I am in the process of migrating to HE from Smartthings and I am having an issue with a Fibaro Contact Sensor (FGDW-002). I can pair the device just fine, and I do get temperature and battery reports but not contact reports. When the contact is closed I get a status update but when the contact is open nothing is reported back to HE.
I moved a Fibaro plug nearby to act as a repeater just in case this was a zwave issue but I am getting very good stats from the device so I don't think that's the case.
I also tried excluding the device and including again but I am getting the exact same behavior.
Finally, the builtin driver for the device doesn't seem to have a wakeup interval config param and my device defaults to 12 hours so unless I wake it up manually it is impossible to test.
Am I doing something wrong? Shouldn't the contact status be reported as soon as it changes?
With parameter 14 and 15 you are able to set a time delay to report changes for the contact sensor.
Maybe check them out using this:
Did you exclude with HE and performed a factory reset before including again?
This is the recommonded procedure for each Z-Wave device.
Also make sure to keep the device close to the hub when including.
I have two of them and both work fine using the builtin drivers, additional configuration has to be done with "Basic Z-Wave Tool".
There's no parameter for this at all, so I'm afraid you have to keep waking up the sensor.
