I can't seem to find a driver that will work with this new zigbee water valve. I have tried the "Sinope zigbee water valve" drivers (both). I have tried the Generic zigbee water valve and generic zigbee outlet drivers, saved the device. Tried "configure". HE discovered the device right off the bat but I can't find any drivers that will simply open/close this valve? I'm running a C-7. I search in package manager for water valve and there is " LeakSmart Water Valve that says it is zigbee. Should i give that a shot ? Is anyone seen this water valve before ?
ZGB
Data * endpointId: 01
- application: 44
- inClusters: 0000,0004,0005,EF00
- manufacturer: _TZE200_1n2zev06
- model: TS0601
- outClusters: 0019,000A
- powerCluster: none
- softwareBuild:
This particular device is not explicitly defined and supported in the Tuya driver, but you can try a simple On/Off by manually selecting TS0601_VALVE_ONOFF profile :
Yep, I don't think you realize it, but that was me on the other thread that told you I got it to work with the above settings. Thanks for the help. I'll still be monitoring if you do any updates to support this new valve. I'm only using it to drain my pool down after Florida daily rain downpours so, I really only need the valve 100% open or closed, but it would be nice to have the "scheduling" function working. This valve has a setting where you can set a timer to shut the valve after however many minutes.
Yeah, these drivers are not working for this Frankever device. At least not consistently. I think its because this valve takes forever to open and close. I mean from start of open/close to completion is like 30 seconds, and I think the driver is looking for a "state" response but doesn't hits a TOV or something? Had you looked into this Frankever fk02 any further?
Hi Gordon,
I haven't had the chance to look at the FrankEver device any further - hopefully, I will have the time this weekend.
Help needed - Ask Tuya on Tuya forum to make their mmWave devices less spammy!
I have sent you a DM with a request to test the latest dev. branch version and to send me back the debug logs.
