I got to Network Management per the instructions and I can see my devices.
Since I can see the devices I then went to step 15 that says:
15.Exclude your Ghost: IMPORTANT: Make sure you remove power from the device that caused the ghost which is almost always the next device in the Z-Wave Details screen in HE. Flip a circuit breaker, pull air gap on a wall switch, remove batteries, etc. The ghost device must not have power.
a. Find and click on your "ghost" device. In the picture above, device 21 is the ghost device.
b. Click on Is Failed in the upper right pane-hopefully it will mark the device as failed. You’ll know the ghost device has been marked failed when the name of the ghost device text turns redlike this.
c .Then click on Remove Failed
d. If the ghost is not removed, try clicking on NOP and maybe Is Failed again a few times to see if that works to get it into Is Failed status
Here is my ghost device # 86 so I air gapped # 87
As you see, it worked in PC Controller and removed #86
However, I still couldn't remove it from Hubitati.
So 15 goes on to say:
NOTE: Not commonly, but in some cases when removing a ghost, the ghost will disappear from PC Controller but persist on your hub. This can occur if the UZB stick is not connected to your hub’s mesh while removing a ghost in PC Controller. The ghost is removed from the UZB stick’s mesh but isn’t removed from your hub. In that case try the following:
Exclude the UZB stick from your hub
Reset it, if it has a reset option
Re-pair the UZB stick to your hub
Remove the ghost node again in the PC Controller app
I was able to exclude the PC Controller from Hubitat by using the Discover and Remove method.
I then put Hubitat into Include Mode and plugged in the PC Stick but it wasn't found. I can't find the instructions on how to include it again.
I have the Zooz 800LR Z-Wave Stick ZST39 LR. I don't see anything in the instructions on how to put it into inclusion mode. (Which is why I thought all I had to do is plug it in and put HE into inclusion mode).
BTW the Zooz instructions say The 800 Series Stick can only be reset by the host software while it's in SerialAPI mode. The device is reset once an appropriate command from the host software is sent to reset the Z-Wave network. There is no way to manually reset the S2 stick if it's not controlled by host software. So I have no idea what that really means or how to do a Factory Reset if that is needed to re-pair it to Hubitat.
I'm hoping that isn't the case, but can you point me to the instructions on how to paid the Z-Wave stick to Hubitat?
BTW, am I correct that there is no Add Device from the Z-Wave Details page, just to Exclude one? If so, I'd like to add that to the Wish List.
