Good Morning,
I am having an issue where my Fibaro Dimmers (have been using the Fibaro Dimmer 2 Driver) are stuck with a status of sync Pending: True when trying to change to a toggle switch.
Is there a Driver for the original Fibaro Dimmer?
Thanks,
Phil
Is anyone able to help with this?
We do not have a driver for this device.
Just wondering if there is any plans to write a driver and if there is a voting system etc for drivers people need?
We do plan to write one. We don't have that device, which is why we haven't yet. Will see if we can get our hands on one.
We have the double, single and dimmer headed to the Lab, so we'll get on these drivers when they arrive.
General fibaro switch/dimmer question...
All of these support the use of a push button (ie momentary contact) switch in lieu of a traditional toggle/paddle (SPDT) switch, is anyone using them in this configuration?
If not, I'll leave those configuration elements out of the drivers I'm working on.
I am using them with a traditional switches such as the one below:
https://www.clipsal.com/Home-Owner/Products/Safety/Waterproof-Switches
Thanks for writing the driver
Hi Mike,
Just wondering how you went with the driver?
Thanks,
Phil
The switch is in this release, the dimmer and the dual switch will be in the next release, along with preference options to choose the connected switch type.
OK Cool,
Thanks Mike, have been travelling a fair bit and haven't had a lot of time to keep up on things.
Hi Mike,
Just wondering if the driver has been added for the Fibaro dimmers? I did see a few Fibaro drivers available but none of them seem to work or fix the Toggle issue when changing the setting.
Thanks,
Phil
Can you tell me about this?, don't know what that issue is.
I have about 10 of the first generation Fibaro dimmers in my house but have been unable to get a driver to allow me to use the toggle switch function. I am double switching all my light switches at the moment.
I have tried the drivers that i believe are correct either the fibaro dimmer becomes unresponsive or doesn't allow me to set the switch type as toggle (it just has pending sync but nothing happens).
Thanks for the assistance
Did you try the built in Fibaro Dimmer?
Can you enable debug logging with a live logging window open, then hit configure and then post the output?
Hi Mike,
Not much to see, output below:
`"dev:1692019-01-30 06:13:53.262 pm debugskip: SwitchMultilevelStopLevelChange()
dev:1692019-01-30 06:13:53.259 pm debugparse description: zw device: 06, command: 2605, payload:
dev:1692019-01-30 06:13:53.193 pm debugskip: SwitchMultilevelStopLevelChange()
dev:1692019-01-30 06:13:53.185 pm debugparse description: zw device: 06, command: 2605, payload:
dev:1692019-01-30 06:13:51.205 pm debugskip: SwitchMultilevelStartLevelChange(dimmingDuration:null, ignoreStartLevel:null, incDec:null, startLevel:null, stepSize:null, upDown:null)
dev:1692019-01-30 06:13:51.193 pm debugparse description: zw device: 06, command: 2604, payload: 20 01
dev:1692019-01-30 06:13:51.166 pm debugskip: SwitchMultilevelStartLevelChange(dimmingDuration:null, ignoreStartLevel:null, incDec:null, startLevel:null, stepSize:null, upDown:null)
dev:1692019-01-30 06:13:51.120 pm debugparse description: zw device: 06, command: 2604, payload: 20 01
dev:1692019-01-30 06:13:43.455 pm infoLight\Bedroom 1 is off [digital]
dev:1692019-01-30 06:13:43.428 pm debugdimmerEvents value: 0
dev:1692019-01-30 06:13:43.424 pm infoBasicReport value: 0
dev:1692019-01-30 06:13:43.403 pm debugparse description: zw device: 06, command: 2003, payload: 00
dev:1692019-01-30 06:13:42.922 pm debugrefresh
dev:1692019-01-30 06:13:42.876 pm warnconfigure...
dev:1692019-01-30 06:13:37.287 pm warndescription logging is: true
dev:1692019-01-30 06:13:37.285 pm warndebug logging is: true
dev:1692019-01-30 06:13:37.282 pm infoupdated..."
This includes the following steps:
- Updated config to be toggle switch
- Saved preferences
- Turned light on with single switch of switch
- Tried to turn light off (light stayed on) with single switch of light
Note: Light does turn off with a double switch of light switch
Edit: Fixed log format
Hi Mike,
Wondering if the log helped at all with why it isn't working? I'll be honest i have very limited knowledge once if comes to debugging the Zwave stuff.
Thanks,
Phil
