I have a gocontrol a19 light that I would like to get connected to HE. It won't detect it at all. It's no longer connected to my smartthings. Any input would be great. Also, is there a DH for it?
I'd be surprised if the generic z-wave bulb doesn't cover it. You've flicked the power to it on and off like 4 times usually? (While in device discovery mode.)
Also I bring the hub close to the device. Long Ethernet cables or a WiFi repeater with an Ethernet port are super useful when pairing.
I've flicked and clicked and no go. I know it's not connected to my ST hub. It's in the light right next to the hub. It just won't connect. It's the damdest thing.
I've had to put the hub in z-wave exclude mode and re-exclude devices. It's like they get confused and don't pair properly the first time. Especially when leaving ST.
At least one of those drivers should work with almost any switch so something might have messed up during inclusion and you may need to remove the device and add it again.
This is not the first time I added it. I attempted it back when I got the hub a few months ago with the same results. It's not listed as compatible. Gocontrol has always been difficult for me.
I am BIGTIME glad I came across your post here. I just fired up my HE for the 1st time and the first device I am trying to pair and get to work is a LinearLinc Z-Wave bulb. FAIL FAIL FAIL for an hour straight. My cats all think I've been yelling at them and are staring me down wanting to eat my face. Finally...Generic Z-Wave Dimmer does the trick! THANK YOU!!!
