I've got a Gledopto Zigbee RGB+CCT Controller (GL-C-008).
I've got it added to my hubitat just fine using the Advanced Zigbee RGBW Bulb. When I first set it up, I was able to add it to Google Home and use the GH app to control on/off. I could never get color control, but at least it was available.
Now, the controller has disappeared from the GH app. When I try to re-add it to GH in Hubitat, I get this error in the GH app - "The following devices are not supported by Google Home and will be removed from your device list:[Device Name]"
I've searched here and in the logs, but I can't find (but admittedly probably don't know the right place to look) more info on why it is failing now and how to fix it.
I have tried removing the device, resetting to default and re-adding, but GH still won't recognize.
Anyone have any pointers on how to get this controller enabled for use in Google Home with color control? i.e. Hey Google set the lights to red.
Thanks in advance for your help!
