Hi @Royski Roy.
To save me looking through the specs and as I'm a lazy so and so, are you finding these reliable and easily controlled with HE and your driver?
Also, the USB outlets. Do they give a good power O/P and are these controllable or always on.
I like the look of these and may have to invest.
TIA.
They’re very hard to come by now as GW stopped producing them. I kept checking eBay for a long while before one came up.
They’re stable for me, as is the power reporting as it reports on change. But as far as I’m aware they don’t have USB?
Aghhh.
My bad.
I've just noticed that the one I found is not a Greenwave Powernode.
It is a wifi one the has 4 USB ports.
I'll go back to sleep now. Sorry..........
The drivers are exact copy of the ones on your github page.
I will try some more things during weekend maybe remove everything and reinstall.
Device
child
Hi,
Yeah that doesn’t look right at all.
In the parent you should see the component devices like below.
And your child devices should show their child driver.
i excluded the greenwave powernode from zwave network and removed the old drivers.
Then i installed the child driver and parent driver and added the powernode again.
It now shows like your pictures and works without any errors in logs and reacts much better in the dashboard.
Thanks for sharing the driver and your time in helping me out.
Great news!! Thanks for persevering
I obtained the Powernode 5 from (Greenwave Multi socket PowerNode US NP222-B Z-wave - Monoprice.com). Initially I installed only the parent drivers and had success with operation of the powerstrip but never received any status information as to the state of each of the individual plugs. I was able to control each plug individually.
I then went back and added the child driver. Excluded the powerstrip from Zwave and tried inclusion again. I never saw any children. My screen does not show a section for Component Devices. I tried to start over with deleting and adding drivers again and excluding and including device discovery, but no change in ability to see child devices. I am able to see parent and child drivers as options for the powerstrip, but no devices discovered that could be assigned the child driver.
I am running Hubitat version 2.1.6.113. Is there some other trick to getting Hubitat to recognize the child devices?
Hi,
There’s no magic here if you have both drivers in place and then add the strip.
You could try the 6 strip driver too, just in case. The only difference being it will add a 6th socket which you won’t have, but no harm trying. If you do that, delete the 5 strip drivers first though.
It would also be useful to see any logs relating to the inclusion.
This is the total log from the power strip. It is the only zwave device I have tried to connect to Hubitat. For the drivers I used the github links for the powerstrip 5, yet there are references for powerstrip 6 in them. I have not yet tried to load powerstrip 6 drivers.
indent preformatted text by 4 spaces
dev:22019-11-06 01:23:13.487 pm infoVibration: Recent activity level reported at 5
sys:12019-11-06 01:19:59.575 pm infoZ-Wave Discovery Stopped
sys:12019-11-06 01:19:59.573 pm infoZ-Wave Device Discovered: GreenWave PowerNode 5
dev:682019-11-06 01:19:59.560 pm infoconfigure()
dev:682019-11-06 01:19:59.542 pm debugcom.hubitat.app.exception.UnknownDeviceTypeException: Device type 'GreenWave PowerNode 6 Child Device' in namespace 'copycat73' not found
dev:682019-11-06 01:19:59.533 pm debugcreating child devices
dev:682019-11-06 01:19:59.531 pm debuginstalled
sys:12019-11-06 01:19:54.382 pm infoInitializing Z-Wave Device : 06
sys:12019-11-06 01:19:51.381 pm infoZ-Wave Discovery Running
sys:12019-11-06 01:16:05.374 pm infoZ-Wave device PowerStrip excluded and removed.
dev:672019-11-06 01:16:05.340 pm debuguninstalled()
sys:12019-11-06 01:16:03.024 pm infoZ-Wave Exclude Started for 30 Seconds
dev:22019-11-06 01:12:42.895 pm infoVibration: Recent activity level reported at 8
sys:12019-11-06 01:12:00.765 pm infoZ-Wave Discovery Stopped
sys:12019-11-06 01:12:00.764 pm infoZ-Wave Device Discovered: GreenWave PowerNode 5
dev:672019-11-06 01:12:00.740 pm infoconfigure()
dev:672019-11-06 01:12:00.717 pm debugcom.hubitat.app.exception.UnknownDeviceTypeException: Device type 'GreenWave PowerNode 6 Child Device' in namespace 'copycat73' not found
dev:672019-11-06 01:12:00.703 pm debugcreating child devices
dev:672019-11-06 01:12:00.701 pm debuginstalled
sys:12019-11-06 01:11:55.547 pm infoInitializing Z-Wave Device : 05
sys:12019-11-06 01:11:52.530 pm infoZ-Wave Discovery Running
dev:32019-11-06 01:10:19.822 pm infoMotion temperature is 77.51°F
sys:12019-11-06 01:09:18.391 pm infoZ-Wave device GreenWavePowerStrip excluded and removed.
dev:662019-11-06 01:09:18.335 pm debuguninstalled()
sys:12019-11-06 01:09:15.951 pm infoZ-Wave Exclude Started for 30 Seconds
dev:22019-11-06 01:06:52.239 pm infoVibration: Recent activity level reported at 10
dev:662019-11-06 01:01:42.949 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:662019-11-06 01:01:42.916 pm debugGreenwave v1 switchbinary report received for endpoint 4 value 0
dev:662019-11-06 01:01:42.911 pm debugGreenwave v3 cMultiChannelCmdEncap command received
dev:662019-11-06 01:01:42.797 pm infoGreenWavePowerStrip node 4 Off
dev:662019-11-06 01:01:37.961 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:662019-11-06 01:01:37.922 pm debugGreenwave v1 switchbinary report received for endpoint 4 value 255
dev:662019-11-06 01:01:37.918 pm debugGreenwave v3 cMultiChannelCmdEncap command received
dev:662019-11-06 01:01:37.804 pm infoGreenWavePowerStrip node 4 On
dev:662019-11-06 01:01:29.176 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:662019-11-06 01:01:29.139 pm debugGreenwave v1 switchbinary report received for endpoint 3 value 255
dev:662019-11-06 01:01:29.135 pm debugGreenwave v3 cMultiChannelCmdEncap command received
dev:662019-11-06 01:01:29.015 pm infoGreenWavePowerStrip node 3 On
dev:662019-11-06 01:01:25.721 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:662019-11-06 01:01:25.685 pm debugGreenwave v1 switchbinary report received for endpoint 3 value 0
dev:662019-11-06 01:01:25.659 pm debugGreenwave v3 cMultiChannelCmdEncap command received
dev:662019-11-06 01:01:25.521 pm infoGreenWavePowerStrip node 3 Off
dev:22019-11-06 01:01:20.870 pm infoVibration: Recent activity level reported at 19
dev:662019-11-06 01:00:56.564 pm errorjava.lang.NullPointerException: Cannot invoke method switchOn() on null object on line 67 (on)
dev:662019-11-06 01:00:56.538 pm debugGreenWavePowerStrip - On
dev:662019-11-06 01:00:54.240 pm errorjava.lang.NullPointerException: Cannot invoke method switchOff() on null object on line 72 (off)
dev:662019-11-06 01:00:54.209 pm debugGreenWavePowerStrip - Off
sys:12019-11-06 12:59:27.391 pm infoZ-Wave Discovery Stopped
sys:12019-11-06 12:59:27.385 pm infoZ-Wave Device Discovered: GreenWave PowerNode 5
dev:662019-11-06 12:59:27.355 pm infoconfigure()
dev:662019-11-06 12:59:27.331 pm debugcom.hubitat.app.exception.UnknownDeviceTypeException: Device type 'GreenWave PowerNode 6 Child Device' in namespace 'copycat73' not found
dev:662019-11-06 12:59:27.317 pm debugcreating child devices
dev:662019-11-06 12:59:27.315 pm debuginstalled
sys:12019-11-06 12:59:22.092 pm infoInitializing Z-Wave Device : 04
sys:12019-11-06 12:59:19.082 pm infoZ-Wave Discovery Running
sys:12019-11-06 12:58:58.037 pm infoZ-Wave device PowerStrip excluded and removed.
dev:652019-11-06 12:58:57.992 pm debuguninstalled()
sys:12019-11-06 12:58:55.677 pm infoZ-Wave Exclude Started for 30 Seconds
sys:12019-11-06 12:56:37.037 pm infoZ-Wave Discovery Running
dev:22019-11-06 12:56:19.591 pm infoVibration: Recent activity level reported at 9
dev:12019-11-06 12:53:26.060 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 12:53:26.058 pm infoDoor: Battery level is 100% (3.025 Volts)
sys:12019-11-06 12:51:39.123 pm infoZ-Wave Discovery Stopped
sys:12019-11-06 12:51:39.121 pm infoZ-Wave Device Discovered: GreenWave PowerNode 5
dev:652019-11-06 12:51:39.019 pm infoconfigure()
dev:652019-11-06 12:51:38.989 pm debugcom.hubitat.app.exception.UnknownDeviceTypeException: Device type 'GreenWave PowerNode 6 Child Device' in namespace 'copycat73' not found
dev:652019-11-06 12:51:38.934 pm debugcreating child devices
dev:652019-11-06 12:51:38.933 pm debuginstalled
sys:12019-11-06 12:51:33.740 pm infoInitializing Z-Wave Device : 03
sys:12019-11-06 12:51:30.683 pm infoZ-Wave Discovery Running
sys:12019-11-06 12:51:21.329 pm infoZ-Wave device PowerStrip excluded and removed.
dev:332019-11-06 12:51:21.112 pm debuguninstalled()
sys:12019-11-06 12:51:18.602 pm infoZ-Wave Exclude Started for 30 Seconds
sys:12019-11-06 12:50:38.358 pm infoZ-Wave Exclude Started for 30 Seconds
sys:12019-11-06 12:50:27.761 pm infoZ-Wave Discovery Stopped
sys:12019-11-06 12:50:27.714 pm infoZ-Wave Discovery Stopped
sys:12019-11-06 12:49:26.745 pm infoZ-Wave Discovery Running
dev:22019-11-06 12:48:33.200 pm infoVibration: Recent activity level reported at 8
dev:22019-11-06 12:44:30.817 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 12:03:21.185 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 12:03:21.183 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 11:49:20.082 am infoVibration: Battery level is 77% (3.015 Volts)
dev:22019-11-06 11:35:44.837 am infoVibration: Recent activity level reported at 4
dev:332019-11-06 11:29:32.013 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 11:29:31.880 am infoPowerStrip node 3 Off
dev:332019-11-06 11:29:28.102 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 11:29:27.952 am infoPowerStrip node 3 On
dev:22019-11-06 11:27:34.955 am infoVibration: Recent activity level reported at 6
dev:12019-11-06 11:13:09.032 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 11:13:09.030 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 11:02:03.016 am infoVibration: Battery level is 77% (3.015 Volts)
dev:22019-11-06 10:58:48.206 am infoVibration: Recent activity level reported at 8
dev:332019-11-06 10:54:08.171 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:54:08.027 am infoPowerStrip node 3 Off
dev:22019-11-06 10:51:04.971 am infoVibration: Recent activity level reported at 21
dev:32019-11-06 10:50:07.028 am infoMotion battery is 87%
dev:32019-11-06 10:50:07.021 am infoMotion temperature is 76.59°F
dev:332019-11-06 10:45:50.324 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:45:50.169 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:45:49.952 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:45:49.732 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:45:49.504 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:22019-11-06 10:45:04.191 am infoVibration: Recent activity level reported at 21
dev:332019-11-06 10:44:57.782 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:44:57.638 am infoPowerStrip node 2 Off
dev:22019-11-06 10:39:38.244 am infoVibration: Recent activity level reported at 21
dev:332019-11-06 10:36:14.299 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:36:14.142 am infoPowerStrip node 2 On
dev:332019-11-06 10:36:11.045 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:36:10.901 am infoPowerStrip node 2 Off
dev:332019-11-06 10:35:54.550 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:35:54.381 am infoPowerStrip node 2 On
dev:332019-11-06 10:35:48.130 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:35:47.975 am infoPowerStrip node 2 Off
dev:22019-11-06 10:34:37.206 am infoVibration: Recent activity level reported at 27
dev:22019-11-06 10:29:36.174 am infoVibration: Recent activity level reported at 18
dev:22019-11-06 10:24:41.265 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 10:23:05.823 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 10:23:05.820 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 10:19:31.925 am infoVibration: Recent activity level reported at 14
dev:22019-11-06 10:14:13.759 am infoVibration: Recent activity level reported at 17
dev:22019-11-06 10:09:12.759 am infoVibration: Recent activity level reported at 10
dev:332019-11-06 10:06:14.743 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:06:14.550 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:06:14.332 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:06:14.058 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:06:13.846 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:22019-11-06 10:04:12.382 am infoVibration: Recent activity level reported at 10
dev:332019-11-06 10:02:51.708 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:02:51.564 am infoPowerStrip node 1 On
dev:332019-11-06 10:02:45.827 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 10:02:45.675 am infoPowerStrip node 1 Off
dev:332019-11-06 09:59:32.347 am infoon
dev:332019-11-06 09:59:18.810 am errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-06 09:59:16.692 am infoPowerStrip node 1 Off
dev:22019-11-06 09:58:00.884 am infoVibration: Recent activity level reported at 5
dev:22019-11-06 09:44:39.300 am infoVibration: Battery level is 77% (3.015 Volts)
dev:22019-11-06 09:44:38.065 am infoVibration: Recent activity level reported at 13
dev:12019-11-06 09:32:46.538 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 09:32:46.535 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 08:52:49.446 am infoVibration: Recent activity level reported at 5
dev:22019-11-06 08:47:36.364 am infoVibration: Battery level is 77% (3.015 Volts)
dev:22019-11-06 08:47:35.157 am infoVibration: Recent activity level reported at 9
dev:12019-11-06 08:42:35.324 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 08:42:35.322 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 08:42:34.716 am infoVibration: Recent activity level reported at 8
dev:22019-11-06 08:36:32.652 am infoVibration: Recent activity level reported at 7
dev:32019-11-06 08:04:53.872 am infoMotion temperature is 75.69°F
dev:22019-11-06 07:58:35.165 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 07:52:31.054 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 07:52:31.051 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 07:02:19.351 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 07:02:19.347 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 07:00:23.103 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 06:12:06.315 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 06:12:06.313 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 05:57:54.381 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 05:21:51.025 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 05:21:51.023 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 04:56:37.884 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 04:31:38.525 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 04:31:38.522 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 03:59:44.347 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 03:41:19.161 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 03:41:19.158 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 02:58:33.735 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 02:51:10.360 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 02:51:10.357 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 02:01:04.653 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 02:01:04.650 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 02:00:34.068 am infoVibration: Battery level is 77% (3.015 Volts)
dev:32019-11-06 01:39:24.505 am infoMotion temperature is 76.59°F
dev:12019-11-06 01:10:51.405 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 01:10:51.402 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-06 01:00:24.396 am infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-06 12:20:40.817 am infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-06 12:20:40.814 am infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-05 11:56:24.086 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-05 11:30:33.113 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 11:30:33.108 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-05 10:59:22.897 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-05 10:40:13.654 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 10:40:13.651 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-05 09:57:12.267 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-05 09:50:02.135 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 09:50:02.132 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 08:59:55.937 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 08:59:55.934 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-05 08:57:06.126 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-05 08:09:37.003 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 08:09:36.999 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-05 07:56:11.118 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:12019-11-05 07:19:25.538 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 07:19:25.535 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-05 06:53:08.689 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:22019-11-05 06:29:50.887 pm infoVibration: Recent activity level reported at 6
dev:12019-11-05 06:29:22.122 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 06:29:22.118 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:22019-11-05 05:51:55.015 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:22019-11-05 05:51:53.795 pm infoVibration: Recent activity level reported at 21
dev:12019-11-05 05:39:12.541 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 05:39:12.535 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:32019-11-05 05:13:39.930 pm infoMotion temperature is 77.49°F
dev:332019-11-05 04:56:47.399 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:47.277 pm infoPowerStrip node 5 On
dev:332019-11-05 04:56:45.139 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:45.014 pm infoPowerStrip node 4 Off
dev:332019-11-05 04:56:44.121 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:44.005 pm infoPowerStrip node 3 On
dev:332019-11-05 04:56:39.434 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:39.308 pm infoPowerStrip node 2 Off
dev:332019-11-05 04:56:37.547 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:37.416 pm infoPowerStrip node 1 On
dev:332019-11-05 04:56:31.513 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:31.341 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:31.170 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:30.985 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:56:30.741 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:22019-11-05 04:55:00.666 pm infoVibration: Battery level is 77% (3.015 Volts)
dev:332019-11-05 04:54:03.133 pm infoResetting kWh for all endpoints
dev:332019-11-05 04:53:59.914 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:53:59.775 pm infoPowerStrip node 5 On
dev:332019-11-05 04:53:57.609 pm errorjava.lang.NullPointerException: Cannot invoke method sendEvent() on null object on line 384 (parse)
dev:332019-11-05 04:53:57.296 pm infoPowerStrip node 5 On
dev:332019-11-05 04:53:53.178 pm infooff
dev:332019-11-05 04:53:52.127 pm infooff
dev:12019-11-05 04:48:54.472 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:12019-11-05 04:48:54.470 pm infoDoor: Battery level is 100% (3.025 Volts)
dev:32019-11-05 04:44:18.880 pm infoMotion battery is 87%
dev:332019-11-05 04:36:56.345 pm infofingerprint mfr:"0099", prod:"0003", deviceId:"0004", inClusters:"0x25,0x32,0x60,0x72,0x86,0x20,0x71,0x70,0x27,0x85,0x87,0x75,0x56"
dev:332019-11-05 04:36:56.339 pm debugbuilding fingerprint for unknown Z-Wave device...
dev:332019-11-05 04:35:21.900 pm infofingerprint mfr:"0099", prod:"0003", deviceId:"0004", inClusters:"0x25,0x32,0x60,0x72,0x86,0x20,0x71,0x70,0x27,0x85,0x87,0x75,0x56"
dev:332019-11-05 04:35:21.867 pm debugbuilding fingerprint for unknown Z-Wave device...
sys:12019-11-05 04:35:19.980 pm infoZ-Wave Discovery Stopped
sys:12019-11-05 04:35:19.979 pm infoUnknown Z-Wave Device Discovered
dev:332019-11-05 04:35:19.732 pm debugconfigure() called...
looks like I do not know how to embed text without formatting.
Are you sure the parent and child drivers are for the 6 or 5?
If installing for the 6, both parent and child need to be for the 6, but the logs state it can’t find the child device driver.
I replaced the drivers with those for Powernode 6 and now the children do show up. I use this via Maker API so was able to exclude the 6th switch, except for the case when I poll for energy use and then MakerAPI still reports the 6th switch status.
Great news!
Feel free to edit the child driver and comment out the section for the 6th.
Also look for a section “1.. 6” if you change the 6 to 5, it should stop trying the poll or refresh No.6
I was also looking into getting one of these. I mean $20! Much less than the Zooz one which is almost $80. I saw a lot of people saying they cannot find them for sale, so I thought I would post that I found them on Amazon.
Should we add this item to the community list of compatible devices?
Quick question, is the energy usage monitoring working?
Thanks so much @Royski for your great support.
You’re very lucky over the pond, you can’t find them anywhere over here. Yes they report power usage And works great got me I get the odd error on a parse, but not had time to track that down as yet.
Warning about this device... I was pretty excited about it until I noticed that it is not z-wave plus.. This device will slow down your z-wave mesh as it is a mains powered non-plus device .. Anything that hops through this will be at 40kbps
@Royski I would happily ship you some, if it was possible to use over there. I wonder if you could just cut off the plug and install one which fits your outlets or if it's different inside because the voltage is different.
Thank you for the warning @bcopeland!
I bought one, connected (to Homeseer) easily. The individual outlets respond reliably. However, I could not get any power readings and apparently, that's a known problem. Also, at least on mine, the hardware is so old that the firmware cannot be updated.
Its the voltage and connections on the strip, all different here, but thank you
