@bcopeland I appreciate all the amazing work with ZwaveJS over the last many months I wanted to circle back on a post I made last year and see if you are willing to investigate this issue.
The GE Smart Fan Control inbuilt driver used to report double tapping the switch. I have a rule that turns off all the lights in my bathroom when I double tap the bottom button and here is an example:
Ever since upgrading to ZwaveJS, double taps are no longer logged and my rule doesn't fire.
I have been trying to use the double tap function on this same switch for probably a year with no resolution. It just doesn't work. I have tried to set up and use this a few times and was hoping for something good to happen, but no luck. Hub is on 2.5.2.135, driver is GE Smart Fan Control. I would like this to work if possible. Thanks.
