From C4 to C8 observations
Hi all,
Finaly moved from C4 to C8 and here are my observations after 2 weeks:
Zwave and ZigBee networks are much more stable - huge plus.
Performance of C8 seems to be worth than C4:
Huge lag (not always) when viewing live logs - some times it takes up to a minute to start showing anything there.
Am I missing some setting?
If there aren't any obvious reasons in the past logs that might otherwise explain what could be going wrong with your hub, then I would look into network settings. Unresponsive interface and sluggish overall performance may be related to the following issue as described in the following post (this doesn't affect the C4 hubs):
I had not seen any errors on the switch interface -( if auto negotiation fails - the connection is half duplex on one side ) but will change and monitor behavior. Thank you for the tip.
I meant errors and warnings or hyperactive devices/apps in general on your hub's past logs
