GE Zigbee Dimmer level not getting set as expected
I have a rule to turn on a light (Device: GE Zigbee Dimmer; Driver: GE Zigbee Dimmer) at an appropriate brightness when motion is detected in the master bath. During day hours it should come on full bright. Otherwise, it should come on at 13% brightness. I've noticed that the first time it is triggered in the night period, it still comes on full bright. If it gets triggered additional times during the night, it behaves correctly.
I can post the rule and device details if that would help troubleshoot, but I'm beyond thinking it is a rule problem. The device events show
"command-setLevel" but no "level" is seen. However, in subsequent triggers, level is seen at 13%.
Thread What am I missing here? and another related to whether or not to use pre-stage may be relevant here. But first, I think using a different driver may changes behaviour. Feedback? Suggestion for an appropriate driver for GE/Jasco Zigbee dimmer?
By the way, I used to have a GE/Jasco ZWave+ dimmer on that light for a couple years and didn't have this issue. I replaced that dimmer several weeks ago with the GE/Jasco Zigbee and that's when I started noticing this behaviour.
harumph. I noted this before but was told the problem didn't exist. Recently I think I solved mine by not using the default driver. I used the driver from ST - some 'features' (which I dont use and dont work right for me anyway like pre-stage) were lost but I don't miss them 1 iota.
I customized the driver slightly (to remove some excess but there is a ton more)
(here's one of my 12 Enbrighten dimmer switches:
 *	Copyright 2015 SmartThings
 *	Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *	in compliance with the License. You may obtain a copy of the License at:
 *		http://www.apache.org/licenses/LICENSE-2.0
 *	Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *	on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *	for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "GE ZigBee Dimmer from ST custom", namespace: "jshimota", author: "SmartThings", ocfDeviceType: "oic.d.light", runLocally: true, minHubCoreVersion: '000.019.00012', executeCommandsLocally: true, genericHandler: "Zigbee") {
		capability "Actuator"
		capability "Configuration"
		capability "Refresh"
		capability "Switch"
		capability "Switch Level"
		capability "Health Check"
		capability "Light"
        		// Generic
		fingerprint profileId: "0104", deviceId: "0101", inClusters: "0006, 0008", deviceJoinName: "Light" //Generic Dimmable Light
		// AduroSmart
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", deviceId: "0101", manufacturer: "AduroSmart Eria", model: "AD-DimmableLight3001", deviceJoinName: "Eria Light" //Eria ZigBee Dimmable Bulb
		fingerprint profileId: "0104", deviceId: "0101", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "AduroSmart Eria", model: "BDP3001", deviceJoinName: "Eria Switch" //Eria Zigbee Dimmable Plug
		// Aurora
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "LCBulb01UK", deviceJoinName: "AOne Dimmer Switch", ocfDeviceType: "oic.d.switch" //Aurora AOne Control Dimmer (120w)
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300", outClusters: "0003", manufacturer: "Aurora", model: "Dimmer", deviceJoinName: "AOne Dimmer Switch", ocfDeviceType: "oic.d.switch" //Aurora AOne Control Dimmer (320w)
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0009", outClusters: "0019", manufacturer: "Aurora", model: "FWMPROZXBulb50AU", deviceJoinName: "Aurora Light" //Aurora MPro
		fingerprint profileId: "0104", inClusters: "0000, 0004, 0003, 0006, 0008, 0005, FFFF, 1000", outClusters: "0019", manufacturer: "Aurora", model: "FWBulb51AU", deviceJoinName: "Aurora Light" //Aurora Smart Dimmable
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "FWStrip50AU", deviceJoinName: "Aurora Light" //Aurora Dimmable Strip Controller
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "Aurora", model: "FWGU10Bulb50AU", deviceJoinName: "Aurora Light" //Aurora Smart Dimmable GU10
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "NPD3032", deviceJoinName: "Aurora Dimmer Switch", ocfDeviceType: "oic.d.switch" //Aurora In-line Dimmer
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "WallDimmerMaster", deviceJoinName: "Aurora Dimmer Switch", ocfDeviceType: "oic.d.switch" //Aurora Smart Rotary Dimmer
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05 ,1000, FEDC", outClusters: "000A, 0019", manufacturer: "Aurora", model: "FWST64Bulb50AU", deviceJoinName: "Aurora Light" //Aurora Dimmable Filament Vintage ST64
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05 ,1000, FEDC", outClusters: "000A, 0019", manufacturer: "Aurora", model: "FWG125Bulb50AU", deviceJoinName: "Aurora Light" //Aurora Dimmable Filament Vintage G125
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05 ,1000, FEDC", outClusters: "000A, 0019", manufacturer: "Aurora", model: "FWA60Bulb50AU", deviceJoinName: "Aurora Light" //Aurora Dimmable Filament Vintage GLS
		//CWD
		// raw description "01 0104 0101 01 09 0000 0003 0004 0005 0006 0008 0B05 1000 FC82 02 000A 0019"
		fingerprint manufacturer: "CWD", model: "ZB.A806Edim-A001", deviceJoinName: "CWD Light" //model: "E27 dim", brand: "Collingwood"
		fingerprint manufacturer: "CWD", model: "ZB.A806Bdim-A001", deviceJoinName: "CWD Light" //model: "BC dim", brand: "Collingwood"
		fingerprint manufacturer: "CWD", model: "ZB.M350dim-A001", deviceJoinName: "CWD Light" //model: "GU10 dim", brand: "Collingwood"
		// IKEA
		fingerprint manufacturer: "IKEA of Sweden", model: "TRADFRI bulb E27 WW 806lm", deviceJoinName: "IKEA Light" // raw description 01 0104 0101 01 07 0000 0003 0004 0005 0006 0008 1000 04 0005 0019 0020 1000 //IKEA TRÅDFRI LED Bulb
		fingerprint manufacturer: "IKEA of Sweden", model: "TRADFRI bulb E27 WW clear 250lm", deviceJoinName: "IKEA Light" //raw desc: 01 0104 0101 01 07 0000 0003 0004 0005 0006 0008 1000 04 0005 0019 0020 1000 //IKEA TRÅDFRI LED Bulb
		// INGENIUM
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0301, FC01", manufacturer: "ubisys", model: "D1 (5503)", deviceJoinName: "INGENIUM Light" //INGENIUM ZB Universal Dimming Module ZBM01d
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "Megaman", model: "AD-DimmableLight3001", deviceJoinName: "INGENIUM Light" //INGENIUM ZB LED Classic
		// Innr
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019", manufacturer: "innr", model: "RF 263", deviceJoinName: "Innr Light" //Innr Smart Filament Bulb Vintage
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019", manufacturer: "innr", model: "BF 263", deviceJoinName: "Innr Light" //Innr Smart Filament Bulb Vintage
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019", manufacturer: "innr", model: "BF 265", deviceJoinName: "Innr Light" //Innr Smart Filament Bulb
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000", outClusters: "0019", manufacturer: "innr", model: "AE 260", deviceJoinName: "Innr Light" //Innr Smart Bulb
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000", outClusters: "0019", manufacturer: "innr", model: "BE 220", deviceJoinName: "Innr Light" //Innr Smart Flood Light White
		fingerprint manufacturer: "innr", model: "RF 265", deviceJoinName: "Innr Light" // raw description: 01 0104 0101 01 09 0000 0003 0004 0005 0006 0008 0B05 1000 FC82 01 0019 //Innr Smart Filament Bulb White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RB 265", deviceJoinName: "Innr Light" //Innr Smart Bulb White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RB 245", deviceJoinName: "Innr Light" //Innr Smart Candle White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RS 225", deviceJoinName: "Innr Light" //Innr Smart Spot White
		fingerprint manufacturer: "innr", model: "RF 261", deviceJoinName: "Innr Light" // Innr Smart filament globe vintage E27 (RF 261)  profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019" //Light
		fingerprint manufacturer: "innr", model: "RF 264", deviceJoinName: "Innr Light" // Innr Smart filament edison vintage E27 (RF 264) profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019" //Light
		// Leedarson
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "Smarthome", model: "S111-201A", deviceJoinName: "Leedarson Light" //Leedarson Dimmable White Bulb A19
		fingerprint profileId: "0104", inClusters: "0000, 0004, 0003, 0006, 0008, 0005, FFFF, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0000", deviceJoinName: "Light" //Smart Bulb
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "LDS", model: "ZHA-DIMLight-GLS0000", deviceJoinName: "Light" //Smart Bulb
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS", deviceJoinName: "Light" //Smart Bulb
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0044", deviceJoinName: "Light" //Smart Bulb
		// Leviton
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL6HD", deviceJoinName: "Leviton Dimmer Switch", ocfDeviceType: "oic.d.switch" //Leviton Dimmer Switch
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL3HL", deviceJoinName: "Leviton Dimmer Switch", ocfDeviceType: "oic.d.switch" //Leviton Lumina RF Plug-In Dimmer
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL1KD", deviceJoinName: "Leviton Dimmer Switch", ocfDeviceType: "oic.d.switch" //Leviton Lumina RF Dimmer Switch
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "ZSD07", deviceJoinName: "Leviton Dimmer Switch", ocfDeviceType: "oic.d.switch" //Leviton Lumina RF 0-10V Dimming Wall Switch
		// LINKIND
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "000A, 0019", manufacturer: "lk", model: "ZBT-DIMLight-GLS0010", deviceJoinName: "Linkind Light" //Linkind Dimmable A19 Bulb
		// Müller Licht
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "MLI", model: "ZBT-DimmableLight", deviceJoinName: "Tint Light" //Müller Licht Tint Bulb Dimming
		// OSRAM/Sylvania
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B04, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY A19 ON/OFF/DIM", deviceJoinName: "SYLVANIA Light" //SYLVANIA Smart A19 Soft White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY A19 ON/OFF/DIM 10 Year", deviceJoinName: "SYLVANIA Light" //SYLVANIA Smart 10-Year A19
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05", outClusters: "0019", manufacturer: "OSRAM SYLVANIA", model: "iQBR30", deviceJoinName: "SYLVANIA Light" //Sylvania Ultra iQ
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY PAR38 ON/OFF/DIM", deviceJoinName: "SYLVANIA Light" //SYLVANIA Smart PAR38 Soft White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B04, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY BR ON/OFF/DIM", deviceJoinName: "SYLVANIA Light" //SYLVANIA Smart BR30 Soft White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B04, 0B05, FC01, FC08", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "A19 W 10 year", deviceJoinName: "SYLVANIA Light" //SYLVANIA Smart 10Y A19 Soft White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B05, FC01", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "BR30 W 10 year", deviceJoinName: "SYLVANIA Light" //SYLVANIA Smart 10Y BR30 Soft White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B05, FC01", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "PAR38 W 10 year", deviceJoinName: "SYLVANIA Light" //SYLVANIA Smart 10Y PAR38 Soft White
		// Ozom
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "LEEDARSON LIGHTING", model: "M350ST-W1R-01", deviceJoinName: "OZOM Light" //OZOM Dimmable LED Smart Light
		// Sengled
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G13", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G14", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G23", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G33", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N13", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N14", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N15", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N13", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N14", deviceJoinName: "Sengled Light" //Sengled Element Classic
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E1A-AC2", deviceJoinName: "Sengled Light" //Sengled DownLight
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N13A", deviceJoinName: "Sengled Light" //Sengled Extra Bright Soft White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N14A", deviceJoinName: "Sengled Light" //Sengled Extra Bright Daylight
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E21-N13A", deviceJoinName: "Sengled Light" //Sengled Soft White
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E21-N14A", deviceJoinName: "Sengled Light" //Sengled Daylight
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-U21U31", deviceJoinName: "Sengled Light" //Sengled Element Touch
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05, FC01", outClusters: "0019", manufacturer: "sengled", model: "E13-A21", deviceJoinName: "Sengled Light" //Sengled LED Flood Light
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N1G", deviceJoinName: "Sengled Light" //Sengled Smart LED Vintage Edison Bulb
		// SmartThings
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0006", deviceJoinName: "Light" //Smart Bulb
		// Wemo
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FF00", outClusters: "0019", manufacturer: "MRVL", model: "MZ100", deviceJoinName: "Wemo Light" //Wemo Bulb
		// Enbrighten/Jasco
		fingerprint manufacturer: "Jasco Products", model: "43096", deviceJoinName: "Enbrighten Dimmer", ocfDeviceType: "oic.d.switch" //Enbrighten, Plug-in Smart Dimmer, 43096, Raw Description: 01 0104 0101 00 07 0000 0003 0004 0005 0006 0008 0B05 02 000A 0019
		fingerprint manufacturer: "Jasco Products", model: "43090", deviceJoinName: "Enbrighten Dimmer", ocfDeviceType: "oic.d.switch" //Enbrighten, In-Wall Smart Dimmer, Toggle. 43090, Raw Description: 01 0104 0101 00 07 0000 0003 0004 0005 0006 0008 0B05 02 000A 0019
		fingerprint manufacturer: "Jasco Products", model: "43080", deviceJoinName: "Enbrighten Dimmer", ocfDeviceType: "oic.d.switch" //Enbrighten, In-Wall Smart Dimmer, 43080, Raw Description: 01 0104 0101 00 07 0000 0003 0004 0005 0006 0008 0B05 02 000A 0019
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
				attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
				attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
				attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
			tileAttribute ("device.level", key: "SLIDER_CONTROL") {
				attributeState "level", action:"switch level.setLevel"
		standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
		main "switch"
		details(["switch", "refresh"])
        preferences {
        input name: "dbgEnable", type: "bool", title: "Enable debug logging", defaultValue: false
        input name: "warnEnable", type: "bool", title: "Enable warning text logging", defaultValue: true
// Parse incoming device messages to generate events
	    if (dbgEnable) log.debug "description is $description"
	def event = zigbee.getEvent(description)
	if (event) {
		if (event.name=="level" && event.value==0) {}
		else {
			sendEvent(event)
	} else {
		def descMap = zigbee.parseDescriptionAsMap(description)
		if (descMap && descMap.clusterInt == 0x0006 && descMap.commandInt == 0x07) {
			if (descMap.data[0] == "00") {
				if (dbgEnable) log.debug "ON/OFF REPORTING CONFIG RESPONSE: " + cluster
				sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
			} else {
				if (warnEnable) log.warn "ON/OFF REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
		} else if (isSengled() && descMap && descMap.clusterInt == 0x0008 && descMap.attrInt == 0x0000) {
			// This is being done because the sengled element touch/classic incorrectly uses the value 0xFF for the max level.
			// Per the ZCL spec for the UINT8 data type 0xFF is an invalid value, and 0xFE should be the max.  Here we
			// manually handle the invalid attribute value since it will be ignored by getEvent as an invalid value.
			// We also set the level of the bulb to 0xFE so future level reports will be 0xFE until it is changed by
			// something else.
			if (descMap.value.toUpperCase() == "FF") {
				descMap.value = "FE"
			sendEvent(zigbee.getEventFromAttrData(descMap.clusterInt, descMap.attrInt, descMap.encoding, descMap.value))
		} else {
			if (warnEnable) log.warn "DID NOT PARSE MESSAGE for description : $description"
			if (dbgEnable) log.debug "${descMap}"
def off() {
	zigbee.off()
def on() {
	zigbee.on()
def setLevel(value, rate = null) {
	def additionalCmds = []
	if (device.getDataValue("model") == "iQBR30" && value.toInteger() > 0) { // Handle iQ bulb not following spec
		additionalCmds = zigbee.on()
	} else if (isMRVL()) { // Handle marvel stack not reporting
		additionalCmds = refresh()
	} else if (isLeviton()) {
		additionalCmds = zigbee.levelRefresh()
	zigbee.setLevel(value) + additionalCmds
 * PING is used by Device-Watch in attempt to reach the Device
def ping() {
	return zigbee.onOffRefresh()
def refresh() {
	zigbee.onOffRefresh() + zigbee.levelRefresh()
def installed() {
	if ((isMRVL() && (device.getDataValue("model") == "MZ100")) || isOsram() || isOsramSylvania()) {
		if ((device.currentState("level")?.value == null) || (device.currentState("level")?.value == 0)) {
			sendEvent(name: "level", value: 100)
def isLeviton() {
	device.getDataValue("manufacturer") == "Leviton"
def isMRVL() {
	device.getDataValue("manufacturer") == "MRVL"
def isOsram() {
	device.getDataValue("manufacturer") == "OSRAM"
def isOsramSylvania() {
	device.getDataValue("manufacturer") == "OSRAM SYLVANIA"
def isSengled() {
	device.getDataValue("manufacturer") == "sengled"
def isJasco() {
	device.getDataValue("manufacturer") == "Jasco Products"
def configure() {
	if (dbgEnable) log.debug "Configuring Reporting and Bindings."
	// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
	// enrolls with default periodic reporting until newer 5 min interval is confirmed
	sendEvent(name: "checkInterval", value: 2 * 10 * 60 + 1 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
	// OnOff minReportTime 0 seconds, maxReportTime 5 min. Reporting interval if no activity
	refresh() + zigbee.onOffConfig(0, 300) + zigbee.levelConfig()
Well, we aren't crazy. I've totally repro'ed this. With the following rule, the observed behavior is that the light goes on full bright and 15 seconds later it goes off. This is repeated every 30 seconds. That's not what the rule says to do. The device events show command-setlevel with no value but not a value event.
I changed the driver to Generic Zigbee Dimmer and the repro rule now works as expected.
Looks like the GE Zigbee Dimmer driver doesn't set level correctly and indeed there are some threads about issues getting this device to come on at low levels originally. Maybe something leftover from that. @mike.maxwell
Ya my Sengled on my dresser still does this. Since no one else reported seeing it I just gave up and I'm living with the behavior.
Since the fix for my issue was replacing the GE Zigbee Dimmer with Generic Zigbee Dimmer, are you thinking the driver you are using has a similar issue?
Will give the generic a try. I've used the two Sengled drivers with the same results.
Seems to be working with the generic driver go figure… thanks for the suggestion.
I changed my GE/Jasco enbrighten 43096 Zigbee Dimmer Plug from the GE driver, for which level changes with the switch off had no effect, to the Generic Zigbee Dimmer, and the dimmer now the 43096 turns on as it sets the level, so not pre-staging.
