GE Smart Fan Control no longer reporting doubleTapped
@bcopeland The GE Smart Fan Control inbuilt driver used to report double tapping the switch. I have a rule that turns off all the lights in my bathroom when I double tap the bottom button and here is an example:
Ever since upgrading to the latest release and specifically ZwaveJS, double taps are no longer logged and my rule doesn't fire.
Same here, recently upgraded to ZwaveJS and double taps stopped working.
Thought it initially was some sort of pairing / authentication issue, but it doesn't seem to be. Removed and re-paired one of my fan control devices today, and double taps are still not registering.
Also tried updating firmware with the device firmware update tool, still no luck.
I'm assuming it is a driver related issue, or something with the driver is not playing nicely with ZwaveJS. Would be nice to get this functionality back, I use it to control the smart blinds in our master, and now I'm stuck yelling at google when I want to adjust them manually.
@bcopeland @bobbyD
