todds89
February 22, 2018, 11:46pm
1
Trying to add my crawl space moisture sensor but don't see any "generic Z wave moisture sensors". Is there something in the works?
My model is Aeotec by Aeon Labs DSB45
You can try the GoControl modified one linked in the Wiki. Not sure if it'll work with that exact sensor, but it's worth a shot.
The purpose of this Wiki post* is to maintain an active list of community based drivers that are currently running on the Hubitat Elevation platform. As you add new devices to your network that are NOT listed in the "List of Compatible Devices " , please add them here to keep the Community up to date.
See also, the Community Apps Wiki for a list community based applications.
Please note:
The list of devices that are known by our staff to work on Hubitat Elevation hub, has a new home. Please vi…
todds89
February 23, 2018, 1:47am
3
Thanks… tried it but not working…
Tony
February 26, 2018, 11:16pm
4
I have the DSB45 working using a modified Generic Z-Wave Water Sensor dth from SmartThings (change the instances of physicalgraph to hubitat). Original file is here:
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Generic Z-Wave Water Sensor
* Author: SmartThings
* Date: 2013-03-05
metadata {
definition (name: "Z-Wave Water Sensor", namespace: "smartthings", author: "SmartThings", ocfDeviceType: "x.com.st.d.sensor.moisture") {
This file has been truncated. show original
system
Closed
September 22, 2022, 6:59pm
5
