Compatible Devices Wiki
#1
The purpose of this wiki post* is to maintain an active list of community based drivers that are currently running on the Hubitat Elevation platform. As you add new devices to your network that are NOT listed in the "List of Supported Devices" , please add them here to keep the Community up to date.
Please note:
The list of devices that are known by our staff to work on Hubitat Elevation hub, has a new home. Please visit our updated list at: List of Supported Devices - Hubitat Documentation
*wiki posts can be modified by every member of our community, just click the "Edit" button located at the bottom of every Wiki post. image
ZWave Devices
Aeon Dry Contact
Aeon Home Energy Meter
Aeon Home Energy Meter v1 for Laundry Monitoring (custom driver)
Aeon Labs Doorbell
Aeon Labs Contact
Aeon micro dimmers
Aeon micro motor controllers
Aeon Minimote
Aeon Multisensor / motion
Aeon Multisensor 6
Aeon Recessed Door Sensor
Aeon Series 2 non energy dimmer
Aeon Series 2 non energy switch
Aeon Siren Gen 5
Aeon WallMotes
Aeon water
Aeotec Garage Door Controller Gen5 (ZW062-A) - Using "Generic Z-Wave Garage Door Opener"
Aeotec NanoMote One (ZWA003-A)
Aeotec NanoMote Quad (ZWA004-A)
Aeotec TriSensor (ZWA005-A)
BeSense 360 Ceiling Sensor (IX32)
BeSense Door/Window Sensor (IM20)
BeSense PIR Wall Sensor (IX30)
Devlolo Home Wall Control Switch (Driver)
Dome Door Sensor
Dome Door/Window Sensor Pro
Dome Leak Sensor
Dome Mouser
Dome On/Off Plug
Dome Siren
Dome Water Shut-off
domitech Smart LED Light Bulb (using Generic Z-Wave Dimmer driver)
Ecolink Contact Sensor (DWZWAVE2.5-ECO)
Ecolink Garage Door Tilt Sensor (TILT-ZWAVE2)
Ecolink PIR Motion
Ecolink Smoke/CO Audio Detector (FF-ZWAVE5)
Ecolink Wireless Rocker Switch
Ecolink Wireless Toggle Switch
EcoNet Controls EBV105-UMK Z-Wave Water Valve
Enerwave Motion Sensor
Eurotronic Spirit Z-Wave Radiator Thermostat (TRV)
Everspring Contact Sensor (HSM02)
Everspring Motion Sensor (HSP02)
Everspring Smoke Detector (SF813)
Fibaro Original multi
Fibaro Dimmer 2 (FGS-212) (custom driver)
Fibaro Door/Window Sensor 2 (FGDW-002)
Fibaro Double Relay (FGS-222) (custom driver)
Fibaro Flood Sensor
Fibaro Motion Sensor ZW5 (FGMS-001)
Fibaro RGBW (FGRGWM-441) (custom driver)
Fibaro Siren
Fibaro Single Switch 2
Fibaro Wall Plug
FIBARO Z-Wave Plus Flood and Temperature Sensor FGFS-101 ZW5
Fibaro Z-Wave Plus Wall Plug with USB Charging Port FGWPB-121
First Alert Smoke & CO Alarm (ZCOMBO)
FOXX Project SmartSwitch Gen5 (custom driver)
GE In wall paddle switch
GE In wall dimmer switch
GE/Jasco Zwave Plus Dimmer Switch with Double Tap, Associations (custom driver)
GE In wall ceiling fan controller
GE Jasco switches
GE Smart Motion switch
GE Outdoor module
GE Smart Switch Dimmer
GE Smart Switch Outlet Plug-in
GE Smart Switch Outdoor
GE Smart Switch Toggle
GoControl Garage Door Controller
GoControl Glass Break Detector
GoControl Contact Sensor (Custom Driver)
GoControl Multifunction Contact Sensor (Custom Driver)
Hank Four-Key Scene Controller (HKZW-SCN04)
Hank One-Key Scene Controller (HKZW-SCN01)
Hank RGBW LED Bulb (HKZW-RGB01)
HomeSeer HS-WV100+ Wireless Z-Wave Plus Water Valve - Using "Generic Z-Wave Valve"
HomeSeer WD-200 Dimmer
Inovelli 1-Channel Smart Plug w/Scene (Custom Driver for advanced features or Basic functionality w/o)
Inovelli 2-Channel Smart Plug (Custom Driver)
Inovelli In-Wall Dimmer(Custom Driver for advanced features or Basic functionality w/o)
Inovelli In-Wall Dimmer w/Scene(Custom Driver for advanced features or Basic functionality w/o)
Inovelli In-Wall Switch(Custom Driver for advanced features or Basic functionality w/o)
Inovelli In-Wall Switch w/Scene(Custom Driver for advanced features or Basic functionality w/o)
Inovelli Door/Window Sensor(Custom Driver for advanced features or Basic functionality w/o)
Inovelli Dimmer Smart Plug(Custom Driver for advanced features or Basic functionality w/o)
Inovelli Dimmer Smart Plug w/Scene(Custom Driver for advanced features or Basic functionality w/o)
Inovelli 1-Channel Outdoor Smart Plug (Custom Driver for advanced features or Basic functionality w/o)
Inovelli 2-Channel Outdoor Smart Plug (Custom Driver)
Intermatic CA3500 Outlet
Intermatic CA600 Dimmer
Kwikset 910/912 Lock
Kwikset Convert Z-Wave Smart Lock Conversion Kit (914 ZW500 CONVERT 15) using the "Z-Wave Generic Lock"
Leak Gopher Z-Wave Valve Control - Using "Generic Z-Wave Valve"
Leviton Outlet Plugin
Leviton Duplex Outlet
Leviton Plug-in Appliance Module
Leviton Plug-in Dimmer Module
Leviton Smart Switch Toggle
Linear Alarm
Linear Contact Sensor (WADWAZ-1)
Linear Motion Sensor (WAPIRZ-1)
MCO Touch Panel Power Single/Double/Triple Switch (Driver for Triple) (Driver for Double) You will also need to import this
Monoprice Contact Sensor
Monoprice Z-Wave Plugin On/Off # 11995 (Using Generic Z-Wave Outlet)
Monoprice Z-Wave Plus PIR Motion Detector with Temperature Sensor # 15271 (Using Generic Z-Wave Motion/Temperature Sensor)
Monoprice Z-Wave Plus PIR Multi Sensor # 15902 (Using Zooz 4-in-1 Sensor)
Monoprice Z-Wave Plus Recessed Door/Window Sensor # 15268 (Using Generic Z-Wave Contact Sensor)
Monoprice Z-Wave Plus Smart Plug and Repeater with 2 USB Ports # 27481 (Using Zooz Power Switch)
Nexia One Touch NX1000 (Using Remotec ZRC DH)
Popp Wall Controller 009303 (Driver)
Popp Key Fob (Driver)
Qubino Z-Wave Plus ZMNHID3
Remotec ZFM-80 relay
Remotec ZRC-90US Button Controller (official and Custom Driver)
Schlage Lock
Sensative Strips Comfort (Temperature/Light Sensor)
Sensative Strips Drip (Temperature/Water Sensor)
Sensative Strips Guard (Contact Sensor)
Telldus Outlet Switch
WaterCop Shut-Off Valve
Wireless Smoke Detector (ZWN-SD)
Z-Wave.Me Wall Controller (WALLC) 1 & 2 (Driver)
Zooz 4-in-1 Sensor (ZSE40)
Zooz Motion/Light Sensor (ZSE09)
Zooz Motion Sensor (ZSE02)
Zooz Motion Sensor (ZSE18)
Zooz Power Switch (ZEN15)
Zooz Smart Plug (ZEN06)
Zooz Water Valve (Custom Driver)
ZWP Dimmer
ZWP Switch
Zigbee Devices
Bosch Motion Sensors
Centralite Contact Sensor
Centralite Multi Sensor
Centralite Moisture Sensor
Centralite Outlet Plug-in
Centralite Perl Thermostat
Cree Smart Bulb
eCozy Thermostat / TRV (custom driver)
Enerwave Duplex outlet
GE Link Bulb
GE Smart Switch
Hampton Bay Zigbee Fan (official and custom driver)
Hive Active Plug (UK Only) (custom driver)
Hue Dimmer (custom driver)
Hue Lux
Hue strip, bloom and Living Colors Lights
Hue Motion Sensor
IKEA Trådfri Bulb E14 CT
IKEA Trådfri Outlet (Outlet only. IKEA remote not supported)
Iris Appliance modules
Iris Fobs and Buttons (presence included)
Iris Contact Sensor
Iris Motion Sensor
Iris Plug-in module with Zwave repeater
Iris security Keypad (also Comcast keypad)
Keen Home Smart Vent
Lux KonoZ Thermostat
NanoLeaf Ivy Bulb
NYCE contact sensor
NYCE Motion sensor (ceiling and wall)
Orbit hose valve timer
Osram BR
Osram Smart+ Classic E27 Multicolor
Osram Smart+ Indoor Flex RGBW
PEQ Appliance Modules
PEQ Moisture Sensor
PEQ Motion Sensor
PEQ contact sensors
Philips Bridge
Philips Color Bulbs
Philips White Bulbs
Philips Iris
Philips Bloom
Philips RGBW strips
Philips Dimmer button controller
GE Quirky Outlink2
Securifi Outlet Plugin (Peanut Plug)2
Sengled Element Plus Color Bulb (using Generic Zigbee RGBW Light)
SmartPower Outlets
SmartSense Motion Sensors
Smartthings Appliance Modules
Smartthings Contact Sensors
Smartthings Moisture Sensor (using Generic Zigbee Moisture Sensor)
Smartthings V1 & V2 & V3 & V5 (IM6001-MTP02) Motion Sensor (using Generic Zigbee Motion Sensor)
SmartThings V1 & V4 Multi Sensor
SmartThings V2 & V3 Presence Sensor
SmartThings ThingShield (custom driver)
Spotify Garden spot lights
Sylvania RBG Bulb (lightify/osram)
Sylvania Garden Spot (lightify/osram)
SYLVANIA SMART+ ZigBee Indoor Smart Plug part # 72922 (use iris plug DH)
Sylvania 2 button dimmer controller
Xbee (Zigbee versions) as routers and tracing Zigbee network
Xiaomi Aqara Button (custom driver)
Xiaomi Aqara Door/Window Sensor (custom driver)
Xiaomi Aqara Leak Sensor (custom driver)
Xiaomi Aqara Motion Sensor (custom driver)
Xiaomi Aqara Smart Wall Switch (custom driver)
Xiaomi "original" Button (custom driver)
Xiaomi "original" Door/Window Sensor (custom driver)
Xiaomi "original" Motion Sensor (custom driver)
Xiaomi Mi Cube Controller (custom beta driver)
Xiaomi MiJia Honeywell Smoke Detector (custom driver)
Zen Thermostat
Lutron Devices
Caséta Switches and Dimmers
Caséta SmartBridge Pro (multiple supported)
Pico Remotes (2, 4 and 5 button)
RadioRA 2 Select
RadioRA 2 Keypads
RadioRA 2 Motion Sensors
RadioRA 2 Main Repeater
RadioRA 2 Switches and Dimmers
Serena Shades
Sivoia QS Shades
LAN Devices
Amazon Echo
Arduino/ESP8266/ESP32 SmartThings ThingShield (custom driver)
IoTaWatt Energy Monitor (custom driver)
Logitech Harmony Hub (custom driver)
Nanoleaf Aurora Light Panels
Rheem EcoNet Communicating Thermostats (custom driver)
Rheem EcoNet Tankless Water Heaters (custom driver)
Sinope hub-based Thermostats (custom driver)
SmarLife H801 & Arilux RGBW Controllers (custom firmware, app, driver)
Sonoff Devices (custom firmware, app, driver)
Sonos Speakers
UK:Lightwwave RF (custom driver)
Wink Relay (custom driver)
Cloud Devices
Ecobee
IFTTT
Life360
LIFX (custom driver)
Nest
Pushbullet (custom driver)
Pushover Notifications
Rachio
Sharptools.io
Twilio Notifications (custom driver)
Footnotes
1 Manually change the driver to generic Z-Wave Switch
2 Manually change the driver to generic Zigbee outlet
Searchable database of devices and drivers
Compatible Devices List
Aeotec Multisensor 6
physicalgraph.zigbee.clusters.iaszone.ZoneStatus (Bosch Motion ISW-ZPR1-WP13)
Generic Zwave Moisture Sensor
Welcome Iris Customers!
"New" SmartThings 2018 sensors
Looking for advice before move to Hubitat
Question on drivers
Leviton DZ15S-1BZ and DZ1KD-1BZ Problems
Is there a better DH for Fibaro FGMS-001, built in support is disappointing
Linear GD00Z-4 garage door opener acting up
What can i do with a Schlage Lock on Hubitat
[RELEASE] Sonoff (Connect)
Current ST user
Lowes Iris WiFi Compatability
Just Starting - Smart product sources?
Coming over from SmartThings
Lowes IRIS Transition
Iris user overwhelmed
Light keeps turning itself off
Devices of choice
RGBW Tiles
Designing a New House - HE as a foundation
#3
Thank you for maintaining this list. It will be very helpful to new and existing users.
#5
Which driver should be used for the ST “Smart Outlet” Model number: F-OUT-US-2? It pairs as a “device” by default. I’m assuming “generic zigbee outlet” is probably the best choice?
#6
Added Sensative Strips Guard - works out of the box with Generic Contact Z-Wave Sensor driver
  • deviceType: 3
  • inClusters: 0x5E,0x86,0x72,0x30,0x70,0x71,0x5A,0x85,0x59,0x80,0x84,0x73
  • deviceId: 3
  • manufacturer: 410
#8
Does anyone know if the power meter works as well for this device?
#9
I can only confirm that the power meter reporting won't work if the Peanut Plug's firmware hasn't been updated.
#10
The Aeon micro switches are on the list, but has anyone tried the Aeon nano switches and/or dimmers?
#11
Yes they work with the generic zwave drivers, we don't have the fingerprints for them yet, so they will be discovered as a device, then you just change the driver.
#12
Thanks Mike. I can probably get you the fingerprints, as I have a couple in service on SmartThings and have another one in a box to add.
#13
What do you have in your house? I thought is was Nano switches, but obviously I'm mistaken.
#14
I'm using the micros, I have one nano i purchased for a fan that for whatever reason blew up 2 micros, but to be honest since they require an extra hot lead I don't like them.
#15
Not sure I understand what you mean by extra hot lead. Only one hot shown in the diagram here and the ability to work w/o neutral is a nice feature.
#16
#17
I understand now. I was linked to the dimmer page, not the switch. Dimmer only needs two line inputs when a bypass is required, Now I see that the switch always does need two line inputs for 120~240v loads, because of their unique ability to handle a 24vdc load without requiring a different module that isn't backward compatible with mains voltages.
#18
I don't see aeotech smart switch 6 listed. I have a bunch of them, are they supported?
I also don't see Aeotech SMARTSWITCH Z-WAVE PLUG-IN ENERGY METERING APPLIANCE MODULE # DSC06106-ZWUS
Which I have a couple of these
I also don't see the new fibaro wall plug I have these as well.
Anyone using these yet?
Built in or custom?
#19
I am using a Fibaro wall plug FGWPB-121 about half way down the list.
Sorry not home so I am not sure which DH I used.
#20
Thanks, it's listed as built in so I will give it a try. I missed that one.
#21
I got one last week and paired fine... as a device I believe. Tried the Aeon Outlet, didn't work. I also have the Dome Smart Switch and so I tried that DH on the Aeon... and it's working!
It's on my washing machine to notify us of "Done". The Dome is on the dryer.
#22
Which model? Aeon and Aeotec are the same company so not sure which one you mean.
Is Dome rated for the dryer? I would be careful with that one. I know Fibaro is rated for high Amp devices as is the Zooz Heavy Duty appliance switch but not sure about Dome. The dome I know about is for small appliances and rated for 13Amp, 0.13W
#23
Gas Dryer.
energy : 1.80
energyCost : 0.38
energyDuration : 11.18 Days
power : 0.00
powerH : 11.03
powerL : 0.00
status : on
switch : on
