I believe all of that needs to go.
Hah, got it to save.
And thanks for the info, now to see if it works.
Cut Tile code
tiles(scale: 2) {
multiAttributeTile(name: "switch", type: "lighting", width: 6, height: 4, canChangeIcon: true) {
tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off",
icon: "st.switches.switch.on", backgroundColor: "#00a0dc", nextState: "turningOff"
attributeState "off", label: '${name}', action: "switch.on",
icon: "st.switches.switch.off", backgroundColor: "#ffffff", nextState: "turningOn"
attributeState "turningOn", label: '${name}', action: "switch.off",
attributeState "turningOff", label: '${name}', action: "switch.on",
tileAttribute("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action: "switch level.setLevel"
childDeviceTile("outlet1", "outlet1", height: 2, width: 2, childTileName: "switch")
childDeviceTile("outlet2", "outlet2", height: 2, width: 2, childTileName: "switch")
childDeviceTile("levelSliderControl1", "outlet1", height: 2, width: 2, childTileName: "level")
childDeviceTile("levelSliderControl2", "outlet2", height: 2, width: 2, childTileName: "level")
standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label: '', action: "refresh.refresh", icon: "st.secondary.refresh"
main("switch")
details(["switch", "outlet1", "levelSliderControl1", "refresh", "outlet2", "levelSliderControl2"])
Edit: It works, sort of, but no better than the generic driver and certainly doesn't give individual control of the outlets.
Tagging @bcopeland from Hubitat, as he seems to be able to crank out Z-wave device drivers very quickly. ![]()
It was worth a try. I do not know any specifics of his device. Is it capable of indepemdant control of the sockets?
If the ST DTH creates child device(s), that section of code will also require some edits as Hubitat’s call to addChildDevice is slightly different than ST’s, IIRC.
2 Individually Controlled Z-Wave Outlets and 2 Always On USB Ports
So yes.. I’ll get a driver for it..
@bcopeland... did you ever get a driver for this device?
I got the device in.. Still in the box I’m afraid.. Been crazy busy..
@bcopeland ... totally understand the "been crazy busy". Is there a Paypal account I can contribute to get this to the top of the To Do list?
At the moment, I am kinda more interested in contributing to something to get the C-7 issues resolved.
Given the firestorm a few days ago, I suspect @bcopeland needs someone who can slow down time so he can get more done and still get some sleep.
I just appreciate how responsive everyone has been!!!
I also have the GE 3106 and can’t find a driver that works. Has anybody figured this out yet?
Driver is in 2.2.4
2.2.4 approximately ETA ?
As soon as it’s ready
So its not in beta yet:wink:
Not yet, still in Alpha
Hi Bryan,
Thank you for the driver for the two outlet smart plug.
I have updated from the generic to the new driver and I see the two outlets.
I also updated the two pico remotes to control them and all is working great!
One question, Where can I rename the two sub-dimmers?
They are called Dimmer-1, and Dimmer-2 by default but there is no reference to the parent device in the selection (tiles etc). I tried to edit them in the device component section but the name seems locked there.
Thank you
