Hi Hubitaters!
I need some help flashing my Lucci Connect fan remote as suggested by @at9 here: Hubitat for AUS/NZ Chat - #1654 by at9 :
Looks like you can flash Tasmota on them with tuya convert.
There is a fork of Tasmota modified to work with HE here .
templates.blakadder.com
Configure Lucci Connect Remote Control to work with Tasmota firmware
I have never flashed a device before, so have no idea where to start...
Some help would be much appreciated
You can flash to Tasmota using Tuya Convert by following this . Once you have Tasmota on there you can follow this HE thread for drivers and upgrading to HE specific firmware.
I used this guide
(Ha! @jchurch beat me to it!)
.....And followed all of Markus' instructions here to get the correct firmware
WARNING: Flashing this firmware MAY cause your device to not boot again. This warning is the SAME as for the STOCK Tasmota release. To fix this you MAY have to flash through TTL. Read all instructions of the original Tasmota firmware CAREFULLY and don't be in a rush!
THIS DRIVER HAS BEEN DEPRECATED IN FAVOR OF A NEW SUIT OF DRIVERS, PLEASE CONSIDER UPGRADING
The latest driver can be found here .
Why this driver?
There's a lot of confusion on which Tasmota driver to use with HE, for some reasoā¦
....remembering to flash in this order (you'll get the gist of it from subsequent responses from @jchurch and markus).
First time playing around with Tasmota so please bear with the dumb question - the OTA process for a new install (on a TYWE2S) is to first flash the 7.1.1 basic build using tuya convert, then test connect to my wifi network and then flash to 8.1.1 using tuya convert again?
markus
March 9, 2020, 1:07am
5
@mikeb147 For the driver, it will require some specialization. It is easily added to the new driver which is in Closed Beta. PM me when you have flashed the device and we'll sort it out.
system
Closed
September 22, 2022, 5:48pm
6
