All,
I have seen some pretty fancy posts here om the forum using code snippets, quotes, links, drop down lists etc etc.
Just thought i would share some of these options on formatting your message here for everyone to review and use.
Ref: BBCode.org reference documentation
- Using triggers like quote, code, summary, details or #
- Using [ ] or < > to encapsulate your formatting triggers
- close the formatting with the same trigger in brackets preceeded with a slash / after the opening trigger
Using # will enable you to link to a forum section
Also drop down lists are possible using the trigger details within opening and closing <>
Example formatting, results below
<details><drop-down list>Text block you want to summarize</details>
<details>
<summary> Title </summary>
Your summary in text here
</details>
- Simple drop down list
- Fancy dropdown list
fancy dropdown list
Your summary in text here ...Cheers! (And thanks for the usefull answers so far already, learning every minute here!)
And last but not least, dont be afraid to edit a post youve made
