I Have a āRule Machineā rule to close my garage door if left open at midnight. The other night it opened at midnight and was open all night till I saw the notification āgarage door failed to closeā. It is a Chamberlain MyQ opener. So, I can easily check the history of the opener and it was closed before midnight and opened at midnight.
Zooz Z-Wave Plus S2 MultiRelay ZEN16 that has been connected for almost 3 years now with no problems. The rule I use is this:
I had noticed before this happened the Zooz relay said the door was opened, but the MyQ app said it was closed and the history verified that.
How can I prevent this from happening again? I am assuming the Zooz relay lost connection with the hub while it was in the open position and did not register when it was closed. Therefore, at midnight it thought the door was still opened and went to close it, but opened it instead, because it was already closed. Is there something I can change in my rule to prevent this?
I see that you have a garage door sensor and that you are checking it. You could always add another one and have it warn you if it sees a discrepancy between the twoā¦
This wonāt change anything in the running of the rule, but you could also make some changes:
Use a required expression instead of the IF condition (garage door sensor contact open)
Remove the if conditions in your rule. All that will be left is the āClose Garage Door Zoozā command.
One incident of opening the garage in the middle of the night is one too many. I would add another contact and check both before sending the command to close the garage.
Yeah I think I prefer my shutter door with its tubular motor. I've had a few issues to get around:
1 - Accidental activation while away. I've now switched the 'up' live connection through a relay so that it cannot open while the alarm is set (when we're out or in bed)
2 - Siri mishearing the TV and opening it via voice. I've now got two virtual switches in Homekit instead of the door - 'Open' and 'Confirm'. A rule dictates that 'Confirm' has to be switched on within 5 seconds of 'Open' to raise the door.
Your situation sounds different, but just because it is in the same theme of a garage door opening mysteriously, you might want to scan. The TL;DR version is that "something in the system" turned on the parent device on a ZEN16 spontaneously, and my assertion is that the parent device isn't used in any automation and there was no prerequisite activity before it turned on.
Using the Zooz garage door app, all you need to do is send the Close command to the virtual device. No need to check sensors and whatnot, the app does it for you. If it thinks the door is already closed it wont do anything. I have a goodnight rule that I activate when I go to bed and it just has a simple close command on it, which usually does nothing. If the garage was open by chance it would close it.
So in your case, clearly the Zooz virtual door thought the door was open, so it sent the command to the relay to trigger (which will just activate the door no matter which position it is in). Possibly your sensor failed to work correctly the last time it has closed.
Thanks for all the suggestions. I will play around with changing the rule. Still trying to figure out if the zooz relay or the garage door sensor lost connection with the hub. Both are Z-Wave.
It'll be a few days before I can work on it, but if you have any more suggestions, I'd appreciate any help. I dont want this to happen again. I was out of town when it happened.
The only possible answer is that the door sensor didnāt register the correct state. The relay doesnāt know anything about the state, it merely triggers the circuit to activate the door opener, not knowing if itās opening or closing it. You stated that the MyQ app showed the door was closed when the door sensor showed it was open, so you already have your smoking gun.
What door sensor are you using? Iāve seen reports of sensors getting stuck that use a ball bearing and people replacing the ball with a mercury sensor.
You should not need to do anything with the rule (except make it less complicated).
Here is my rule to make sure the door is closed when I go to bed. This is sending the Close command to a Virtual Door device created from the Zooz app (same as you).
Yes this is all you should need, it is that simple. The virtual door driver / app handles everything else as far as checking the sensors and making sure not to send a command if already closed.
Ecolink has a couple tilt sensor versions - the older one is is the physical ball-bearing style (which can get stuck), and the newer version is solid-state.
If you have the old ball-bearing style, I'd suggest replacing it - either with the latest version of Ecolink or something like the Zooz ZSE43 (also solid-state).
