Sorry to have been away so long. I was able to get one problem fixed, and that was my room turning everything on. I was able to track that down to an Alexa routine that was turning it all on at Sunset. I'm the only who ever does any automations and I'm 100% I didn't intentionally create it. I don't know if it was an Alexa hunch or suggestion and I said OK to it or what. But, in any event, that's resolved.
So today (Feb 4, 2024) I wanted to try to resolve the issue where I have a device with a route, but no name. That was 4B a/k/a 75.
My plan was to follow these steps:
OK, since you have PC Controller and since the device appears to be a switch based off your screenshot, go to the Network Management tab, select device 75, then click "Basic Set ON" and then go around your house looking for the switch or light that just turned on.
You can alternately hit the ON and OFF commands to help you locate the device. This will help you identify WHAT device is device 75.
Then, in Hubitat, create a virtual device, but select the appropriate type for that device, ie "Generic ZWave Switch", or whatever is appropriate.
Create the device, then change the network ID. You'll have to tell Hubitat that you think you know what you're doing. Then you'll enter "4B" in the ID box (without the quotes. 4B represents 75 if hex).
After you do this, save the device, then immediately hit initialize or configure at the top of the device page. It should sync Hubitat with the switch and you should be golden.
The first issue I have is that controller appeared as 129 and 131. 129 is in Hubitat, but not 131
But in the PC Controller it looks like 129 isn't working, but 131 is.
I don't know if that is the reason, but for whatever reason, with 75 selected clicik on Basic Set On did nothing:
The next step said " You can alternately hit the ON and OFF commands to help you locate the device." But I don't know what that means as there are no buttons that say just "ON" or "OFF", Just the Basic Set On and Basic Set Off. So I couldn't try that as I couldn't find any such button.
I then started looking on my Hubitat Devices page and noticed one was missing, my Master Bathroom Toilet Fan. This device is an Inovelli Black On/Off. Since I have others just like it I went into one and saw the Device was an Inovelli Switch LZW30.
So I created a virtual device with that driver and made the ID 4B. (I added "AA AA" to the name so it would sort to the top.
I saved it and then quickly press the Configure button (as I didn't see one called "Initalize")
I saw this in the logs after I pressed Configure:
I then went to the Devices page and 4B is now my virtual device:
When I'm inside the virtual device in Hubitat pushing the On or Off button does not generate anything in the logs and the Current States remains blank.
As a test I changed the drive to Generic Z-Wave Plus Switch:
And since there is no Initialize button I immediately pressed the Configure button again.
But as you can see above, I still have nothing under the Current States and it doesn't show up in the logs at all. BTW, I did create a virtual device a long time ago to act as a place holder for my Inovelli Red Series dimmers for times when I would have to take a device offline and didn't want to re-do apps. Pressing the on/off button for that does change the Current States and shows up in the logs. So this vitrual device isn't working.
So I am not "golden". Hubitat still doesn't know that is the Master Bathroom Toilet fan.
So what do I do now?
