Exterior temp/internal sensor graph
I’ve tried this before but failed.
I Would love to do some analysis and see a graph/chart over time of the temperature sensors in various rooms in my house (with sensors) compared to outdoor temp. Bonus would be to add in my hvac settings (can be manual.)
Has anyone done this, using something like Hubigraphs?
I suspect that Watchtower may provide you with what you are looking for:
I personally think Watchtower is a poor fit for this purpose cause it uses a Round Robin Database, where the resolution of the data degrades as it ages. From the Readme:
The application utilizes a fixed-size database, similar in design and purpose to an RRD (Round-Robin Database). This setup allows for high-resolution data (minutes per point) to gradually degrade into lower resolutions for long-term retention of historical data.
(FWIW, I like and use Watchtower)
True, however I believe that the resolution change can be disabled, though it is not recommended…
