Generic Zigbee Moisture Sensor (no temp) Battery 200%
I'm using the Generic Zigbee Moisture Sensor (no temp) driver for quite a few of our water leak sensors. It is alternatingly reporting Battery between 200% & 100%. I've temporarily switched one of them to [RELEASE] Tuya NEO Coolcam Zigbee Water Leak Sensor to see if it fixes it.
These are the devices affected:
Probed Water Leak Sensor:
  • endpointId: 01
  • application: 42
  • manufacturer: _TZ3000_upgcbody
  • model: TS0207
Meian Water Leak Sensor:
  • endpointId: 01
  • application: 42
  • manufacturer: _TZ3000_kyb656no
  • model: TS0207
Let me know if you need any more info!
Which driver was being used when the screenshot above was taken?
The Generic Zigbee Moisture Sensor (no temp). Your driver works great and is reporting it at 100% throughout the day :slight_smile: I may just continue using it.
