I made an update to the driver. Now if in the Preferences section you only enter your "User API Key", and leave the other two blank it will:
List in the logs all devices attached to that API Key. It looks like this
It will automatically set your preferences to use the last device in the list (the most recent). So everything should just work if you only have one device. If you have more than one, check the logs and just change the Address and Model in your preferences and save.
I only have one Govee device. So if it gives people with more than one any problems, lemme know.
