Govee Leak Detector 2
How can I get this connected locally to my C5? The H5043 hub has LoRa and bluetooth and I assume LoRa is operating at 908.42MHz. Should I just buy one of the newer Z-Wave sticks and plug it into my C5?
Ultimately, I want to use them to trigger a Titan actuator (ZAC36).
I don't think you will be able to connect that, should have gone with Zigbee or Zwave sensors.
Try asking in this post.
In the Govee Home app do they show up in the environment section on the Home Page?
Most likely it is not going to be possible, but there is a sliver of hope if the answer to the above question is yes.
If it is yes send me a DM and i will let you know what i need to test.
Yes they all show up on the home page
Check your DM
Curious if you were able to get the leak detectors to work?
At the moment no progress was made using the idea hinted at above.
That said the water leak sensors were brought up on the developer discussion boards and Govee responded positively to adding support. So it ahould be coming at some point. When it does become avaliable i will just need someone with the devices to work with to create the drivers.
