Govee WiFi LED Light Strip
I have 2 x Govee LED strips that are WiFi and Bluetooth enabled (model number H6159). I have tried to find a way to add them to Hubitat but not managed to find anything. Can anyone help? They can be controlled with Alexa so am assuming it can be done with Hubitat? TIA
Moving forward this is a dangerous assumption to make with Wi-Fi devices as it is typically not true or only true with some unusual workarounds. To confirm if a device works with Hubitat directly, you should always reference this list:
https://docs.hubitat.com/index.php?title=List_of_Compatible_Devices
I didn't read this entire thread but it looks like the Govee LEDs might have an open API that you can use with Hubitat:
