[Guide] Docker / Portainer installation on linux-based systems
For anyone looking to install Docker / Portainer on a Raspberry Pi or other linux server such as Ubuntu, here is a list of commands to enter in a terminal window.
Notes:
  • The first box below can be scrolled until the line "END". Don't miss out on the full instructions.
  • Some commands are very long and are hidden to the right. Ensure that the entire line has been selected before copy/pasting.
#### Update System
sudo apt update && sudo apt upgrade
#### Docker
# Docker pre-reqs - curl, certs, and other software
sudo apt install apt-transport-https ca-certificates curl software-properties-common
# Docker GPG key
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
# Docker repository
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
# Update.  Yes, need to update again after installing
# the repo
sudo apt update
# Docker Install
sudo apt install docker-ce docker-ce-cli containerd.io
# Start Docker
systemctl start docker
# Enable Docker
systemctl enable docker
# Check that Docker is running
systemctl status docker
# enter 'q' to quit the status output and return to command prompt
#### Portainer
# Choose port number
# Check if port 8000 is already in use.  If the port is NOT
# in use, there will be no output and the command
# prompt will appear.  If port 8000 is already in use (e.g.
# Homebridge), there will be some output. Check other
# ports, such as 8100.
sudo netstat -peanut | grep ":8000"
# Create Docker volume for Portainer data.  A volume
# stores settings, making them persistent through reinstalls.
docker volume create portainer_data
# Download Portainer and run it
# Replace 8000 with an alternate port from above, if required
# Port 9443 is the web interface for Portainer
docker run -d -p 8000:8000 -p 9443:9443 --name=portainer --restart=always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer-ce:latest
# Open ports in the firewall.  These commands are for the
# ufw firewall. Replace 8000 with previously chosen port.
# allow tcp protocol port 9443
sudo ufw allow proto tcp to any port 9443
# allow tcp protocol port 8000
sudo ufw allow proto tcp to any port 8000
#### END
Access the user interface in a web browser: https://<your server IP>:9443
To update Portainer in the future
# Stop Portainer
docker stop portainer
# Remove Portainer container
docker rm portainer
docker pull portainer/portainer-ce:latest
# Run Portainer
# Remember to change port 8000, if it was required before
Some additional commands for Docker, if NOT using Portainer. I am not responsible for any harm or loss that may result in using these commands. Seriously, Portainer is the way to go.
# list running docker containers
docker ps
# restart a container using the ID from previous command
docker restart <id>
# stop a running container. BE CAREFUL!!  BE VERY CAREFUL!!
# Can’t start the container by simply using the instructions given here
docker stop <id>
# remove a container
docker rm <id>
# delete all non-running containers.  BE CAREFUL!!  BE VERY, VERY, VERY CAREFUL!!
# You’re nuking your docker containers.
docker system prune -a
Sources:
Nice write-up!
Docker/Portainer is an awesome combination.
My buddy got me into this particular flow about a year ago, and now I use it daily.
In my case, I use containers for running my plex server and all my media; running an apache server which allows me to file share to any other device on the network; and isolated environments for any local code development for clients.
As an aside, I see you linked to the Echo Speaks topic. I was never able to get this working in Docker/Portainer on my particular setup. After further researching, I noticed Echo Speaks was quite resource intensive.. and since I already own plenty of Sonos.. I decided to just keep the Sonos and abandon the Echo Speaks integration. Others' have it working successfully.. so I'm not sure what was preventing my installation from completing.
Anyways, here are a few screenshots from my Portainer console (just thought I'd share):
Thank you!
For me, Heroku was extremely complicated to set up initially and it continued to work by paying, so I was very reluctant to try docker and portainer. I am very familiar with VMs, but docker/portainer were completely foreign to me. It really only took me 10 minutes, the first time, to get it working. Then trying to be extra-smart resulted in another couple of hours to get it working in the same way as the first 10 minutes. I should have quit while I was ahead.
echo-speaks ran fine on my H7 from a resource perspective. If you're willing to give it a try, follow the "stacks" instructions in that guide and then follow the Hubitat App Login section EXACTLY.
Lmao... ohhhh, how well I know that situation!
Yeah, I was able to get all the way through... stack and container looked fine... cookie validation page looked fine... it just never actually accepted/registered the cookie correctly.
I found that I had to restart the container and repeat the last step. That didn't work for you? And If any mistake was made, to nuke the container, reset the login and cookie in echo-speaks, and try again.
