Great little Relay controller and 433Mhz fob integration!
i managed to get it all working using the generic zigbee switch driver. it’s just odd (annoying) that it doesn’t come in this way by default when joining. it comes in as a multi endpoint device. quite odd. even more odd is i found a tuya driver that lets me reverse the led indicator. but that’s a fail, since this is a neutral not required device, if you turn the led on when the switch is off, each time it repeats a signal, the lights connected to the switch flash. this is due to how current is always drawn to maintain the radio. when you add the minimal amount of current from the led, it’s just enough to make the light connected to the circuit flicker when the radio repeats a signal. i’m sure someone might get a kick out of knowing this.
