I found it, it was in the advanced options, I had to activate it
uff too mess friend, I already have enough headaches with HE. but thanks for your help to webcore
I can create the rule, the problem I see is that it doesn't let me send a message, only the one I tell it to write, it doesn't let me send it to weathersummary, I don't know if I understand myself
Have you taken a look at this integration?
[RELEASE] Telegram Bot API (notifications)
You create a variable populated by the attribute of the weather device then insert that variable into the message
I already have it installed
The issue is that I don't deal much with the rules, could you help me?
You can sort of use this as a template to create your variable. then in your notification simply put "Today's Weather is %whateveryourvariablenameis% sent to pushover or whatever notification device you want to use is.
I was able to do it guys! I had to create the variable in the hub and then the variable came out, I am Spanish and the summary comes out in English, any way to send it to me in Spanish?
¡Felicidades por hacerlo y aprender cómo funcionan las variables!!!!!!!!!
¿Cambiar el idioma en Hubitat cambia los atributos que emite el dispositivo?
You need a source for your weather forecast that uses the Spanish language, not English.
no friend, I have hubitat in spanish but openweather is english and it gives me the results in english
and how would that be? I can't find a Spanish one. The truth is that things in Spanish are quite limited.
I dunno, I live in the US and English is my primary language.
You could try using wunderground instead, that may output in spanish.
I don't see that it's in Spanish... too bad, any other alternative?
Does weather underground still have an API and a Hubitat driver with an attribute similar to the “weatherSummary” attribute for openweathermap?
@dJOS Is it possible to change the language? I want to make an automation that sends me a summary message, but it comes out in English, any chance to change the language?
The language is from the source the driver pulls in info from.
That’s true for both wunderground and OWM.
That seems to be the root of the issue for the OP.
Perhaps there are no sources of info for weather, traffic, etc. on the web available for your location, in your language. Or perhaps you have not found them yet.
