Fibaro Dimmer Driver / Toggle Switch
Hi Mike,
Sorry to hassle you but wondering if you have had a chance to look at the logs?
Thanks,
Phil
Any chance you might be able to help with this please?
Just me again
Can i please have an update regarding this thread?
@phillipbaaten, when you are calling on a response from someone you should use the "@" followed by the person's handle...otherwise you calls can be like shouts in the dark.
@mike.maxwell, someone needs your super powers.
@stephack thanks wasn't aware that i could do that and yep super powers are very much requested and appreciated.
@mike.maxwell or @bravenel Hi Mike or Bruce, are you able to provide any assistance?
I'll see if I can figure this out today.
The driver we have is for the newer versions of this device, which uses a different parameter number for this setting.
You will need to use the super basic zwave tool to set parameter 14 with a size of 1 to a value of 1
Thanks Mike, Will give it ago once i get home tonight
@mike.maxwell Yep that worked perfectly, didn't know that the basic zwave tool was there, will be using it more in the future.
Updates in the last few months seem to have fixed most of my devices that previously were unable to join the Hubitat.
@mike.maxwell @bravenel @phillipbaaten
Hi chaps, loving my hub, its really getting me into automation.
I have bought a couple of fibaro Dimmer2 switches using them with a retractable switch, i am using the second input to control another relay,
Are you able to look at a driver for the unit?
I think if you use the Fibaro RGBW controller you no longer need the LED driver. You can connect the LED’s to the controller directly. the controller also has a connector for a switch as well as a potentiometer.
