I have set a notification to let me know when I have left the garage doors open for noir than an hour. However the notification app only will send me a text and play a sound on devices I donāt have.
However I do have a Aeotec Siren and I would like it to sound and flash if the garage door is left open for 1 hour and clear when the door is closed or the siren is pressed.
There are some additional features (repeated notifications) coming in the next version, but you can always use Rule Machine for more complicated actions as suggested above (though this one isn't really complicated, just apparently a device without capabilities that the Notifications app can use directly).
I second the idea of providing a screenshot of your rule. Be sure to include both the triggers and actions section. It sounds likely you might be missing the "Cancel" flag on the delay and possibly something else.
I'd also suggest trying the "notifications app" and setting the audio notification to your Siren.
My Dome Siren when using this kind of native T2P does one of the alarms as a default instead of the speech.
I haven't tried this in a while to make sure it's still working, but happy to if you need confirmation.
So are you not getting the text notification with this notification app child?
I guess I'm confused as you have mentioned RM and shows the screenshot of the notification app.
Mind clarifying the issue specifically you are having with this notification app version v.s. whatever you have tried to do in RM?
Also, kind of contact sensors are you using to determine open and closed?
Why don't you just use a RM rule to automatically close the garage door after an hour. At least have it part of your night time routine so you don't get wakened up by a siren.
