I have a rule that if motion stops, the lights fade over time.
I would like to set ten seconds, but can only set minutes.
Is there a way to set it in seconds?
I use Transitions under Groups and Scenes to do my transitioning, it does it in seconds. If that helps at all.
The fade action is in minutes, but you should be able to use the dimmer action to set the dimming time to 10 seconds.
Thx, wil give that a try
