I'm consistently getting error 500 when I try to force-remove a Schlage be469nx lock.
I already excluded the lock through Hubitat, but not via 'delete' of the device itself. I put controller into z-wave exclusion state via z-wave settings.
Now I'm trying to remove the device, so I press 'Delete', it puts controller into exclusion mode, then after a while, it gives me an option to force-delete the device. When I press that 'Force-delete' button, I'm getting error 500 (with no details).
No that is not a known issue. Did you change the device network id of this device? You are not supposed to change that value for zwave and zigbee devices, it is assigned by the system and is very specific to the device.
Its a balancing act, it can be changed if you know what you are doing, but should not be changed if you don't. We are discussing adding a warning for these cases
Thank you. Thank you.
I spent the weekend searching for this solution and of course it wasn't until I sent an email to support that I stumbled on this. Never the less, thank you.
