Fibaro Smart Implant
I updated the driver from "boblehest" mentioned above with periodic reports, analog and digital inputs, event notifications, etc and made it available here:
https://github.com/muchu999/Hubitat/tree/master/Fibaro%20FBGS-222%20Smart%20Implant
This driver is relatively generic and hopefully it will help others get started with using this device. Because of the lack of documentation on some features, I wasted quite a bit of time (a lot) making it work, especially the periodic reports.
I made another personal version for my own project where I used the smart implant with some relays and other parts to replace a Venmar HRV Altitude Wall Control.
Some specifics:
  • [update: To clarify the install, install the 5 files as 5 drivers. Use the main driver file "...smart implant" for the device "type" of the device. This main driver will take care of using the other drivers as required (it will create child devices automatically).]
  • Periodic reports only work when multiChannelAssociation is set in a very specific way. Nothing you should worry about unless you plan on changing the code...
  • [updated, see next post] Outputs are individually linked to the digital inputs unless the inputs are set to be analog. Once the input has acted upon its corresponding output, it is always possible to set it back to whatever you want using the switch commands.
  • I didn't test the external temperature sensors functionality because I don't have any [update, user @tinker3433 said it was working fine with 3 external sensors]
  • The on-board temperature sensor always report high because it is heated by the device.
  • I didn't test much the scenes and buttons modes
  • [updated: solved, commands have been removed from the parent] Some of the commands in the parent device are there just so they work for the children, use the commands in the children devices for setting outputs and refresh
  • Don't forget to "save preferences" and then press the "configure" button when changing parameters. Sending all the parameters to the implant over RF takes about 1 minute after "configure" is pressed.
