My Fingerbot stopped working about two weeks ago. I tried a second Fingerbot and it has the same problem. They can both pair, but ping times out and commands don't work.
Hub: C-8 with 2.4.1.167 Fingerbot driver(latest) 3.3.0 @kkossev . The devices show up on the graph.
When I pair them with a C-7 with the same firmware and driver code, they work great. The only difference between the environments is the hardware.
I have tried Zigbee repair multiple times.
I have the following logs on the c-7 with devices that are working correctly.
dev:532025-05-20 02:49:45.582 PM
error
java.lang.NullPointerException: null on line 1159 (method parse)
dev:532025-05-20 02:49:45.573 PM
warn
Tuya Zigbee Fingerbot NOT PROCESSED Tuya cmd: dp=119 value=10 descMap.data = [00, 0E, 77, 02, 00, 04, 00, 00, 00, 0A]
dev:532025-05-20 02:49:45.567 PM
debug
Tuya Zigbee Fingerbot parse: descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8CD5 01 00 0000 05 01 000E770200040000000A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8CD5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:05, direction:01, data:[00, 0E, 77, 02, 00, 04, 00, 00, 00, 0A]] description=catchall: 0104 EF00 01 01 0040 00 8CD5 01 00 0000 05 01 000E770200040000000A
dev:532025-05-20 02:49:45.545 PM
error
dev:532025-05-20 02:49:45.536 PM
warn
Tuya Zigbee Fingerbot NOT PROCESSED Tuya cmd: dp=117 value=0 descMap.data = [00, 0D, 75, 01, 00, 01, 00]
dev:532025-05-20 02:49:45.448 PM
debug
Tuya Zigbee Fingerbot parse: descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8CD5 01 00 0000 05 01 000D7501000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8CD5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:05, direction:01, data:[00, 0D, 75, 01, 00, 01, 00]] description=catchall: 0104 EF00 01 01 0040 00 8CD5 01 00 0000 05 01 000D7501000100
