The first thing I'm going to say is thanks for finding this site.
Since you have posted this I have ported over the Smoke detector. It can be that quick.
All I did was replace every instance of
physicalgraph
with
hubitat
Copy the code from the Fibaro github repository into notepad or something similar and do a find and replace.
Then copy in to a new Device Handler. Hopefully it should go in OK. As I said the Smoke detector has.
* FIBARO Smoke Sensor
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Fibaro Smoke Sensor ZW5", namespace: "FibarGroup", author: "Fibar Group") {
capability "Battery"
capability "Configuration"
capability "Sensor"
capability "Smoke Detector"
capability "Temperature Measurement"
attribute "heatAlarm", "enum", ["overheat", "inactive"]
attribute "tamperStatus", "string"
fingerprint mfr:"010F", prod:"0C02"
fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x86, 0x72, 0x5A, 0x59, 0x85, 0x73, 0x84, 0x80, 0x71, 0x56, 0x70, 0x31, 0x8E, 0x22, 0x9C, 0x98, 0x7A", outClusters: "0x20, 0x8B"
simulator {
//battery
for (int i in [0, 5, 10, 15, 50, 99, 100]) {
status "battery ${i}%": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().batteryV1.batteryReport(batteryLevel: i)
).incomingMessage()
status "battery 100%": "command: 8003, payload: 64"
status "battery 5%": "command: 8003, payload: 05"
//smoke
status "smoke detected": "command: 7105, payload: 01 01"
status "smoke clear": "command: 7105, payload: 01 00"
status "smoke tested": "command: 7105, payload: 01 03"
//temperature
for (int i = 0; i <= 100; i += 20) {
status "temperature ${i}F": new hubitat.zwave.Zwave().securityV1.securityMessageEncapsulation().encapsulate(
new hubitat.zwave.Zwave().sensorMultilevelV5.sensorMultilevelReport(scaledSensorValue: i, precision: 1, sensorType: 1, scale: 1)
).incomingMessage()
preferences {
input(
title: "Fibaro Smoke Sensor manual",
description: "Tap to view the manual.",
image: "http://manuals.fibaro.com/wp-content/uploads/2017/07/sd_icon.png",
url: "http://manuals.fibaro.com/content/manuals/en/FGSD-002/FGSD-002-EN-A-v1.1.pdf",
type: "href",
element: "href"
parameterMap().each {
getPrefsFor(it)
tiles (scale: 2){
multiAttributeTile(name:"FGSD", type: "lighting", width: 6, height: 4){
tileAttribute ("device.smoke", key: "PRIMARY_CONTROL") {
def url = "http://fibaro-smartthings.s3-eu-west-1.amazonaws.com/smoke/"
attributeState("clear", label:"CLEAR", icon: url + "smoke-sensor0.png", backgroundColor:"#ffffff")
attributeState("detected", label:"SMOKE", icon: url + "smoke-sensor1.png", backgroundColor:"#e86d13")
attributeState("tested", label:"TEST", icon: url + "smoke-sensor1.png", backgroundColor:"#e86d13")
attributeState("unknown", label:"UNKNOWN", icon:url + "smoke-sensor1.png", backgroundColor:"#ffffff")
tileAttribute("device.multiStatus", key: "SECONDARY_CONTROL") {
attributeState("multiStatus", label: '${currentValue}')
valueTile("tamperStatus", "device.tamperStatus", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state("tamperStatus", label:'${currentValue}')
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "battery", label:'${currentValue}% battery', unit:"%"
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
state "temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("heatAlarm", "device.heatAlarm", inactiveLabel: false, width: 4, height: 2) {
state "inactive", label:'No temperature alarm', backgroundColor:"#ffffff"
state "overheat", label:'Temperature alarm', backgroundColor:"#bc2323"
standardTile("syncStatus", "device.syncStatus", decoration: "flat", width: 2, height: 2) {
def syncIconUrl = "http://fibaro-smartthings.s3-eu-west-1.amazonaws.com/keyfob/sync_icon.png"
state "synced", label: 'OK', action: "forceSync", backgroundColor: "#00a0dc", icon: syncIconUrl
state "pending", label: "Pending", action: "forceSync", backgroundColor: "#153591", icon: syncIconUrl
state "inProgress", label: "Syncing", action: "forceSync", backgroundColor: "#44b621", icon: syncIconUrl
state "incomplete", label: "Incomplete", action: "forceSync", backgroundColor: "#f1d801", icon: syncIconUrl
state "failed", label: "Failed", action: "forceSync", backgroundColor: "#bc2323", icon: syncIconUrl
state "force", label: "Force", action: "forceSync", backgroundColor: "#e86d13", icon: syncIconUrl
main "FGSD"
details(["FGSD","temperature", "battery", "heatAlarm", "tamperStatus", "syncStatus"])
//UI Support functions
def getPrefsFor(parameter) {
input(
title: "${parameter.num}. ${parameter.title}",
description: parameter.descr,
type: "paragraph",
element: "paragraph"
input(
title: null,
type: parameter.type,
options: parameter.options,
range: (parameter.min != null && parameter.max != null) ? "${parameter.min}..${parameter.max}" : null,
defaultValue: parameter.def,
required: false
def updated() {
log.debug "Updated"
if (state.lastUpdated && (now() - state.lastUpdated) < 2000) return
def cmds = []
def cmdCount = 0
if (settings."$it.key" == null || state."$it.key" == null) {
state."$it.key" = [value: it.def as Integer, state: "notSynced"]
if (settings."$it.key" != null) {
if (state."$it.key".value != settings."$it.key" as Integer || state."$it.key".state == "notSynced") {
state."$it.key".value = settings."$it.key" as Integer
state."$it.key".state = "notSynced"
cmdCount = cmdCount + 1
} else {
if (state."$it.key".state == "notSynced") {
if (cmdCount > 0) {
logging("${device.displayName} - sending config.", "info")
sendEvent(name: "syncStatus", value: "pending")
state.lastUpdated = now()
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
log.info "Executing zwaveEvent 86 (VersionV1): 12 (VersionReport) with cmd: $cmd"
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} battery is low"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbatt = now()
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationBusy cmd) {
def msg = cmd.status == 0 ? "try again later" :
cmd.status == 1 ? "try again in $cmd.waitTime seconds" :
cmd.status == 2 ? "request queued" : "sorry"
createEvent(displayed: true, descriptionText: "$device.displayName is busy, $msg")
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
log.info "Executing zwaveEvent 71 (NotificationV3): 05 (NotificationReport) with cmd: $cmd"
def result = []
if (cmd.notificationType == 7) {
switch (cmd.event) {
case 0:
//result << createEvent(name: "tamper", value: "Tamper is inactive", displayed: false)
sendEvent(name: "tamperStatus", value: "Tamper inactive")
break
case 3:
//result << createEvent(name: "tamper", value: "Tamper is active", descriptionText: "$device.displayName casing was opened")
sendEvent(name: "tamperStatus", value: "Tamper active")
break
break
break
} else if (cmd.notificationType == 1) { //Smoke Alarm (V2)
log.debug "notificationv3.NotificationReport: for Smoke Alarm (V2)"
result << smokeAlarmEvent(cmd.event)
} else if (cmd.notificationType == 4) { // Heat Alarm (V2)
log.debug "notificationv3.NotificationReport: for Heat Alarm (V2)"
result << heatAlarmEvent(cmd.event)
} else if (cmd.notificationType == 8) {
if (cmd.event == 0x0A) {
def map = [:]
map.name = "battery"
map.value = 1
map.unit = "%"
map.displayed = true
result << createEvent(map)
} else if (cmd.notificationType == 9) {
if (cmd.event == 0x01) {
result << createEvent(descriptionText: "Warning: $device.displayName system hardware failure", isStateChange: true)
} else {
log.warn "Need to handle this cmd.notificationType: ${cmd.notificationType}"
result << createEvent(descriptionText: cmd.toString(), isStateChange: false)
result
private multiStatusEvent(String statusValue, boolean force = false, boolean display = false) {
sendEvent(name: "multiStatus", value: statusValue, descriptionText: statusValue, displayed: display)
def smokeAlarmEvent(value) {
def alarmInfo = "Last alarm detection: "
def alarmTestInfo = "Last alarm detection - TEST: "
log.debug "smokeAlarmEvent(value): $value"
def map = [name: "smoke"]
if (value == 2) {
map.value = "detected"
map.descriptionText = "$device.displayName detected smoke"
state.lastAlarmDate = "\n"+new Date().format("yyyy MMM dd EEE HH:mm:ss", location.timeZone)
multiStatusEvent(alarmInfo + state.lastAlarmDate)
} else if (value == 0) {
map.value = "clear"
map.descriptionText = "$device.displayName is clear (no smoke)"
} else if (value == 3) {
map.value = "tested"
map.descriptionText = "$device.displayName smoke alarm test"
multiStatusEvent(alarmTestInfo + state.lastAlarmDate)
} else {
map.value = "unknown"
map.descriptionText = "$device.displayName unknown event"
createEvent(map)
def heatAlarmEvent(value) {
log.debug "heatAlarmEvent(value): $value"
def map = [name: "heatAlarm"]
if (value == 2) {
map.value = "overheat"
map.descriptionText = "$device.displayName overheat detected"
map.value = "inactive"
map.descriptionText = "$device.displayName heat alarm cleared (no overheat)"
} else {
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
log.info "Executing zwaveEvent 84 (WakeUpV1): 07 (WakeUpNotification) with cmd: $cmd"
log.debug "WakeUpNotification"
def event = createEvent(descriptionText: "${device.displayName} woke up", displayed: false)
def cmds = []
def cmdsSet = []
def cmdsGet = []
def cmdCount = 0
def results = [createEvent(descriptionText: "$device.displayName woke up", isStateChange: true)]
cmdsGet << zwave.batteryV1.batteryGet()
cmdsGet << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: 0)
if (device.currentValue("syncStatus") != "synced") {
if (device.currentValue("syncStatus") == "force") {
if (state."$it.key"?.value != null && state."$it.key"?.state == "notSynced") {
cmdsSet << zwave.configurationV2.configurationSet(configurationValue: intToParam(state."$it.key".value, it.size), parameterNumber: it.num, size: it.size)
cmdsGet << zwave.configurationV2.configurationGet(parameterNumber: it.num)
log.debug "Not synced, syncing ${cmdCount} parameters"
sendEvent(name: "syncStatus", value: "inProgress")
runIn((5 + cmdCount * 1.5), syncCheck)
if (cmdsSet) {
cmds = encapSequence(cmdsSet, 500)
cmds << "delay 500"
cmds = cmds + encapSequence(cmdsGet, 1000)
cmds << "delay " + (5000 + cmdCount * 1500)
cmds << encap(zwave.wakeUpV1.wakeUpNoMoreInformation())
results = results + response(cmds)
return results
def syncCheck(){
logging("${device.displayName} - Executing syncCheck()", "info")
log.warn "CHECK"
def notSynced = []
def count = 0
if (state."$it.key"?.state == "notSynced") {
notSynced << it
log.warn "Sync failed! Verify parameter: ${notSynced[0].num}"
log.warn "Sync $it.key " + state."$it.key"
sendEvent(name: "batteryStatus", value: "Sync incomplited! Check parameter nr. ${notSynced[0].num}")
count = count + 1
if (count == 0) {
logging("${device.displayName} - Sync Complete", "info")
sendEvent(name: "syncStatus", value: "synced")
} else {
logging("${device.displayName} Sync Incomplete", "info")
if (device.currentValue("syncStatus") != "failed") {
sendEvent(name: "syncStatus", value: "incomplete")
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
log.info "Executing zwaveEvent 31 (SensorMultilevelV5): 05 (SensorMultilevelReport) with cmd: $cmd"
def map = [:]
switch (cmd.sensorType) {
case 1:
map.name = "temperature"
def cmdScale = cmd.scale == 1 ? "F" : "C"
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
map.unit = getTemperatureScale()
break
default:
map.descriptionText = cmd.toString()
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.deviceresetlocallyv1.DeviceResetLocallyNotification cmd) {
log.info "Executing zwaveEvent 5A (DeviceResetLocallyV1) : 01 (DeviceResetLocallyNotification) with cmd: $cmd"
createEvent(descriptionText: cmd.toString(), isStateChange: true, displayed: true)
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.info "Executing zwaveEvent 72 (ManufacturerSpecificV2) : 05 (ManufacturerSpecificReport) with cmd: $cmd"
log.debug "manufacturerId: ${cmd.manufacturerId}"
log.debug "manufacturerName: ${cmd.manufacturerName}"
log.debug "productId: ${cmd.productId}"
log.debug "productTypeId: ${cmd.productTypeId}"
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.DeviceSpecificReport cmd) {
log.debug "deviceIdData: ${cmd.deviceIdData}"
log.debug "deviceIdDataFormat: ${cmd.deviceIdDataFormat}"
log.debug "deviceIdDataLengthIndicator: ${cmd.deviceIdDataLengthIndicator}"
log.debug "deviceIdType: ${cmd.deviceIdType}"
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
def result = []
if (cmd.nodeId.any { it == zwaveHubNodeId }) {
result << createEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
} else if (cmd.groupingIdentifier == 1) {
result << createEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
result
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
def map = [:]
case 1:
map.name = "smoke"
map.value = cmd.sensorState == 0xFF ? "detected" : "clear"
map.descriptionText = cmd.sensorState == 0xFF ? "$device.displayName detected smoke" : "$device.displayName is clear (no smoke)"
break
case 4:
map.name = "heatAlarm"
map.value = cmd.sensorState == 0xFF ? "overheat" : "inactive"
map.descriptionText = cmd.sensorState == 0xFF ? "$device.displayName overheat detected" : "$device.displayName heat alarm cleared (no overheat)"
break
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.timeparametersv1.TimeParametersGet cmd) {
log.info "Executing zwaveEvent 8B (TimeParametersV1) : 02 (TimeParametersGet) with cmd: $cmd"
def nowCal = Calendar.getInstance(TimeZone.getTimeZone("UTC"))
//Time Parameters are requested by an un-encapsulated frame
response(zwave.timeParametersV1.timeParametersReport(year: nowCal.get(Calendar.YEAR), month: (nowCal.get(Calendar.MONTH) + 1), day: nowCal.get(Calendar.DAY_OF_MONTH),
hourUtc: nowCal.get(Calendar.HOUR_OF_DAY), minuteUtc: nowCal.get(Calendar.MINUTE), secondUtc: nowCal.get(Calendar.SECOND)).format())
def zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "General zwaveEvent cmd: ${cmd}"
private command(hubitat.zwave.Command cmd) {
def secureClasses = [0x20, 0x5A, 0x70, 0x71, 0x84, 0x85, 0x8E, 0x9C]
if (isSecured() && secureClasses.find{ it == cmd.commandClassId }) {
log.info "Sending secured command: ${cmd}"
secure(cmd)
} else {
log.info "Sending unsecured command: ${cmd}"
crc16(cmd)
private secure(hubitat.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crc16(hubitat.zwave.Command cmd) {
//zwave.crc16encapV1.crc16Encap().encapsulate(cmd).format()
"5601${cmd.format()}0000"
private commands(commands, delay=200) {
log.info "inside commands: ${commands}"
delayBetween(commands.collect{ command(it) }, delay)
private setSecured() {
updateDataValue("secured", "true")
private isSecured() {
getDataValue("secured") == "true"
## Z-Wave Toolkit ##
def result = []
logging("${device.displayName} - Parsing: ${description}")
if (description.startsWith("Err 106")) {
result = createEvent(
descriptionText: "Failed to complete the network security key exchange. If you are unable to receive data from it, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
displayed: true,
} else if (description == "updated") {
return null
} else {
def cmd = zwave.parse(description, cmdVersions())
if (cmd) {
logging("${device.displayName} - Parsed: ${cmd}")
zwaveEvent(cmd)
//event handlers related to configuration and sync
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
def paramKey = parameterMap().find({ it.num == cmd.parameterNumber }).key
logging("${device.displayName} - Parameter ${paramKey} value is ${cmd.scaledConfigurationValue} expected " + state."$paramKey".value, "info")
if (state."$paramKey".value == cmd.scaledConfigurationValue) {
state."$paramKey".state = "synced"
log.debug state."$paramKey"
//security
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
setSecured()
def encapsulatedCommand = cmd.encapsulatedCommand(cmdVersions())
if (encapsulatedCommand) {
log.debug "command: 98 (Security) 81(SecurityMessageEncapsulation) encapsulatedCommand: $encapsulatedCommand"
zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = cmdVersions()[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
logging("${device.displayName} - Parsed Crc16Encap into: ${encapsulatedCommand}")
} else {
log.warn "Unable to extract CRC16 command from $cmd"
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
logging("${device.displayName} - Parsed MultiChannelCmdEncap ${encapsulatedCommand}")
zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint as Integer)
} else {
log.warn "Unable to extract MultiChannel command from $cmd"
private logging(text, type = "debug") {
if (settings.logging == "true") {
log."$type" text
private secEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using Secure Encapsulation, command: $cmd", "info")
private crcEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using CRC16 Encapsulation, command: $cmd", "info")
zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format()
private multiEncap(hubitat.zwave.Command cmd, Integer ep) {
logging("${device.displayName} - encapsulating command using MultiChannel Encapsulation, ep: $ep command: $cmd", "info")
zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint: ep).encapsulate(cmd)
private encap(hubitat.zwave.Command cmd, Integer ep) {
encap(multiEncap(cmd, ep))
private encap(List encapList) {
encap(encapList[0], encapList[1])
private encap(Map encapMap) {
encap(encapMap.cmd, encapMap.ep)
private encap(hubitat.zwave.Command cmd) {
if (zwaveInfo.zw.contains("s")) {
secEncap(cmd)
} else if (zwaveInfo.cc.contains("56")) {
crcEncap(cmd)
} else {
logging("${device.displayName} - no encapsulation supported for command: $cmd", "info")
cmd.format()
private encapSequence(cmds, Integer delay = 250) {
delayBetween(cmds.collect { encap(it) }, delay)
private List intToParam(Long value, Integer size = 1) {
def result = []
size.times {
result = result.plus(0, (value & 0xFF) as Short)
value = (value >> 8)
return result
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationRejectedRequest cmd) {
log.warn "Flood Sensor rejected configuration!"
sendEvent(name: "syncStatus", value: "failed")
def zwaveEvent(hubitat.zwave.commands.securityv1.NetworkKeyVerify cmd) {
log.info "Executing zwaveEvent 98 (SecurityV1): 07 (NetworkKeyVerify) with cmd: $cmd (node is securely included)"
log.debug cmd
def zwaveEvent(hubitat.zwave.commands.securityv1.SecuritySchemeReport cmd) {
log.debug cmd
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
log.info "Executing zwaveEvent 98 (SecurityV1): 03 (SecurityCommandsSupportedReport) with cmd: $cmd"
def configure() {
state.lastAlarmDate = "-"
def cmds = []
//1. configure wakeup interval
cmds += zwave.wakeUpV1.wakeUpIntervalSet(seconds:4200, nodeid:zwaveHubNodeId)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, scaledConfigurationValue: 2)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, scaledConfigurationValue: 0)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 20, size: 2, scaledConfigurationValue: 1)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 21, size: 1, scaledConfigurationValue: 11)
cmds += zwave.configurationV1.configurationSet(parameterNumber: 30, size: 1, scaledConfigurationValue: 55)
cmds += zwave.wakeUpV1.wakeUpNoMoreInformation()
encapSequence(cmds, 500)
private Map cmdVersions() {
[0x86: 1, 0x72: 2, 0x59: 1, 0x73: 1, 0x80: 1, 0x56: 1, 0x31: 5, 0x22: 1, 0x98: 1, 0x7A: 2, 0x84: 1, 0x84: 2, 0x71: 3, 0x70: 1, 0x70: 2, 0x8E: 1, 0x8E: 2, 0x9C: 1, 0x5A: 1, 0x85: 1, 0x85: 2, 0x20: 1, 0x8B: 1]
private parameterMap() {
[key: "smokeSensorSensitivity", num: 1, size: 1, type: "enum", options: [
1: "High",
2: "Medium",
3: "Low"],
def: 2, title: "Fibaro Smoke Sensor sensitivity", descr: ""],
[key: "statusNotification", num: 2, size: 1, type: "enum", options: [
0: "all notifications disabled",
1: "casing opening notification enabled",
2: "exceeding temperature threshold notification enabled",
3: "casing opening and exceeding temperature threshold enabled"],
def: 0, title: "Status notification:", descr: "Notification sends in case of excess temperature and/or case opening"],
[key: "intervalOfTemperatureReports", num: 20, size: 2, type: "enum", options: [
1: "10s",
3: "30s",
6: "60s",
30: "300s",
60: "600s",
360: "3600s",
864: "8640s"],
def: 1, title: "Interval of temperature measurements", descr: "Time interval between temperature measurements. Report is sent when the measured value is different than previous one - specified in par. 21"],
[key: "temperatureReportsThreshold", num: 21, size: 1, type: "enum", options: [
3: "0.5°F / 0.3°C",
6: "1°F / 0.6°C",
11: "2°F / 1.1°C",
17: "3°F / 1.7°C",
22: "4°F / 2.2°C",
28: "5°F / 2.8°C"],
def: 11, title: "Temperature reports threshold ", descr: "Change of temperature resulting in temperature report being sent to the HUB."],
[key: "temperatureThreshold", num: 30, size: 1, type: "enum", options: [
55: "130°F / 55°C",
60: "140°F / 60°C",
65: "150°F / 65°C",
71: "160°F / 71°C",
77: "170°F / 77°C",
82: "180°F / 82°C",
93: "200°F / 93°C"],
def: 55, title: "Temperature threshold", descr: "Temperature above which the excess temperature notification is sent to the HUB (with visual and sound indication)"]
