more time
It's not possible to downgrade the stick after the upgrade, but I think your question is on whether it wipes the stick's config or not. I was able to upgrade the firmware while keeping the current ZWave network in-tact.
Would it be possible to do a test where the NVM data pulled from one of these upgraded Nortek devices is sent to someone at Hubitat manually and then inserted into the database for a test user as if it had been uploaded from the device, and then migrated to a new hub to see if it takes it as expected?
Thanks @mike.maxwell - If its any incentive.. its basically the only thing making me not upgrade to the C7. My home has many devices that are built in and / or extremely difficult to get to so re pairing all of those devices is practically speaking impossible - I've only done it once, when I moved over from Smartthings and the entire process took months and in some cases involved calling out an electrician. Although there may not be as many people with such difficulties as me, I reckon you may find that a lot of people would buy a new hub from Hubitat if they knew this was possible!
Thanks so much for the guide.
TP28 can be used for the reset. TP28 is on the opposite side of the board and is near pin 1 of the usb connector and also near C7. This is a much larger pad and easy to solder to. I successfully programmed used TP28. If you solder a wire, keep it short it might be sensitive to noise pickup.
I also used the 6.84 SDK which can be found here, look under z-wave-500-series. https://www.silabs.com/developers/z-wave-500-series
For the PC controller software, that does not seem to be available as a direct link. One has to download simplicity studio 5, from within the application it gives you the option to download other software including the controller.
I have already upgraded the HusbZb following this tutorial (V 6.09). If I want to update it to the new version 6.10, I have to disassemble the USB dongle again or can I do it directly from the Z-Wave PC Controller program? Thanks
